Thread Number: 36583
Twin tub won't drain/spin and emits loud sound HELP? |
Post# 544626 , Reply# 1   9/20/2011 at 02:11 (4,601 days old) by RONHIC (Canberra, Australia)   |   | |
I'd suggest that the pump may be blocked or the drain hose kinked.
At the very least, it is one of the first places I would start and if you have a fairly good amount of wind in you, get the sink end of the discharge hose and blow with all your might down it - that may be sufficient to help dislodge something...
...make sure there is a small amount of water in both the spin can and the wash tub so you can hear if anything bubbles.... |
Post# 544822 , Reply# 3   9/21/2011 at 02:49 (4,600 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 544876 , Reply# 6   9/21/2011 at 08:30 (4,600 days old) by gizmo (Victoria, Australia)   |   | |
Can you either record and post the noise, or at least describe it for us? A loud HUM is likely to be a jammed pump. A really loud angry BUZZZ is more likely to be a stuck / damaged solenoid (if it has one) or something more serious. |
