Thread Number: 37465
Kenmore Thread! |
Post# 557090   11/16/2011 at 18:20 (4,536 days old) by lebron (Minnesota)   |   | |
Post# 557092 , Reply# 1   11/16/2011 at 18:22 (4,536 days old) by lebron (Minnesota)   |   | |
Post# 557106 , Reply# 2   11/16/2011 at 19:17 (4,536 days old) by mrb627 (Buford, GA)   |   | |
Post# 557114 , Reply# 3   11/16/2011 at 19:59 (4,536 days old) by peteski50 (New York)   |   | |
Post# 557122 , Reply# 4   11/16/2011 at 21:16 (4,536 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557130 , Reply# 5   11/16/2011 at 22:42 (4,535 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 557133 , Reply# 6   11/16/2011 at 22:55 (4,535 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
There was yet another Kenmore as Pic Of The Day not too long ago--this one a Top O' The Line!
With the Triple-Dispenser & even available in "Tawny Gold", in addition to the White/Avocado/Copper-standard available colors & White w/ Suds Saver! Florescent Light, Off-Balance Switch & Alarm, Self Cleaning Lint Filter--And All...!!!!!! -- Dave |
Post# 557139 , Reply# 7   11/16/2011 at 23:29 (4,535 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 557142 , Reply# 8   11/16/2011 at 23:32 (4,535 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Gas, also a "Ninety-series"... Even an electronic moisture sensor & a "discovered"-drum light, after thinking it was without:
Don't like how the thing starts & stops after the Auto Dry cycle, though; to me not "completely" automatic if I need to run to the basement to shut off the timer after it gets done drying...! -- Dave |
Post# 557147 , Reply# 10   11/16/2011 at 23:47 (4,535 days old) by DADoES (TX, U.S. of A.)   |   | |
Don't like how the thing starts & stops after the Auto Dry cycle, though; to me not "completely" automatic if I need to run to the basement to shut off the timer after it gets done drying...!That's not a malfunction, the machine is running as intended. The Wrinkle Guard feature tumbles (without heat) for ~30 seconds every 5 mins for a period of time if the load isn't removed immediately to ward-off wrinkles that may occur if the items were left sitting stationary in the drum. It will shut off after the intermittent tumble period runs out ... usually between 45 mins to 2.5 hours depending on the machine's configuration. I have a similar Kenmore 90 washer in almond (but with a replacement white lid), same controls & settings except 4 water levels instead of infinite. An agitator-mounted softener should have been included, probably lost or tossed out by the previous owners. The friend who gave my machine to me didn't have a dispenser with it but I bought one so as have it fully outfitted, cost $6. |
Post# 557149 , Reply# 11   11/16/2011 at 23:58 (4,535 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 557150 , Reply# 12   11/16/2011 at 23:59 (4,535 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 557151 , Reply# 13   11/17/2011 at 00:05 (4,535 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 557153 , Reply# 14   11/17/2011 at 00:48 (4,535 days old) by lebron (Minnesota)   |   | |
Post# 557168 , Reply# 15   11/17/2011 at 04:07 (4,535 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 557180 , Reply# 16   11/17/2011 at 06:36 (4,535 days old) by mrb627 (Buford, GA)   |   | |
Post# 557229 , Reply# 17   11/17/2011 at 11:47 (4,535 days old) by rickr (.)   |   | |
Post# 557231 , Reply# 18   11/17/2011 at 11:48 (4,535 days old) by rickr (.)   |   | |
Post# 557244 , Reply# 19   11/17/2011 at 12:20 (4,535 days old) by mickeyd (Hamburg NY)   |   | |
Post# 557246 , Reply# 20   11/17/2011 at 12:23 (4,535 days old) by mickeyd (Hamburg NY)   |   | |
Post# 557316 , Reply# 21   11/17/2011 at 15:13 (4,535 days old) by washerlover (The Big Island, Hawai’i)   |   | |
Post# 557331 , Reply# 22   11/17/2011 at 16:00 (4,535 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 557338 , Reply# 23   11/17/2011 at 16:52 (4,535 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
The only Kenmore set in my Collection. 1986 Electronic Limited Edition. This is the first production run of a 27" DD electronic control machine. An Intersting fact I learned from Gordon when corresponding about the set when I bought it is that this machine was made before his 86 Electronic BD. The washer is all original and the dryer has only had a PCB board replaced.
Post# 557339 , Reply# 24   11/17/2011 at 17:00 (4,535 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 557341 , Reply# 25   11/17/2011 at 17:16 (4,535 days old) by yogitunes (New Jersey)   |   | |
the Limiteds are beautiful......
