Thread Number: 37272
Adding water to your FL --Anyone Tried this? |
Post# 554199 , Reply# 2   11/5/2011 at 02:29 (4,548 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 554462 , Reply# 5   11/6/2011 at 07:24 (4,547 days old) by mark_wpduet (Lexington KY)   |   | |
On my Duet from 2004
I adjusted the screw and I too had the issue of either default or water WAY too high. I kept playing with it and finally got it to where I think it uses a couple more gallons than it did before, but it took me a while to get that. It was so hard to find the happy medium, even with the ever so slight adjustment of the screw......I did this maybe 4 yrs ago. I haven't touched it since I got it to about where I want it. Not exactly where I wanted it......but almost |
Post# 554482 , Reply# 6   11/6/2011 at 09:29 (4,547 days old) by rp2813 (Sannazay)   |   | |
Martin (yogitunes) posted something about a year ago with pictures of a successful system he rigged up on his Frigidaire. It involved a 16 to 20 oz. plastic soda or water bottle, a "heavy duty" balloon to use as a bladder type of arrangement, a rubber band and some tubing. I didn't feel comfortable tacking the project so for loads that require more water I'm still adding it via the detergent dispenser using a 100 oz. Tide bottle.
I never saw any need to add water to my Duet HT, but this Affinity I have now is really skimpy with the water. Our king size mattress pad would never receive a proper and effective washing if I didn't intervene with three or four Tide bottles' worth of additional water. |
Post# 555672 , Reply# 8   11/10/2011 at 12:53 (4,542 days old) by Autowasherfreak ()   |   | |
When I had my Frigidaire Gallery front loader I would add 1-3 gallons of water through the detergent drawer, it helped a lot on the larger loads. |
Post# 555852 , Reply# 9   11/11/2011 at 03:15 (4,542 days old) by laundromat (Hilo, Hawaii)   |   | |
My Affinities and Mieles I can add as much water as needed (desired) with no problem by using a Tide liquid bottle and pouring the water through their dispenser trays. However, as Tom has pointed out, the LGs will not allow ANY additional water and will throw it back up via pump out and restart the program.Sort of similar to the current commercial front loaders with the emergency shut down button. My earlier Frigidaire, Kitchenaid, Whirlpool and Kenmore washers had the adjustable screws on the pressure switch. Those I had set so the water would fill completely just beneath the boot enough to still be able to open the door without the water gushing out.It really made a difference in not only the drama but also the effect it had on getting my wash super clean and super rinsed.
Post# 556253 , Reply# 11   11/13/2011 at 08:01 (4,540 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
well in my toughs i do not see the point in doing this if you went more water you can always buy a top load washer and use a top load washer instead of a front load washer. So for me that shows that a top load washer do a better job in washing clothes than a front load du to the fact that the clothes are submerge in water and that the agitator sends the suds through the fabric to wash the clothes thats my 2 cents in this.
