Thread Number: 36495
Convert vented dryer to condenser type? |
Post# 543510 , Reply# 2   9/14/2011 at 00:54 (4,607 days old) by vintagekitchen ()   |   | |
I was assuming it would have to be a seperate unit next to the dryer. but it seems it should be possible, if one had the schematics of a condenser unit to go by... |
Post# 543520 , Reply# 5   9/14/2011 at 01:33 (4,607 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Here is a picture of an Asko condenser dryer I posted several times. I hope this helps you.
Post# 543523 , Reply# 7   9/14/2011 at 03:44 (4,607 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 543528 , Reply# 8   9/14/2011 at 06:56 (4,606 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I have already pulled together some of the equipment that I am going to use to convert a 1967 KM electric dryer [ with electronic moisture sensor ] to a heat pump clothes dryer. I am using the refrigeration system salvaged from one of these nearly useless portable AC units. There will be a separate unit that will be installed either next to or maybe above the dryer, if above I will not have to use a drain pump or water collection container as the water can just flow into a sink or nearby drain. I hope to work on this later this year. I will keep everyone posted about it when it is up and running John. |