I had the 1988 and the 1995 versions........ what I liked about the 88 was that you could select a cycle, press start, after the dispenser minute, the tub would fill.....hit the water level to the lowest, once agitation starts, press the water level again to raise it, the washer will continue to agitate while filling until full.....this was great for a concentrate of detergent scrubbing, like socks, as it fills add more laundry..... the 95 would not allow this, but I did like it for the "asterisk" that allowed you to override the detergent dispense....... also the dryer with the 2 buttons, for the five second tumble to bring the clothes to the front for unloading.....your also missing the clothes hanger rack! |
Post# 557345 , Reply# 26   11/17/2011 at 17:34 (4,535 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 557346 , Reply# 27   11/17/2011 at 17:34 (4,535 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 557348 , Reply# 29   11/17/2011 at 17:37 (4,535 days old) by MaytagA710 ()   |   | |
That last machine was Early to Mid 80s. This is a Mid 80s to end of production for BD. I believe these were produced in Canada up until 1990ish, thats when they changed the control panel design. |
Post# 557349 , Reply# 30   11/17/2011 at 17:38 (4,535 days old) by MaytagA710 ()   |   | |
This would be a mid to late 70s machine here. BOL. |
Post# 557350 , Reply# 31   11/17/2011 at 17:40 (4,535 days old) by pdub (Portland, Oregon)   |   | |
Post# 557395 , Reply# 32   11/17/2011 at 20:41 (4,535 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 557396 , Reply# 33   11/17/2011 at 20:42 (4,535 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 557397 , Reply# 34   11/17/2011 at 20:45 (4,535 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 557398 , Reply# 35   11/17/2011 at 20:46 (4,535 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 557400 , Reply# 36   11/17/2011 at 20:48 (4,535 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 557404 , Reply# 37   11/17/2011 at 20:51 (4,535 days old) by supremewhirlpol ()   |   | |
Here's part of a Kenmore. |
Post# 557405 , Reply# 38   11/17/2011 at 20:53 (4,535 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 557406 , Reply# 39   11/17/2011 at 20:53 (4,535 days old) by supremewhirlpol ()   |   | |
Here's part of a dead Calypso |
Post# 557408 , Reply# 40   11/17/2011 at 20:54 (4,535 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 557409 , Reply# 41   11/17/2011 at 20:56 (4,535 days old) by supremewhirlpol ()   |   | |
gone! |
Post# 557411 , Reply# 42   11/17/2011 at 20:58 (4,535 days old) by peteski50 (New York)   |   | |
Post# 557412 , Reply# 43   11/17/2011 at 20:59 (4,535 days old) by peteski50 (New York)   |   | |
Post# 557413 , Reply# 44   11/17/2011 at 21:00 (4,535 days old) by peteski50 (New York)   |   | |
Post# 557414 , Reply# 45   11/17/2011 at 21:01 (4,535 days old) by supremewhirlpol ()   |   | |
13/15 dead, will be getting some mods soon. |
Post# 557415 , Reply# 46   11/17/2011 at 21:02 (4,535 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 557416 , Reply# 47   11/17/2011 at 21:03 (4,535 days old) by appnut (TX)   |   | |
Post# 557417 , Reply# 48   11/17/2011 at 21:04 (4,535 days old) by Northwesty (Renton, WA)   |   | |
My daily drivers, 1951 Kenmores and I have another set in the garage. |
Post# 557421 , Reply# 49   11/17/2011 at 21:24 (4,535 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 557422 , Reply# 50   11/17/2011 at 21:29 (4,535 days old) by appnut (TX)   |   | |
Post# 557469 , Reply# 51   11/17/2011 at 23:55 (4,534 days old) by 70series ( Connecticut.)   |   | |
The washer posted in Reply # 15 above is the exact Kenmore model my parents got in 1999. The only difference is theirs was white. I loved that washer. I love all of the photos. This is definitely a fun thread. Have a good one, James |
Post# 557507 , Reply# 52   11/18/2011 at 05:55 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Hey Jed,
THANKS for the awesome comment. I'll get a bunch of pics added to this thread for sure. I have some great ones that are on my computer at work (which may have to wait until Monday) but for now, here's a few. First, no thread with my washers would be complete without the master washer that started me in rebuilding and now collecting - my 1979 model Kenmore 80 series. Bought for my sister used in 1989, AND now residing in my laundry room after being the first washer I restored in 2008 after finding AW.org. Pictured here in my garage at the second set of connections I have, James and I simply refer to this machine as the "'79-eighty" |
Post# 557510 , Reply# 53   11/18/2011 at 06:01 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557512 , Reply# 54   11/18/2011 at 06:03 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Also purchased new in 1986, and is the newest belt-drive washer that I am aware of in our wonderful club. I adore this machine. It is out of service as it needs centerpost bearing seals, but I'd have to disconnect the '79 to put it back into use, so I'm in no hurry (no way it's going in the garage).
Post# 557513 , Reply# 55   11/18/2011 at 06:05 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
But here's a lid open shot.
I'm thinking of having a second washer box added to the laundry room so I can have both the 79 and this machine connected inside the house. PS - don't ask about the nick in the console - I shuddered for weeks when I did that....am going to have a buddy at Dent Wizard fix it. |
Post# 557516 , Reply# 56   11/18/2011 at 06:15 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557517 , Reply# 57   11/18/2011 at 06:16 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557518 , Reply# 58   11/18/2011 at 06:18 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557519 , Reply# 59   11/18/2011 at 06:20 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557520 , Reply# 60   11/18/2011 at 06:21 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557521 , Reply# 61   11/18/2011 at 06:25 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Totally rebuilt in 1995 from a complete piece of sheet (aka junk), it was only 10 years old, but had been left outside in a field for long enough to have ruined the motor and basket drive. The trans was disgusting (it had been leaking water through the center for a long time), and the pump and timer were locked-up. Totally worthless to anyone but me, I rebuilt it using only a new pump. Everything else I pieced together using parts scavenged, etc. The timer came from my Mom's washer (very similar) and the original, which I spliced together using parts from both. I put it in service in 1997 and I'd bet it has done over 1,000 loads since then, easily.
This post was last edited 11/18/2011 at 06:56 |
Post# 557523 , Reply# 62   11/18/2011 at 06:31 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
My 1993 Kenmore DD 70-series.
