Thread Number: 36271
Need Advice....Newer Frigidaire Dishwasher! |
Post# 540477 , Reply# 1   8/29/2011 at 20:03 (4,616 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 540500 , Reply# 2   8/29/2011 at 22:09 (4,616 days old) by stevet (West Melbourne, FL)   |   | |
IIRC, they have a plastic wash arm down below and you may want to re-inspect it and make sure that none of the seams on it have opened up causing the water to spray out horizontally and perhaps leak where you say it is. |
Post# 540504 , Reply# 3   8/29/2011 at 22:26 (4,616 days old) by Frigilux (The Minnesota Prairie)   |   | |
My similar-era TOL Frigidaire would do the same thing if a large pot or saucepan was angled toward the left front corner of the tub. The water was finding a trail to the outside. I'd open the machine and redistribute the offending item and the leak would disappear.
This only happened occasionally, mind you, not all the time. |
Post# 540965 , Reply# 4   8/31/2011 at 23:56 (4,614 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
If the wash arm is split it will leak due to unexpected water pressure against the door seal. I had this happen with, belive it or not a Hobart AM-14(the best dishwasher ever made). The upper wash arm split where the 2 pieces of stainless steel were crimped together. After I had it welded up the dishwasher did not spray out around the top of the doors and front panel.
