Thread Number: 36305
toploaders with KitchenAid badge |
Post# 540857 , Reply# 1   8/31/2011 at 13:00 (4,613 days old) by DADoES (TX, U.S. of A.)   |   | |
KitchenAid toploader pairs were Whirlpool-sourced direct-drive units with matching dryers. They generally had heftier components (motors, dryer belts & roller bearings & heating elements and porcelain tops). I have an early brochure (thanks MagicClean!) that indicates (if I'm interpreting the info correctly) a date of 11/1986, and another 1988. Washers (although not on all cycles on the early models) had stepped-spin, which started at lower speed for a couple mins then switched to higher speed. The final spin on Perm Press on my KAWE760 runs two mins of each motor speed low, med & high. Later (3-speed) models had an oversize agitator with a larger diameter base & larger fins and ran high agitation at the medium motor speed for less aggressive but effective action. The initial offering was only two model pairs ... one fully electronic, the other all pushbutton with rapid-advance timer. At least a couple collectors have featured pushbutton units in previous discussions. My KAWE760/KEYE760 pair was bought July 1992. The washer has a fiberglass sound insulation pad under the base. |
Post# 541143 , Reply# 4   9/2/2011 at 00:11 (4,612 days old) by PassatDoc (Orange County, California)   |   | |
washer controls |
Post# 541144 , Reply# 5   9/2/2011 at 00:12 (4,612 days old) by PassatDoc (Orange County, California)   |   | |
dryer controls |
Post# 541151 , Reply# 6   9/2/2011 at 01:52 (4,611 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
I know that as late as 1993 KitchenAid offered washers and dryers. The Whirlpool electronic set I have was offered as a KitchenAid model for a lot more $$$$. |
Post# 541163 , Reply# 7   9/2/2011 at 04:32 (4,611 days old) by DADoES (TX, U.S. of A.)   |   | |
Those are largely equivalent to my 760 pair. My washer has the same water level & temp settings, slightly different timer cycles. My dryer is the same. The model tags are on the back of washer's loading port under the rear edge of the lid, and at lower left inside on the dryer's loading port. Manufacture date is coded into the serial number. Note: I found years ago that washer/dryer pairs are best positioned NOT to be touching each other. Vibrations during operation over period of time will abrade the finish of the sides that are touching. |
Post# 541190 , Reply# 8   9/2/2011 at 08:44 (4,611 days old) by PassatDoc (Orange County, California)   |   | |
The pair is now in a somewhat dimly lit garage. I can bring a flashlight to look at the serial tags more closely and possibly decode the date from the serial number. My Frigidaire tags have a date of manufacture clearly listed, independent of the serial number. |
Post# 541473 , Reply# 9   9/3/2011 at 20:56 (4,610 days old) by dnastrau (Lords Valley, PA)   |   | |
KitchenAid made top-loading washers and dryers into the mid-2000s as far as I know. I bought a set in 2000 and still have the gas dryer. I sold the washer when we bought a Maytag Epic (rebaged Duet) in 2007 and wish that we had kept it. |
Post# 541478 , Reply# 10   9/3/2011 at 22:12 (4,610 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 541588 , Reply# 12   9/4/2011 at 10:51 (4,609 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 541610 , Reply# 14   9/4/2011 at 12:48 (4,609 days old) by limitededition ()   |   | |
Kitchenaid Ensembles' became Maytag Epics' Whirlpool cleared out te Ensembles at Costco as a special buy after they bought Maytag and discontinued Kitchenaid Laundry |