Hardly used, I did about 200 loads with it from 1993-1997, then it was out of service completely until 2006, when again taken out of service when the 79-eighty took over inside the house. This machine was a gift from the store where my buddy and I were able to help Sears decommission their compactor (Yay!) by taking all their haul-backs. As you can see, it has some serious dents from a mishap during delivery. Instead of it going on the scratch-and dent floor (in this case "smash and bash" would have been more appropriate), Sears gave it to me so I could learn the nuiances of DD washing so I'd be prepared for the day when BDs were no longer around. Blasphemy! I do love the machine though. This pic hides the dent over the timer knob, which I smoothed out, along with a new lid, when I got it home. |
Post# 557524 , Reply# 63   11/18/2011 at 06:36 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
This is a 1972 Kenmore 200. I believe the most BOL washer for 1972, this is a fairly decent machine really, but the early to mid-70s was a period of feature laden models for Kenmore.
1-speed, three bizarre cycles (Normal, Short, and Pre-Soak), two water levels, it has a straight vane agitator like my '79 model, no filter, and no porcelain on the top. This washer was found by Austin Wilder in Houston and he wanted me to have it. I am keeping it near. Not a high-mileage washer either, as Austin found a sock in the pump which had clogged the machine many years earlier and prevented further use. |
Post# 557526 , Reply# 64   11/18/2011 at 06:39 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Here is something totally cool. My never used 1962 Kenmore 70 dryer.
Acquired this summer, it had been in a Connecticut basement since delivery. The house it was in was being renovated by a flipper/realtor. She told me there were clothes lines everywhere inside and out, which explains the non-use of the dryer. I expected it to be nice (she said Mint) but I did not expect it to be only dusty, but totally devoid of any lint or any signs of ever being used!!!!!!!!!! |
Post# 557527 , Reply# 65   11/18/2011 at 06:42 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
A 1963 Kenmore 700, just like the washer in Robert's Kenmore "see it wash".
Acquired from Bygted, this is my only Turquiose washer. It doesn't look like there are a lot of miles on this washer, but it's loaded with detergent residue. Fun stuff to clean one day... I am looking for a 'Filtering' light for it if anyone knows of one. Also in the shot is a 1973 Kenmore 60-series. This washer is in remarkable condition, courtesy of my washer pimp in Arizona. It's totally unrusted, anywhere, and like new, just dirty. Seems to need a motor. This was the first gold washer in my collection. |
Post# 557530 , Reply# 66   11/18/2011 at 06:48 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557600 , Reply# 67   11/18/2011 at 13:10 (4,534 days old) by jaxsunst ()   |   | |
What year did they change Kenmore timers to pull out to start instead of push in? |
Post# 557601 , Reply# 68   11/18/2011 at 13:18 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 557602 , Reply# 69   11/18/2011 at 13:22 (4,534 days old) by jaxsunst ()   |   | |
Two pics up, I had the Harvest Gold set that looks like the one next to the turquiose washer. They were ugly, but it was the best set I ever had. It had the push to start timer. |
Post# 557624 , Reply# 70   11/18/2011 at 16:51 (4,534 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
There were A LOT of the 1972/1975 era plastic top washers like the Gold one I have. These were very good sellers for Sears. I sold several of those in White in the 90s, and had one in Avocado recently.
There was at least 7 different variations on that model, from BOL-ish 500 series with timer set temps, to a 60-series with many bells (not so many whistles) and even a Roto-Swirl. One of the models was an 18lb. machine with the large capacity Roto-Swirl. I'd love to find one of those. |
Post# 557712 , Reply# 71   11/18/2011 at 23:51 (4,533 days old) by 70series ( Connecticut.)   |   | |
Gordon, the garage is looking great as always. Just like a Sears store from the 70s/80s. Annie is one of my favorites too along with the GB, and the 79-eighty. Glad you posted the 86 to the site, and it is great to see Lady amongst others. Looking forward to more, James |
Post# 557842 , Reply# 72   11/19/2011 at 14:12 (4,533 days old) by peteski50 (New York)   |   | |
Post# 557845 , Reply# 73   11/19/2011 at 14:20 (4,533 days old) by peteski50 (New York)   |   | |
Post# 557934 , Reply# 74   11/20/2011 at 00:58 (4,532 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 557989 , Reply# 75   11/20/2011 at 08:00 (4,532 days old) by jaxsunst ()   |   | |
Kenmoreguy64: Mine had all the cycles, 5 temp choices, three water level choices. If I recall, it had the straight vein agitator and a huge softner dispenser. I moved out of state and had to sell them, broke my heart. |
Post# 558008 , Reply# 76   11/20/2011 at 09:30 (4,532 days old) by bravos4me ()   |   | |
Post# 558026 , Reply# 77   11/20/2011 at 10:24 (4,532 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 558186 , Reply# 79   11/20/2011 at 22:02 (4,531 days old) by chaskelljr2 (Washington, D. C.)   |   | |
My childhood Dryer (the 1975 "All-American" Dryer). --Charles-- |
Post# 558234 , Reply# 88   11/21/2011 at 06:06 (4,531 days old) by appnut (TX)   |   | |
There was actually more changes in the sequence than you describe above. What you describe as the 1st was more actually the 2nd process. The first being a series high-speed drains and then cold water fills. There was no agitation inbetween any of the drains and fills. This was the sequence for the very first models with the wasn-n-wear cycle that was introduced in 1958. Your "2nd process" was actually the last version. I'm not sure exactly when this came into existence. However, I do asssociate it with the large capacity models that came out in 1975 or 1976 when they also did the major panel redesign and put the timer in the middle of the panel. Gordon or Tom might be able to shed some light on this. Makes me wonder if the 18 pound capacity Kenmore & Whirlpools of the late 1960s also did the cool-down with the agitate while filling or simply just filled iwth water and hten agitated like its future sibbilngs that were the large capacity. |
Post# 558259 , Reply# 89   11/21/2011 at 09:41 (4,531 days old) by bajaespuma (Connecticut)   |   | |
Some of those machines are just fab u lus.
