Thread Number: 36244
FOR SALE 1962 RCA Whirlpool Imperial Dryer
Post# 540030   8/27/2011 at 21:10 (4,615 days old) by stainfighter (Columbia, SC)
stainfighter's profile picture
While I truly appreciate this forum's founder, collectors and enthusiasts (and expertise so many of you share) I am not meant to collect vintage appliances, just be an admirer :-). In 2008 we acquired this beloved 1962 RCA WP Imperial dryer from Mark (LightedControls). It has been a FAITHFUL daily driver but now with three dogs, and their bedding, we need a LARGE capacity dryer. She is PURTY but she ain't a BIG gal, rather petite! (her capacity is about 4 cubic feet?).
We adopted her for $275 because of LOOKS and features (lighted console, porthole window) and the care shown by her former owner. The paint is not perfect but original. All cycles, the lights, and the two speeds are working. Timer starts and stops on all cycles, drum light works, all temperature settings work great; the door creaks but does close with the use of velcro (and has worked quite well this way for us). She does not have her front 'legs' you can see in the lower right of the picture a piece of foam used to balance her. The picture angle makes it look like the paint is scratched above the door handle, but it is not. She appears to have what may be her original lint filter, but does not have the fragrance bottle, just a blank space near the lint filter). Her very first owner (not Mark) must have kept her in a damp basement, the base of her body does have some rust which was touched up prior to our adoption in 2008. Her paint is not perfect at the base but the top, door and overall front appearance is nice. I would prefer she be adopted by an AW member. If you can make a reasonable offer --AND collect her before the end of September-- (I have NO storage) she can be YOURS! The 4-prong cord will be included. Other pictures available upon request. Email: rstuessy@sc.rr.com.
Post# 540055 , Reply# 1   8/28/2011 at 00:42 (4,615 days old) by akronman (Akron/Cleveland Ohio)
request
akronman's profile picture
Can you post a closeup of the console, please?
Thanks
Post# 540087 , Reply# 2   8/28/2011 at 06:57 (4,615 days old) by stainfighter (Columbia, SC)
request, close-up (1)
of course! ...
Post# 540090 , Reply# 3   8/28/2011 at 07:00 (4,615 days old) by stainfighter (Columbia, SC)
request, close-up (2)...
When we first acquired her, I wasn't sure how to start a cycle. One turns the dial to the amount of time then pushes in one of the heat/air settings and it begins. Our favorite cycle for bath towels is P.P. at 40 minutes on HIGH, when it times down to 10 minutes it does not add much -if any- heat and the results are perfectly dry not-baked towels. I really wish we had room to keep her :(...
Post# 540092 , Reply# 4   8/28/2011 at 07:04 (4,615 days old) by akronman (Akron/Cleveland Ohio)
news
I've never heard of 2 speeds on a dryer!
Post# 540093 , Reply# 5   8/28/2011 at 07:08 (4,615 days old) by stainfighter (Columbia, SC)
request, close-up (3)...cycle selection
...where one can see that a button has been selected. The button stays in place after it is pushed. If one needs to check the dryness of clothes just open the door, then push the button to restart. One can also switch temperature mid-cycle by pushing a different button, it has a distinct 'click' when a selection is made. The drum and console lights come on as soon as you turn the timer dial on and stay on until the cycle completes; the timer 'click's when it reaches off.
Post# 540104 , Reply# 6   8/28/2011 at 08:49 (4,615 days old) by DADoES (TX, U.S. of A.)
Multiple speed Whirlpool dryers
dadoes's profile picture
Two-speed on this model does not refer to two tumble speeds. The speed control changes the airflow rate for a faster or slower drying rate by shifting the blower belt on a dual-diameter pulley. Not sure, the heating element may be dual-wattage.
When Whirlpool went to the direct-drive blower design, airflow rate was changed via a damper door in the blower housing.
There were models in the early 1970s with THREE and then two tumble speeds, achieved by shifting the drum belt along a tapered-diameter motor pulley.
Post# 540110 , Reply# 7   8/28/2011 at 09:05 (4,615 days old) by stainfighter (Columbia, SC)
Dual-wattage heating element?...
...DADoES knows more about this baby than do I, it does run quieter on 'Normal' (not that it is roaring loud on 'Super'). It is not as loud as say a Norge dryer. Probably not as quiet as a modern dryer but it's not bothersome - actually pleasant (to me).
I haven't noticed any difference in heat output, it seems like all temperature options work the same??
Not really sure how one can tell if it is a dual-element, do you know DADoES???
If needed I can post a pic of the back with the panel removed, just let me know...
Post# 540184 , Reply# 8   8/28/2011 at 15:55 (4,614 days old) by philcobendixduo (San Jose)
This control panel is JUST like the Imperial Set
philcobendixduo's profile picture
In my message (THREAD 35967) I inquired about this very machine - except ours did not have a window in the door like this one does.
