Thread Number: 3706
Dryer leaves rust streaks on clothes |
Post# 90149 , Reply# 1   10/22/2005 at 20:11 (6,752 days old) by coldspot66 (Plymouth, Mass)   |   | |
Check the front felt seal that the front of the drum rides on. The plastic bearing surface wears down and causes a gap between the edge of the drum and the felt seal.If you can lift the top then you will see the drum seal glued to the front panel. Hope this helps! |