Although I still have to admit some of the Kenmore BOL's are so ugly, in the words of Moms Mabley, they hurt my feelings.
Maybe someday the Kenmore gods will take pity and send me one like yours, Tuttle. Just love those color-keyed buttons, those awesome dispensers and that lovely white porcelain tub with its over-the-top out-of-control nut job agitator. Oh, and I always forget the garage-door control panel covers that make absolutely no sense at all unless the engineers at Kenpool were trying to outfit their appliances with an attitude of modesty. |
Post# 558278 , Reply# 90   11/21/2011 at 10:59 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558279 , Reply# 91   11/21/2011 at 11:00 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558280 , Reply# 92   11/21/2011 at 11:01 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558281 , Reply# 93   11/21/2011 at 11:02 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558282 , Reply# 94   11/21/2011 at 11:02 (4,531 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 558283 , Reply# 95   11/21/2011 at 11:03 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558284 , Reply# 96   11/21/2011 at 11:03 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558285 , Reply# 97   11/21/2011 at 11:04 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558286 , Reply# 98   11/21/2011 at 11:06 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558287 , Reply# 99   11/21/2011 at 11:08 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558288 , Reply# 100   11/21/2011 at 11:09 (4,531 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 558343 , Reply# 101   11/21/2011 at 14:58 (4,531 days old) by StrongEnough78 (California)   |   | |
Post# 558388 , Reply# 104   11/21/2011 at 19:31 (4,531 days old) by bajaespuma (Connecticut)   |   | |
Post# 558389 , Reply# 105   11/21/2011 at 19:40 (4,531 days old) by bajaespuma (Connecticut)   |   | |
Post# 558425 , Reply# 106   11/21/2011 at 22:33 (4,530 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
In your words "just to be clear" Ken, I'm not sure where in here anywhere, in all these replies, where anyone querried you as to what you find offensive! In fact, I am sure nobody asked....
If you want to start a GE thread where everyone can explore all the wonderful things GE, by all means... This one however is for those who enjoy Kenmores. For those such as yourself who don't, be a grown-up and leave your comments unsaid. Gordon |
Post# 558431 , Reply# 108   11/21/2011 at 23:37 (4,530 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
A few questions for you Ken:
1. About the "damn stupid lids". What is so stupid about them? OK, they don't lay flat, but so what? Do they really need to? Is the lid somehow in your way when you are adding or removing laundry from the machine? How would it be "useful" if it lays flat? Why is it such an issue?
2. The agitator. What is your issue with this one? Is it only the color? Or maybe the shape? Who the hell cares WHAT the agitator looks like? As long as it does it's job and gets your clothes clean, what difference does it make? We are not talking about a piece of art here, it's a machine with a specific purpose... and that is to get your dirty laundry clean. Or am I missing the point here?
3. How does the black control panel "offend" you? Do you see unpleasant nude images when you look at it? Do you see curse words instead of "Hot, Warm, Cold, Normal or Delicate"? Is it an issue of prejudice since the panel is black?
So you don't miss understand MY intent, I am only trying to understand your point of view and why you would post such negative comments in a thread that is otherwise very positive.
Kevin This post was last edited 11/21/2011 at 23:58 |
Post# 558436 , Reply# 109   11/22/2011 at 00:10 (4,530 days old) by powerfin64 (Yakima, Washington)   |   | |
Post# 558448 , Reply# 110   11/22/2011 at 04:06 (4,530 days old) by Frigilux (The Minnesota Prairie)   |   | |
Yay for all the Kenmores! I took them for granted as I grew up with one (1960 pushbutton Model 80) and I always had acute Frigidaire envy. Now I appreciate the old belt drives much more.
Speaking of the pushbutton models---I know there are 1959 and '60 pushbutton models in the AW family; any chance we can get photos of them, guys? |
Post# 558496 , Reply# 112   11/22/2011 at 08:19 (4,530 days old) by rll70sman (Hastings, Minnesota)   |   | |
Thanks for speaking out against those who always try to sabotage our beloved Kenmore memories! I'm thoroughly enjoying this thread! Rob |
Post# 558619 , Reply# 113   11/22/2011 at 20:05 (4,530 days old) by bendixmark (Winchester Mass)   |   | |
I just love Kenmores for many reasons including the centerdial ones,they are all special in their own way.I have been enjoying this thread greatly also as I have known all these machines at on time or another going all the way back to my childhood. |
Post# 558678 , Reply# 114   11/23/2011 at 02:00 (4,529 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Well, I didn't mean to be excessively critical on my Kenmore dryer's "Fabric Master" 'auto-dry' control in terms of it being a "malfunction" or to convey my being nit-picky...
