My combo won't tumble, but when I put it in the spin cycle, it spins at high speed. Belt okay. Motor okay. Fills and drains okay. Just won't tumble .. it tries to tumble, but gives just a tremble. Is is possible that this machine could have 2 capacitors? It looks like there are 2 (different sizes). Since they have stopped production of these, there are only limited parts available. Any suggestions? Or is it time to put her out to pasture?
Post# 548561 , Reply# 1   10/10/2011 at 19:18 (4,580 days old) by cfz2882(Belle Fourche,SD)
it could have seperate capacitors for spin and tumble if it has an induction motor
I don't know where Edgestar is made or if it is a rebadge,but a motor i got from
a haier combo did have seperate windings for the two speeds with seperate
capacitors...If there is a bad capacitor,and original is not easy to get,a
substitute capacitor of the same or close microfarad rating could be used-just make
sure voltage rating of the new capacitor is the same or higher than the original
Post# 548566 , Reply# 2   10/10/2011 at 19:49 (4,580 days old) by bayouboy(Metairie)
Thanks for the info ... I bought a new capacitor last week and it did not make a difference ... then, as I dug deeper, I found what looks like a second capacitor on the machine. I am going to try to swap that one out and see if it helps ... I just wasn't sure if i was possible to have 2 capacaitors on a machine. THANKS!!!
