Thread Number: 3613
New User - GE FilterFlo Question |
Post# 88837 , Reply# 1   10/14/2005 at 09:48 (6,766 days old) by peterh770 (Marietta, GA)   |   | |
You really should read what I responded to you on this same post on the other FF thread: Hummer, 1) is there a washer on the market now that removes lint and hair well; No. The best you can do is a front loader that doesn't produce lint with "thrashing blades" of an agitator and a good, roomy dryer. 2) if I decide to stick with the old FFs, what was the best performance year(s) for them; Since the design of the FF hasn't changed in many years, there really isn't a good or bad model year run. 3) what are the best features to watch for (stainless tubs, etc.); In a new washer or in the FF's? Find a washer with the features that you want and need. 4) which years had the choice of hot wash/hot rinse, hopefully falling within the best performance years; The only instance of a hot rinse that I know of were the spray rinses on early SQ models. If you want a hot rinse, you are going to have to either fill the washer manually, or connect your hot water to your washer's cold water valve. 5) which years did not dumb down the hot water wash option and add cold water. I don't think GE ever did this in the FF line "way back then". |