Just that the Moisture Sensor which I'm lucky for my dryer to have is much easier to use in terms of judging my degree of dryness, as opposed to the guess-work involved in deciding how many minutes a load requires on a timer (although I have pretty much mastered a load of towels needing FIFTY-MINUTES & on the highest heat setting, and of course the 'Touch-Up' area showing the remaining Fifteen-Minutes on the dryer timer for loads 'not-completely-yet dry' is useful, so I have really NOT eliminated the use for my manual timer; nice to give that 'Sensor' a break once-in-a-while, though)... I just, like my washer lacking a fabric dispenser, (which I would probably seldom, if ever use in this day 'n' age) or being disappointed it doesn't have for a '90' being that 'high-endy', feel a dryer (also a '90') probably needs a switch to turn off the "Wrinkle Guard", or wish it was just in another portion of the timer area... I'm not that unappreciative of the feature, I do like to know to take my clothes out to prevent wrinkles, although many is the time I put clothes wrinkled from HANGING in my dryer for a few minutes (with the manual timer) along w/ my hard rubber dryer ball, or a damp wash cloth... Just that I don't go for the "phantom spins" of the dryer starting up again & turning off & of course, I have the alarm set to highest volume... --There's something I like about my dryer buzzing to let me know it's done, and I respond if & when I can get to it; it's down a flight of stairs at the end of the house under the bedrooms, while I'm normally in the house right above it! I'm sure a lot of people bought high-end dryers w/ that feature & did pay for an extra knob (to get Frigidaire's 'Press Guard' or GE's 'Extra Care', for instance), just to get another feature of two unavailable on a lesser model, so that's how this dryer is viewed... Regarding the lid on my Kenmore washer, since that had been brought up: the only time it would be in my way is watching my washer during filling & having to adjust the Water Level; I have to turn that knob to "Reset" to make any changes, so I have to briefly lower the lid if I want to use less water or can see a load requiring more water during a fill, that's all there... A lid that would lie flat would be right on top of the dryer, which would need a door that opens to the left (a Maytag, in the case of it being a vintage machine) or why a Kenmore w/ a drop-down opening door (which more Whirlpool dryers also have) was chosen, much like a left-opening lid that doesn't lie flat (which CONSUMER REPORTS cites as "Hampers access to the left") or a lid opening to the back would be appropriate in accordance to the installation requirements of my laundry (did take a few pics of my laundry area w/ my camera phone & don't think I have 'em there, but I put 'em on my Facebook page so I'll see if I cvan someday find a way to post 'em here)... Still like my Kenmores, & the many others here, too, fancy or utilitarian, Top-, Bottom-, or Mid-Line, whether washer, dryer, or machine that does both, and no matter what era or what year...! And even if "everyone had one", as opposed to any "underdog" brands, such as Hamilton, Franklin, or Blackstone... Or even Gibson, Kelvinator, Westinghouse, Norge, Wards, or Frigidaire; of which at least like GE, Whirlpool or Maytag, would at least be seen in the kitchen, whereas in my case, the washer & dryer would be a Sears Robuck catalog # _______ (Insert Here)... The best appliances of their time! -- Dave |
Post# 558730 , Reply# 116   11/23/2011 at 09:42 (4,529 days old) by joefuss1984 (Little Rock, AR)   |   | |
I would just like to say that everybody has their own opinion of what machines and styles look good and which ones do not. I for one happen to Love the look of the machines that were found offensive. I am still waiting for my trip out to Gordon's place to get one . However, there is no need to bash what one person likes or doesn't like, the different bodies, control panels, etc all make up the rich history of the brand name.
KENMORE FOR THE WIN!!!!
Post# 558740 , Reply# 117   11/23/2011 at 10:09 (4,529 days old) by stainfighter (Columbia, SC)   |   | |
Post# 558885 , Reply# 119   11/23/2011 at 23:59 (4,528 days old) by areuoneto ()   |   | |
Picture #2 |
Post# 558887 , Reply# 120   11/24/2011 at 00:20 (4,528 days old) by Autowasherfreak ()   |   | |
AWESOME Kenmores! I wish I had a pic of the set I had in the early 90's (92 or 93) TOL with the dual auction agitator and triple dispenser. |
Post# 558900 , Reply# 121   11/24/2011 at 02:14 (4,528 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 558903 , Reply# 122   11/24/2011 at 02:22 (4,528 days old) by CleanteamofNY ((Monroe, New York)   |   | |
Post# 558913 , Reply# 124   11/24/2011 at 05:17 (4,528 days old) by chaskelljr2 (Washington, D. C.)   |   | |
Kenmore Model 80 Image # 2 --Charles-- |
Post# 558917 , Reply# 125   11/24/2011 at 05:31 (4,528 days old) by chaskelljr2 (Washington, D. C.)   |   | |
1960 Lady Kenmore Set Image # 1 --Charles-- |
Post# 558918 , Reply# 126   11/24/2011 at 05:33 (4,528 days old) by chaskelljr2 (Washington, D. C.)   |   | |
The 1960 Lady Kenmore Set Image # 2 --Charles-- |
Post# 559043 , Reply# 127   11/25/2011 at 05:08 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Greg ( gansky )...Which I never forget said , That all washers have there beauty ! And I agree from the top of the line to the bottom Kenmore washers had the most styles as well as agitator designs then any other brand.
Gordon the three cycle model is my faverite we had this model in my family for 10 yrs and one of the strongest Kenmore's I encounterd , the pump on that machine was so strong you can feel the floor vibrate !
All of you guy's kenmores or so speacial and beautiful !
Here are mine...
This model is my friends which I made him get out of the garage swapped out from a modern 2004 GE for now... the agitator grooves whore out need's a replacement.
So I cleaned up this Solid State electronic model and that's what's running now. Ben ( Swestoyz ) also had this machine , I'm not sure if he sold it yet.
Post# 559044 , Reply# 128   11/25/2011 at 05:17 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Pic 2. My 1964 and my best Kenmore.
Classic Tilted Lid. This post was last edited 11/25/2011 at 07:12 |
Post# 559045 , Reply# 129   11/25/2011 at 05:32 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Pic 3. Washing.
