Thread Number: 36548
Replacement pump for wringer washer |
Post# 544229 , Reply# 1   9/18/2011 at 03:11 (4,602 days old) by ricky5050 (Durham Britain)   |   | |
Hello Lance, a small pump from a modern washer or drain pump from a dishwasher would work, you can buy them new off eBay but if your local recycling centre / tip has a collection of old washers waiting to be crushed try asking the foreman if you can dismantle one and take out the pump I paid about £5 for one which they were delighted with. Some tips have stopped you buying the rubbish now tho. You need a one of a older hotpoint or Hoover ideally ones without a front filter as these tend to be a filter pump unit . They are normally a sealed unit and very reliable. A plastic mount would screw to the inside of the washer and then it's only 2 wires (pos earth one as well) the only trouble may be the pipe sizes. Modern pumps are designed for the horrid grey plastic tube as an outlet and a fatter one from the drum. I'm not sure how you want to drain the machine ie straight from the new pump via a new plastic tube through a hole in the cabinet or pump it back to the tub ( I'm assuming it did that ) you may need to replace more pipework. Car accessory shops sell heater hoses in different diameters in metre lengths etc for trucks busses etc I got some at halfords.. To connect a large diameter to a smaller one I've even used a small circular shampoo bottle cut in half , one pipe on the screw thread where the top went one one the bottom, lots of bostik and some jubilee clips. If you do get a pump from an old auto washer collect the black rubber pipe from the drum as well as at least it will fit the pump and you may be able to marry the original hose to it. If the original pump doesnt leak the water could flow through that first if sizes make it easier
Good luck you have some beautiful machines Richard |
Post# 544237 , Reply# 2   9/18/2011 at 05:47 (4,602 days old) by lancethecook (Driffield England)   |   | |
Thanks for your advice, i have looked at ebay and dont really know what to search for , any idea where i can buy one new? Husband says if i buy another washer he will leave me. Im gonna miss him ! |
Post# 544238 , Reply# 3   9/18/2011 at 06:01 (4,602 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Lance
That made me laugh out loud :) try the search on the link below - I think you will need a complete assembly rather than one with the impellor exposed. Hope that helps Al CLICK HERE TO GO TO vacbear58's LINK on eBay |
Post# 544239 , Reply# 4   9/18/2011 at 06:03 (4,602 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
But I suspect this is the sort of thing you need - this particular one may well be re-listed
Post# 544240 , Reply# 5   9/18/2011 at 06:13 (4,602 days old) by ricky5050 (Durham Britain)   |   | |
Why would he leave you?? Lots of clean clothes , they are in the garage (with loads of room for more!!) and you keep a well stocked bar!!
Seeing all of the hoses hanong over the support bar reminds me of older washer vacs shops I used to get parts from as a kid. Sadly a lot gone now. The one Al pointed out is ideal and a great price. They used to be about £15 new 20 years ago from a shop. Richard |
Post# 544243 , Reply# 6   9/18/2011 at 06:26 (4,602 days old) by lancethecook (Driffield England)   |   | |
There are 3 more in the kitchen , three more at the other side of the garage and three more in the shed. But I NEED them all , as I keep telling him. |
Post# 544244 , Reply# 7   9/18/2011 at 06:29 (4,602 days old) by lancethecook (Driffield England)   |   | |
That is just what I want , I have emailed the seller and made him and offer. What would we do without you. |
Post# 544249 , Reply# 8   9/18/2011 at 07:21 (4,602 days old) by bellaboy ()   |   | |
hi i can send u one for free if u want |
Post# 544276 , Reply# 9   9/18/2011 at 10:13 (4,602 days old) by ozzie908 (Lincoln UK)   |   | |
