Thread Number: 37373
Maytag washer question |
Post# 555581   11/10/2011 at 03:44 (4,544 days old) by doug (West Virgina)   |   | |
Post# 555582 , Reply# 1   11/10/2011 at 03:46 (4,544 days old) by doug (West Virgina)   |   | |
Post# 555613 , Reply# 2   11/10/2011 at 07:50 (4,544 days old) by DirectDriveDave ()   |   | |
at what part does the squeal happen? |
Post# 555626 , Reply# 3   11/10/2011 at 08:42 (4,544 days old) by yogitunes (New Jersey)   |   | |
Post# 555635 , Reply# 4   11/10/2011 at 09:40 (4,544 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 555637 , Reply# 5   11/10/2011 at 09:44 (4,544 days old) by yogitunes (New Jersey)   |   | |
Post# 555653 , Reply# 6   11/10/2011 at 11:22 (4,544 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 555783 , Reply# 7   11/10/2011 at 21:14 (4,543 days old) by doug (West Virgina)   |   | |
Post# 555784 , Reply# 8   11/10/2011 at 21:17 (4,543 days old) by DirectDriveDave ()   |   | |
that sounds like it could be the tub brake slipping, bit i'm not fully sure. |
Post# 555802 , Reply# 9   11/10/2011 at 22:48 (4,543 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 555805 , Reply# 10   11/10/2011 at 22:59 (4,543 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
In the middle of the wash cycle could be slipping belts, bad pump, or transmission starting to size up. Try flipping the pump belt off and letting the machine agitate for ten to twenty minutes and see if you still have the noise, this will tell you if it involves the pump and its belt or the main drive belt and possibility the transmission, it could also be the brake if the tub is indexing even slightly in which case the sound will not hurt anything. |
Post# 555851 , Reply# 11   11/11/2011 at 03:13 (4,543 days old) by doug (West Virgina)   |   | |