Thanks you Laundress without your tactful postings I would have not gotton this goldmine of a washer , you have made me soooo happy with this washer ! Hopeing you well and healthy ! This post was last edited 11/25/2011 at 08:00 |
Post# 559046 , Reply# 130   11/25/2011 at 05:38 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Pic 4. Two years ago I picked up this model deep in the burbs in Philly.
This post was last edited 11/25/2011 at 06:09 |
Post# 559047 , Reply# 131   11/25/2011 at 05:46 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 559048 , Reply# 132   11/25/2011 at 05:50 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 559049 , Reply# 133   11/25/2011 at 06:01 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Washing...
The agitator is my faverite... the only baseless agitator's that I know of. And it is really gentle. Check out the floating sock on the left side of the tub. I call this washer The Screeming Woo Woo ! This post was last edited 11/25/2011 at 07:17 |
Post# 559050 , Reply# 134   11/25/2011 at 06:05 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 559051 , Reply# 135   11/25/2011 at 06:22 (4,527 days old) by neptunebob (Pittsburgh, PA)   |   | |
RevvnKevin, I'm not Kevin but can I chime in about the Kenmores:
2. Agitator: Kenmore offered many so if you didn't like one just buy a model with the one you liked.
3. The control panels: I call these the "Star War" panels beceuse of the black background and they came out around the time the movie was released. But I really like the chrome and colored buttons that made Kenmore unique in the past and they looked like they belonged in an "optimistic" mid century house. Eventually, everyone had the black control panels - which I am sure were cheaper to make - and there was nothing unique.
But there was a unique washer and dryer I wish I had bought - The black Limited Edition of 1986 in black. Darth Vader, your laundry room is ready. |
Post# 559053 , Reply# 136   11/25/2011 at 07:07 (4,527 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 559504 , Reply# 138   11/26/2011 at 20:15 (4,526 days old) by Autowasherfreak ()   |   | |
Wasn't there a video on YouTube that compared all the different Kenmore agitators, or was it just a couple of the Kenmore agitators. I had it saved, but lost it when my old computer died. |
Post# 559791 , Reply# 140   11/27/2011 at 21:24 (4,525 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Just surfing CL in Mpls and found these early DD Lady K machines. I'v had a problem with links not working so be patient if it don't
CLICK HERE TO GO TO whirlykenmore78's LINK on : sale-kgbqj-2707798779@craigslist Craigslist |
Post# 560126 , Reply# 141   11/29/2011 at 09:27 (4,523 days old) by bajaespuma (Connecticut)   |   | |
I apologize for my clumsy comments; I was trying to “stir up the pot” but I mis-stepped on some sensitive toes. That said…
Kevin, you’ve met me in person so you know me at least a little bit. What you wrote was offensive and went well over the line. Don’t know what the issue is, but this is the second time you’ve used the AW forum to attack me personally. Is there a problem that we need to resolve?
Gordon, as far as I’m aware, I don’t know you and we don’t have any history. As for being a “grown-up”, well, I said some negative things about some vintage appliances in the abstract. You, on the other hand, went after me, a vintage human being. |
Post# 560142 , Reply# 142   11/29/2011 at 10:08 (4,523 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Ken, everyone here is allowed their opinion. That's how it works. That being said...
I think you may have made your posted opinions personal, intended or not, by using pictures of one of Kevin's agitators and of Gordon's famed (and one of the most personal to him) Green Monster. If you had used pictures of one of mine in a post where you are knocking the brand or styling, I'D be hard pressed not to take it a little personal. Like me going after G.E. And what I don't like it while using one of those neat designs you make. Also, posting detractions about the Kenmores in a thread that was started and ended up being popular to show off member's personal Kenmores might not have been the wisest choice. As you said, you were "stirring the pot...". That is usually intended to try to get a reaction. You have received your reaction. Ken, I have absolutely NO problem with you. I enjoy your designs. So please take this as it's intended. Just some friendly advise... RCD |
Post# 560158 , Reply# 143   11/29/2011 at 10:51 (4,523 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Charles of DC your dream machines are within 1/2 hours drive away, fully rebuilt delevered and installed with a 1 year parts and lobor in home warranty included for less than 1/2 the cost of crappy new LG machines.
Live your dreams, we only live once.
This pair is also available to anyone else in the club, but we can't provide del & installation and in home warranty service if you live outside our service area. |
Post# 560159 , Reply# 144   11/29/2011 at 10:54 (4,523 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 560178 , Reply# 147   11/29/2011 at 12:44 (4,523 days old) by Jsneaker ()   |   | |
If anyone needs one of those Kenmore white, agitator-top fabric softener dispensers from my 1995, I have mine saved unused/"new". |
Post# 560216 , Reply# 148   11/29/2011 at 15:17 (4,523 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Here's two side by side. You'll remember them as I had videoed them doing a agitation comparison. Both went to Gordon...
