Thread Number: 36892
What's wrong with this timer. |
Post# 548774 , Reply# 1   10/11/2011 at 20:32 (4,573 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 548788 , Reply# 2   10/11/2011 at 21:16 (4,573 days old) by coldspot66 (Plymouth, Mass)   |   | |
The timer shaft is usually on the other side of the timer????? |
Post# 548864 , Reply# 5   10/12/2011 at 07:51 (4,572 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The timer is CORRECTLY ASSEMBLED this is the way it was built. The timer is mounted directly to the inner door panel with SS screws that go through the porcelain inner door. MT used SS washers and rubber gaskets to pervent water from getting into the timer or leaking. This is the correct type timer for the MT WU 200 DWs I am not sure if it is correct for the WU201s, Barry do you have the correct part?. There is nothing wrong with that timer, I don't see why it looks odd to anyone as ALL the black Kingston timers used in MT, Nogre and Frigidare washers have terminals on both sides which includes the shaft side. This is just a one sided timer, similar timers were used in many clothes dryers, including current SQ dryers. And no you should not attempt to drill out the rivets and reassemble it the other way around. LOl. |
Post# 551451 , Reply# 7   10/23/2011 at 19:30 (4,561 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
