Thread Number: 36903
Speed Queen AWN432 - Fill Level |
Post# 548896   10/12/2011 at 10:46 (4,578 days old) by llmaytag (Southern California)   |   | |
So far I'm very happy with my new AWN432 Speed Queen. Very solid and quiet when it runs, close to my original Maytag DC. I miss the spin-sprays after the rinses, but not that big a deal.
Anyway, the reason why I write...in the manual it mentions that as of January 2009 all top loaders had to reduce fill levels. At the highest setting the level is still about four inches below the top of the tub, (up to the first row of holes on the agitator). I've heard that the commercial units have a switch inside the console that can raise the top fill level. Does anyone know if there is such a switch inside the console of the in-home models? Thanks! |
Post# 548976 , Reply# 2   10/12/2011 at 18:14 (4,578 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Here it is from thread #25261, reply #30, post #391435, from mtn1584
On the back panel of the washer there are three screws. One on the right, the left, and the middle. Unscrew these, you may need to use a tiny wrench to do so. Once unscrewed tilt the control panel foward and look for the water level switch. There is a screw on this switch. Turn it clockise 1/4 to raise the water level. Check the water level. If it is not to your liking drain the machine, and turn the screw another 1/4 turn until the height is to your preference. Unplug the machine while doing this adjustment. |
Post# 549025 , Reply# 3   10/12/2011 at 21:46 (4,577 days old) by llmaytag (Southern California)   |   | |
Post# 549176 , Reply# 4   10/13/2011 at 18:42 (4,577 days old) by cehalstead (Charleston, WV)   |   | |
I see the three screws you are talking about. These three screws are in cutouts, and there are two others that are not. Do these two need removed also? |
Post# 549995 , Reply# 6   10/17/2011 at 12:48 (4,573 days old) by cehalstead (Charleston, WV)   |   | |
I just modified my fill level...was much easier to do than I expected. Have a load in now...it's good to see the water where it should be...thanks for all of your help... |
Post# 550266 , Reply# 7   10/18/2011 at 18:22 (4,572 days old) by yogitunes (New Jersey)   |   | |