Here's the comparison on YouTube. RCD CLICK HERE TO GO TO redcarpetdrew's LINK |
Post# 560217 , Reply# 149   11/29/2011 at 15:20 (4,523 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 560219 , Reply# 150   11/29/2011 at 15:24 (4,523 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 560268 , Reply# 151   11/29/2011 at 19:58 (4,523 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 560305 , Reply# 153   11/30/2011 at 00:14 (4,522 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 560307 , Reply# 154   11/30/2011 at 00:17 (4,522 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 560308 , Reply# 155   11/30/2011 at 00:19 (4,522 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 560309 , Reply# 156   11/30/2011 at 00:24 (4,522 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 560310 , Reply# 157   11/30/2011 at 00:27 (4,522 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 560311 , Reply# 158   11/30/2011 at 00:31 (4,522 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 562020 , Reply# 159   12/8/2011 at 20:32 (4,514 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Loved the pic here
Looks like I'm late to the party again I'm going to get my scanner fixed and scan in the Kenmore pic that I have Our 84 TOL washer dryer set that we got i think was the last year of the BD systems Then the 96-97 DD electronic that Mom got when she did the major remodel on the back of the house |
Post# 562486 , Reply# 161   12/10/2011 at 20:27 (4,512 days old) by superken ()   |   | |
I had a problem loading the picture so here it is. |
Post# 881224 , Reply# 162   5/17/2016 at 16:14 (2,892 days old) by kellyhowe ()   |   | |
heres my kenmore 70 series washing my friends clothes works great |
Post# 881398 , Reply# 163   5/19/2016 at 00:29 (2,890 days old) by 70series ( Connecticut.)   |   | |
I forgot how many great machines were posted in this thread. |
Post# 881402 , Reply# 164   5/19/2016 at 01:28 (2,890 days old) by delaneymeegan (Midwest)   |   | |
Post# 881417 , Reply# 165   5/19/2016 at 07:07 (2,890 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 885100 , Reply# 166   6/14/2016 at 11:35 (2,864 days old) by seedub (South Texas Hill Country)   |   | |
I miss it and hope there's one out there somewhere.
Post# 971103 , Reply# 168   12/2/2017 at 08:00 (2,328 days old) by chetlaham (United States)   |   | |
Post# 971198 , Reply# 169   12/2/2017 at 22:29 (2,327 days old) by 70series ( Connecticut.)   |   | |
I hope you find that model as well. The funky console lighting has a casino-esque look to it that I think is cool; it reminds me of the slot machines I played in Atlantic City. |
Post# 1042754 , Reply# 170   8/26/2019 at 08:56 (1,696 days old) by arthurrbarcello (São Paulo, Brazil)   |   | |
I'm from Sao Paulo, Brazil and these are two of my washing machine collection. A Kenmore Self Cleaning Filter Washing Machine and a Solid State Sensor Electric Dryer. I'm sending two pics of them and a Youtube Link of a video that I made.
CLICK HERE TO GO TO arthurrbarcello's LINK |
Post# 1042808 , Reply# 171   8/27/2019 at 00:06 (1,695 days old) by 70series ( Connecticut.)   |   | |
Great way to resurrect this wonderful thread. Thanks for sharing your video. Have a good one, James |
Post# 1042809 , Reply# 172   8/27/2019 at 00:55 (1,695 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 1052698 , Reply# 173   11/29/2019 at 11:25 (1,601 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 1052905 , Reply# 174   12/2/2019 at 01:59 (1,598 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1052949 , Reply# 175   12/2/2019 at 16:07 (1,598 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1052990 , Reply# 176   12/3/2019 at 04:27 (1,597 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1053058 , Reply# 177   12/3/2019 at 17:22 (1,597 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1053174 , Reply# 178   12/4/2019 at 18:47 (1,596 days old) by Frigilux (The Minnesota Prairie)   |   | |
Question: Does anyone know what year the beautiful 31480 shown in reply #166 (and also here) was produced? It’s a stylish one, no doubt! Also: Is it an American model or perhaps Canadian?
Post# 1053179 , Reply# 179   12/4/2019 at 19:47 (1,596 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Is a 1963 KM 800 series, It might have been carried over into 1964 ?
I always liked this machines styling.
This was the first KM washer I did a major repair on in a customers home. Sears had told her that it would cost over $100 to fix, so my Mom drove me over to her house and I took it all apart, the basket drive had stripped ears at the top of the shaft. I went by a local appliance dealer and took a BD out of a 1961 KM on the scrap pile and took the part over to the customers house and installed it, I think I charged her about $20 which was all profit as my Mom even drove me back and forth and didn't even charge me for gas.
This 63 KM lasted into the 80s and someone gave her an early 70s KM that finally replaced it.
Post# 1053188 , Reply# 180   12/4/2019 at 22:50 (1,595 days old) by toploadloyalist (San Luis Obispo, CA)   |   | |
I have created a group devoted group to old-time Kenmores called "Vintage Kenmore Appliances (Especially Laundry Pairs and Dishwashers). Come join and enjoy! |
Post# 1053190 , Reply# 181   12/4/2019 at 23:44 (1,595 days old) by aircub (Huntington, AR)   |   | |
where are they? I would love to own them!!!! Darren |
Post# 1053219 , Reply# 183   12/5/2019 at 09:29 (1,595 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1053245 , Reply# 184   12/5/2019 at 16:50 (1,595 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1053246 , Reply# 185   12/5/2019 at 16:59 (1,595 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1053288 , Reply# 186   12/6/2019 at 00:01 (1,594 days old) by aircub (Huntington, AR)   |   | |
man I wish I lived closer but Arkansas is to far I had the exact pair my first house set and loved them real work horse! I love your collection, Darren |
Post# 1053308 , Reply# 187   12/6/2019 at 08:40 (1,594 days old) by goatfarmer (South Bend, home of Champions)   |   | |
The barn is full, a mix of retro, and newer things. But it would be a long road to try and make a business of selling vintage appliances. Lots of lookers, few takers. I've offered a lot of items for FREE, come pick them up.
I still have them.....