Lighted panel - exactly the same.
Normal and Super speed selector with indicator light, buttons and timer dial - exactly the same.
Only difference seems to be no window in the one we had - just had a solid door.
Now if only this dryer had the matching washer! Did it have a window in the lid as well?
Post# 540186 , Reply# 9   8/28/2011 at 16:03 (4,614 days old) by Maytagbear (N.E. Ohio)
No, the washer did not
have a window in its lid. The fact that the washer did not have a window lid was one of my great disappointments in my childhood. We had the matching washer, and a Maytag dryer.
Lawrence/Maytagbear
Post# 540323 , Reply# 10   8/29/2011 at 03:34 (4,614 days old) by westingman123 ()
That's the dryer I grew up with, excepting the color and the window in the door. I would love to get me grubby hands on it! Is it electric? Please say yes.
Post# 540331 , Reply# 11   8/29/2011 at 06:02 (4,614 days old) by stainfighter (Columbia, SC)
Yes...Electric
it is electric...another member said they are very interested as well...as far as shipping I've had success with both Creighters & Freighters and U-Crate.
Post# 540342 , Reply# 12   8/29/2011 at 07:35 (4,614 days old) by akronman (Akron/Cleveland Ohio)
Interested, but
I have a 1960 RCA Imperial Mark 12 washer, not a perfect match but darn close. However, my budget just won't currently allow me to think about this one, no way.
Best of luck to the happy buyer!
Post# 540343 , Reply# 13   8/29/2011 at 07:42 (4,614 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
PINK WP ELECTRIC DRYER
combo52's profile picture
This dryer does [ or is supposed to have ] a dual wattage element, it would change from 5600 to 4600 watts when turned from super to normal. This dryer did not have an air-freshener [ no WP dryer ever did this as this was a KM only feature ] The opening next to the lint filter was where you poured in water for the clothes damping feature if you wanted to re-dampen clothing for ironing.
  The drum in this dryer is far closer to 5 cubic than four and these do a very good drying with no hot spots. But unfortunately all WP built dryers before 1966-7 with the direct drive blower use about 25% more power and are not as fast in the electric versions as the gas models could faster.
  I would have been silly to have put a window on a WP built TL washer, as they always steam up and get dirty with mineral and dirt and detergent deposits. WP always allowed you to have the lid open during everything except the spin cycle anyway, WPs were very well behaved washers and did not splash much. The only two TL washer manufactories that sometimes installed windows were Kelvinator and Frigidare, both splashers.
  This dryer was originally part of Bob OF Hollywoods collection and it is neat to see that it is still out there running. It is little newer than 1962, it is either a 1963 or 4 machine, if you post the model and serial #s we can tell for sure.I to hope someone here gets it.
Post# 540434 , Reply# 14   8/29/2011 at 17:13 (4,613 days old) by philcobendixduo (San Jose)
Drum Shot, Please!
Could you give us a shot of the drum interior?
Model plate would be handy too!
Thanks!
Post# 540495 , Reply# 15   8/29/2011 at 21:25 (4,613 days old) by stainfighter (Columbia, SC)
update requested, Model, S.N. ...
will have to take the interior drum shot tmw when I back the car out (be advised the drum shows LOTS/ 40+ years of use!). Here's today's pic of model and serial number...to the right is the piece of velcro used to keep the door closed.
Post# 540562 , Reply# 16   8/30/2011 at 08:07 (4,613 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
AGE OF WP DRYER
K models are 1963 models It was made in Marion Ohio where WP still makes all of its dryers.
Post# 540574 , Reply# 17   8/30/2011 at 09:30 (4,613 days old) by stainfighter (Columbia, SC)
...drum shot, requested...
so, anyone interested in adopting this pink gal???
Post# 540603 , Reply# 18   8/30/2011 at 12:57 (4,613 days old) by BrianL (Saddle Brook, New Jersey)
Somebody better be!
brianl's profile picture
I wish I could but shipping would be way off for me right now, and I couldn't afford to get it. I hope someone can take ownership soon.
Post# 540782 , Reply# 19   8/31/2011 at 06:07 (4,612 days old) by stainfighter (Columbia, SC)
"Reasonable" offer is?
I've gotten the usual responses...gee I wish it was closer, just can't do it right now...IF this were its twin (washer) it would have been already claimed.
Is $125 too much to ask???
Post# 541025 , Reply# 20   9/1/2011 at 09:02 (4,611 days old) by akronman (Akron/Cleveland Ohio)
Price is fine
$125 isn't bad, but it's the distance and freight costs that keep folks from buying. For many of us, one necessity is finding these great old machines NEARBY.
