Thread Number: 37504
Cleaning Washer Grime |
Post# 557641   11/18/2011 at 18:18 (4,541 days old) by joefuss1984 (Little Rock, AR)   |   | |
I am trying to figure out the best way to clean grime off of a washer. The main problem I have is the top of the agitator and wash tub where the top water level sits. I got the agitator clean with some simple green, a rag, and some elbow grease. The tub however is stainless and the grime seems baked in somehow haha. Any suggestions? Also on washers that are all caked up with detergent scum, what do you use to cut through that, a wet rag just creates a slimy mess!
Post# 557655 , Reply# 2   11/18/2011 at 19:43 (4,541 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 557693 , Reply# 3   11/18/2011 at 22:18 (4,541 days old) by whirlaway (Hampton Virginia)   |   | |
Hi! Its a real fine scouring powder,but no additives like comet.Supermarket should have it or the dollar store.Sometimes you can get it in a bar like soap,good for cleaning windows,its not coarse,your welcome Bobby |
Post# 557818 , Reply# 4   11/19/2011 at 11:50 (4,541 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 557821 , Reply# 5   11/19/2011 at 12:11 (4,541 days old) by westingman123 ()   |   | |
Bon Ami, hasn't scratched yet! |
Post# 557897 , Reply# 6   11/19/2011 at 19:48 (4,540 days old) by stan (Napa CA)   |   | |
running a cycle, maybe with a 20 min soak (no clothes) with hot water and some phosphate detergent, or add STPP, to soften and loosen. See how much comes off first before scrubbing! if its on the inside tub, then it's on the outer tub as well. The phosphate will help to break it loose from both inner and out tubs, and pump, hose drain, ect
Post# 558267 , Reply# 7   11/21/2011 at 10:17 (4,539 days old) by joefuss1984 (Little Rock, AR)   |   | |