This thread I offered a few machines for free. Look what was offered. I ended up parting the dishwasher to a member. The others I still have. CLICK HERE TO GO TO goatfarmer's LINK |
Post# 1053397 , Reply# 188   12/7/2019 at 00:01 (1,593 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
I like them inside much more.
Post# 1053408 , Reply# 189   12/7/2019 at 07:50 (1,593 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Wow Jon they look great in your Laundry Room, The wood appliance accents and cabinets and floor look great together, you just need a home with more laundry rooms.
While there are lots of interesting Washers & Dryers out there it is easy to see how WP laundry products captured nearly 50% of the laundry market from around 1950 on and WP laundry is still the best selling in the US.
The BD washers worked great overall and you did not have to make excuses about cleaning, lint, sand, tangling or machines walking etc, owners would buy one after another, WP-KM had a much better loyalty and repurchase rate far higher than any other brand.
Jon you should call that friendly Sears service man dressed in his gray uniform for your annual preventive service heck-up and see what they think of you more than 40 YO W&Dstill working like new, LOL
Post# 1053425 , Reply# 190   12/7/2019 at 09:33 (1,593 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
John,
I was chatting with Jason a week or two ago about my lawn sprinkler collection. This past spring I lucked out and found several NOS Rainbird in-ground brass heads from 1974. I decided I wanted my sprinkler system to be more matching to my house which was built in early 1979. Now the same applies to the laundry room! Bringing my home back to its roots. I can’t tell you how nice it is to hear the belt-drive sounds within these walls. By the way, I ran a very full load of mixed dark and white towels. Typically I’d find a little bit of dark lint on my white towels. Not this time. The towels were fluffier and completely lint-free with only a single rinse. Impressive! |
Post# 1085784 , Reply# 193   8/20/2020 at 13:33 (1,336 days old) by Maytag85 (Sean A806)   |   | |
My 1984 Kenmore portable belt drive set I now have owned for 3 years. And they have came a long way from when I first got them.
Some photos of my Kenmore portable belt drive set |
Post# 1085864 , Reply# 195   8/21/2020 at 02:00 (1,335 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Here’s the 1964 Kenmore 70 fully restored. Quietest Kenmore I’ve ever seen.
Post# 1085877 , Reply# 196   8/21/2020 at 10:23 (1,335 days old) by appnut (TX)   |   | |
Post# 1085885 , Reply# 198   8/21/2020 at 11:50 (1,335 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
The machine appeared to be all original. The filter was missing but I found a Whirlpool NOS filter and housing that I installed. I believe the snubber agitator cap was included on the next model up which I believe was the Lady K. New bearings and seals installed making this the smoothest and quietest Kenmore I’ve ever witnessed.
Post# 1085895 , Reply# 199   8/21/2020 at 13:09 (1,335 days old) by Maytag85 (Sean A806)   |   | |
This may be a Kenmore thread but I have a ‘63 Whirlpool Imperial Mark XII that’s all original with the exception of the belt and pump and hose that goes from the pump to the lint filter and it appears to works just fine and doesn’t make any strange sounds at all. Could be because it only has 42 years of actual use on it since it was in service from 1963 to 2005 and the elderly lady who owned my ‘63 Whirlpool Imperial Mark XII set probably didn’t use it much at all before the house it was in ended up being sealed up until last year sometime
Post# 1085904 , Reply# 200   8/21/2020 at 14:03 (1,335 days old) by 4bagger (Long Beach)   |   | |
Mismatched and miscolored, but still a pretty cool way to do a few loads of laundry a week!
Post# 1085910 , Reply# 201   8/21/2020 at 15:28 (1,335 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1085916 , Reply# 203   8/21/2020 at 16:09 (1,335 days old) by Maytag85 (Sean A806)   |   | |
Had to replace the drum rollers and belt on my Kenmore portable dryer along with the timer and power cord but I can’t really complain about making those repairs to something that’s over 35 years old. Interestingly enough my ‘63 Whirlpool dryer has no drum rollers and only has a bearing in the rear compared to the 1966 to the present Whirlpool and Kenmore 29” dryers.
Post# 1085998 , Reply# 204   8/22/2020 at 08:04 (1,334 days old) by chetlaham (United States)   |   | |
Post# 1086014 , Reply# 205   8/22/2020 at 12:19 (1,334 days old) by DDFan92 (Boise ID)   |   | |
I'd say normally, about maybe 4-6 loads a week. But that will probably change when I get my other two machines in service. |
Post# 1086103 , Reply# 206   8/22/2020 at 23:28 (1,333 days old) by chetlaham (United States)   |   | |
Post# 1086247 , Reply# 207   8/24/2020 at 02:12 (1,332 days old) by aircub (Huntington, AR)   |   | |
just found these at an estate auction for $5 each, |
Post# 1086249 , Reply# 208   8/24/2020 at 02:13 (1,332 days old) by aircub (Huntington, AR)   |   | |
why are my pics turned wrong? |
Post# 1086269 , Reply# 209   8/24/2020 at 07:47 (1,332 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1086272 , Reply# 210   8/24/2020 at 08:26 (1,332 days old) by appnut (TX)   |   | |
Post# 1086281 , Reply# 211   8/24/2020 at 10:12 (1,332 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1086306 , Reply# 212   8/24/2020 at 11:56 (1,332 days old) by appnut (TX)   |   | |
Post# 1086423 , Reply# 213   8/25/2020 at 02:18 (1,331 days old) by aircub (Huntington, AR)   |   | |
Do you know about what year these are the washer agitator has the loud clicking so I know it was early Dual Action? Darren |
Post# 1086450 , Reply# 214   8/25/2020 at 07:08 (1,331 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
