Thread Number: 37167
33019L Hoovermatic.... |
Post# 552790   10/30/2011 at 13:01 (4,533 days old) by keymatic (London / UK)   |   | |
Hi Guys,
Recently picked up a 33019L Hoovermatic, however someone has decided to take out the timer and wired it so that the pulsator comes on when you turn the thermostate control to "Motor" I had a timer and have decided to put it in however not too sure about the wiring..does anyone have a wiring diagram for a 33019L ???? Any help much appreciated. Regards Keith |
Post# 552795 , Reply# 1   10/30/2011 at 14:02 (4,533 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Keith
I presume that the time is mechanically driven (I have some recollection that it is driven by the pulsator motor) so surely its just a matter of taking the wire off its existing terminal and putting it on the timer, with a new wire running from the now vacant position from the thermostat to the "other side" of the timer Congratulations on gettin a 3309, look forward to seeing pictures Al |
Post# 552806 , Reply# 2   10/30/2011 at 14:45 (4,533 days old) by aquarius8000 ()   |   | |
Hi Keith! nice find! If you like that you may like this... CLICK HERE TO GO TO aquarius8000's LINK on eBay |
Post# 552819 , Reply# 3   10/30/2011 at 15:35 (4,533 days old) by keymatic (London / UK)   |   | |
Hi Al,
Thanks for your message, unfortunately the 3309L didnt have any wiring to the timer, so i have taken the old motor out complete with part of the drive on the end and put a complete timer and motor in from a 3301L i had a few years ago, however off the timer box there are 3 connectors, one to the wash motor, but i am not sure where the other two wires go to.. Pics to follow soon !! Keith |
Post# 553570 , Reply# 5   11/2/2011 at 08:28 (4,530 days old) by keymatic (London / UK)   |   | |
Hi James,
Thanks for the information, I will have a play aropund the weekend..I was only confused because the timer i took out of a 3301L had 3 wires coming off of it, 2 that went to the thermostat and 1 that goes to the wash motor, however whent he 3309L come along the wiring configuration must have changed to 2 wires, 1 to the thermostat and 1 to the wash motor. I will post an update. Cheers Keith |
