Thread Number: 36061
Maytag washer |
Post# 537567 , Reply# 1   8/17/2011 at 12:09 (4,628 days old) by macboy91si (Frankfort, KY)   |   | |
I think a more popular opinion here would be you should have kept the 106 :)
Personally I would have, I'm not a fan of the later Maytags with the fast stroke. I've also heard of many seal and bearing replacements on them. Also this is to assume your newer Maytag is not an Amana-tag or Norge-tag, many are not "real" Maytags. I don't know what that model number you have is though. Out of curiosity, what was wrong with the 106? -Tim |
Post# 537597 , Reply# 3   8/17/2011 at 13:43 (4,628 days old) by macboy91si (Frankfort, KY)   |   | |
I'm gonna go out on a limb and say this is actually a Newton machine. It's a fast stroke agitation. It's very similar in design as you're old 106, just a bit cheapened :) While I'm not a big Maytag guy, I do like the slow stroke of the older models much more. I under-load my washers anyhow (except the poor little portable BD I have) so the Maytag still does fine even if it has less than spectacular rollover. We had the fast stroke models at the college campus and I did not like them, they were also unreliable in MY experience. Your mileage may vary :)
-Tim |
Post# 538632 , Reply# 4   8/21/2011 at 20:38 (4,623 days old) by dnastrau (Lords Valley, PA)   |   | |
Yes, that is a "true" Maytag, not a "Norgetag" or "Amanatag." |
Post# 538640 , Reply# 5   8/21/2011 at 21:29 (4,623 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes this is the good MT designed and built machine, and it has a larger capacity and better wash action if it has the Load Sensor agitator [ if not get one for it ] than the old MT you had, I think you made the correct decision. The load going OOB could not damage the timer. Be sure that the washer is leveled properly as close to the floor as possible with all four rubber feet in place and all four lock nuts tight against the base of the washer. This is often a problem on Newton MTs if this is not done correctly. |
Post# 538680 , Reply# 6   8/22/2011 at 04:35 (4,623 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 538949 , Reply# 7   8/23/2011 at 09:03 (4,622 days old) by kindalazy (toronto)   |   | |
I'm glad I have a genuine Maytag, and yes, it does have a Load Sensor agitator! Great turnover. Do I need to worry about the slight indexing, or is this normal on this machine? Cheers |
Post# 538956 , Reply# 8   8/23/2011 at 10:22 (4,622 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 539056 , Reply# 9   8/23/2011 at 16:42 (4,622 days old) by kindalazy (toronto)   |   | |
Oh, our washer guy (who sold us the original a106) told me that even if I do a cold water wash and rinse, to make sure both the hot and cold water faucets should be open. Is this right? And if so, why? |
Post# 539309 , Reply# 10   8/24/2011 at 19:01 (4,621 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
