Thread Number: 37475
Maytag problem |
Post# 557225 , Reply# 1   11/17/2011 at 11:14 (4,515 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hi Mark,
Unless I'm mistaken, the large pulley you are referring to has the tub brake assembly in it. As you are turning it you are most likely releasing the tub brake, that;s why it only turns so far.
Please further explain what happens with the washer. You set the timer and start it, water flows and then what? Does the motor start but nothing at all happens? What happens when you start the washer on a drain/spin? Do you have the front panel off while you are trying all this so you can see what's happening inside?
Thanks! Kevin |
Post# 557265 , Reply# 3   11/17/2011 at 13:19 (4,515 days old) by mrb627 (Buford, GA)   |   | |
Post# 557272 , Reply# 4   11/17/2011 at 13:38 (4,515 days old) by map79z28 ()   |   | |
Clockwise. Didnt try to turn counter-clockwise. But why does it get stuck in the same place? and cant move it any further by hand? |
Post# 557286 , Reply# 5   11/17/2011 at 14:18 (4,515 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hey Mark,
Have you seen this thread yet?
Thread# 37462 Maytag LAT2914AAE Won't Wash (here in this forum)
It not check it out, there may be some helpful info there. Does your washer have the same transmission as the one pictured in the thread?
Kevin |
Post# 557308 , Reply# 6   11/17/2011 at 15:03 (4,515 days old) by map79z28 ()   |   | |
Cant tell for sure. But based on the three things indicated. It sounds like the transmission is toast. |
