Thread Number: 37105
Ebay Unimatic find |
Post# 551953   10/26/2011 at 06:00 (4,565 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Vintage GM Frigidaire Washer Spin Cage Base 5433466 WO-65 UnimaticCLICK HERE TO GO TO akronman's LINK on eBay |
Post# 551963 , Reply# 1   10/26/2011 at 07:19 (4,564 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 552024 , Reply# 2   10/26/2011 at 13:10 (4,564 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 552028 , Reply# 3   10/26/2011 at 13:17 (4,564 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 552033 , Reply# 4   10/26/2011 at 13:46 (4,564 days old) by Unimatic1140 (Minneapolis)   |   | |
Really, this heavy chunk of cast breaks?
No you could shoot a bullet through many of those Unimatic mechanism, parts and they wouldn't flinch. John was being facetious. The clutch torque spring and upper water seal are the only vulnerable parts I've found in that mechanism. Sometimes the pump impeller screw gets loose over the years causing the fan to rattle, but that is a simple fix of tightening the screw. |
Post# 552037 , Reply# 5   10/26/2011 at 14:29 (4,564 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 552079 , Reply# 6   10/26/2011 at 16:21 (4,564 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 552092 , Reply# 7   10/26/2011 at 17:28 (4,564 days old) by goatfarmer (South Bend, home of Champions)   |   | |
