Thread Number: 37288
Enameled washer outer tub help. |
Post# 554486 , Reply# 1   11/6/2011 at 09:42 (4,546 days old) by bendixdeluxe ()   |   | |
The heater seal end |
Post# 554487 , Reply# 2   11/6/2011 at 09:43 (4,546 days old) by bendixdeluxe ()   |   | |
The whole thing |
Post# 554798 , Reply# 3   11/7/2011 at 14:00 (4,545 days old) by ricky5050 (Durham Britain)   |   | |
Hi there years ago I repaired a servis outer tub, sand it down and use something like finnigans number 1 primer then a couple of coats of hammerrite , it should last a long while. Wow you must have hard water down there , ours is so soft you never get any scale in the kettle never mind washer !
Richard |
Post# 554799 , Reply# 4   11/7/2011 at 14:12 (4,545 days old) by Docker (Cape Town, South Africa)   |   | |
Mathew Take a look at this pic of my Indesit 092. I gave the area a light sanding, treated it with Kurust and finished off with Pratley's Putty. I then sanded the putty to the shape of the drum. You can then apply some Hammerite, although I never bother with that. |
Post# 554998 , Reply# 7   11/8/2011 at 06:00 (4,544 days old) by SeamusUK (Dover Kent UK)   |   | |
