Thread Number: 37455
Please help! |
Post# 556790 , Reply# 1   11/15/2011 at 12:28 (4,538 days old) by jade (Oregon)   |   | |
never mind I figured it out! |
Post# 556794 , Reply# 2   11/15/2011 at 12:51 (4,538 days old) by mickeyd (Hamburg NY)   |   | |
Post# 556805 , Reply# 3   11/15/2011 at 14:07 (4,538 days old) by rp2813 (Sannazay)   |   | |
Post# 556836 , Reply# 5   11/15/2011 at 15:52 (4,538 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 556841 , Reply# 6   11/15/2011 at 16:09 (4,538 days old) by mickeyd (Hamburg NY)   |   | |
Look at me asking if it has a pump when you already said it did! Every wringer and many automatics drain out when the hose is on the floor. So glad you like your wringer washer. Many people here have one or more and love them.
When I read you earlier, I said nothing because I couldn't figure out what was going on. Then when you said you solved it, I wrote without re-reading your question. I'm the one who's dumb.
You've probably figured out that gravity draining machines operate by throwing the hose on the floor. Maytag is famous for them and sold millions of them. Could be wrong about the millions. Have to ask Ben or Geoff. Pictures would be sweet. |
Post# 556859 , Reply# 7   11/15/2011 at 17:59 (4,538 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Welcome Jade.....actually almost every machine (automatic or wringer) and also dishwashers that have the hose exit placed under the tub throws water if the hose is on the floor, some automatics models have the exit upper to the tub level and this does not happend .....you do not have to feel stupid at all! You tought it had a kind of "thing" that blocks the water in the tub if the pump is not on am I right? But you've now learned that no washer have this thing....we're humans and we learn also by our mistakes! Glad, very glad you're happy with it!
Pics are welcome if you can. |
Post# 557027 , Reply# 9   11/16/2011 at 12:13 (4,537 days old) by turquoisedude (.)   |   | |
Post# 557052 , Reply# 10   11/16/2011 at 13:46 (4,537 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 557614 , Reply# 12   11/18/2011 at 15:17 (4,535 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
That's probably cuz their hose "exit" was placed higher to the tub and not cuz they have a valve, like my filterflo......think it is so, as I guess all filterflos have the same kind of pump from 60s to the lasts and they usually does not have a valve.....but I could also be wrong.
Yes pump is quite different than the older whirlpool and kenmore, I'll post a pic, I've replaced mine about 4 months ago. Pumps are directly connected to the motor. They just have a propeller inside, 2 propellers, one smaller runs in one direction to pump recirculation water to the lint filter pan on (washing direction) , and the other one, the bigger, pumps water out when is on spin direction.... |
Post# 557615 , Reply# 13   11/18/2011 at 15:18 (4,535 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
Post# 558979 , Reply# 14   11/24/2011 at 15:14 (4,529 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Now I'm curious to the was the 4 port pump on a GE and or Hotpoint works
I know 1 port is for the filterflo rimflo system 1 port is to the tub drain 1 port is to the drain hose to drain the washer But I cannot figure out the 4th port I figures that the water goes from the tub drain to the pump to the filterflo rimflo Then when the washer drains the water goes from the tub drain to the pump to the drain hose Maybe I'm missing a hose that is there somewhere that hooks to the 4th pump port |
Post# 558981 , Reply# 15   11/24/2011 at 15:37 (4,529 days old) by yogitunes (New Jersey)   |   | |
from what I can remember back of all models of FF, its just a matter of inside the drain hose loops up to the top of the cabinet and then down to the connection for the drain hose......no anti siphon device included......laying the drain hose on the floor, the machine would not just empty out, but if the machine was put into spin for a few seconds to get the water going, and then stopped, the water would continue to flow, until the tub was empty or the drain hose raised higher than the machine....this design also eliminated the cavitation noise of the pump running in reverse.....
the four port pump----the top/smaller ports it for the filter flo...one in, and one out(clockwise)........same goes for the drain/larger, one in and one out(counter-clockwise)......the motor reversing decided if it should filter with the agitation...or drain with the spin.....a simple design |
Post# 558990 , Reply# 16   11/24/2011 at 17:43 (4,529 days old) by kenmoreguy89 (Valenza Piemonte, Italy- Soon to be US immigrant.)   |   | |
The're 2 separate chambers in the pump unit, every chambers have it's own propeller, every chamber has an IN and an OUT, every propeller is shaped inside toward the direction will have to pump, filterflo water propeller will need to be shaped to pump water out turning in a clockwise direction, the drain propeller to pump out in counter clockwise direction, yes it's a very simple design but at the same time very smart, GE in fact followed this kind of simple and smart designs for all the washer itself and if you'll ever get in hand a GE you'll undesrtand of what I'm talking about, I love the mechanical scheme to wich they're built, you know, functional, strong, ingenious and simple at the same time, a lot of mechanic features without too many fripperies.......
