Thread Number: 37516
Number of Rinses Indesit IWD5123 |
Post# 557800 , Reply# 2   11/19/2011 at 10:58 (4,541 days old) by AquaCycle (West Yorkshire, UK)   |   | |
Post# 557803 , Reply# 3   11/19/2011 at 11:05 (4,541 days old) by paulc (Edinburgh, Scotland)   |   | |
Post# 557816 , Reply# 4   11/19/2011 at 11:39 (4,541 days old) by HotpointFan (United Kingdom)   |   | |
Post# 557817 , Reply# 5   11/19/2011 at 11:47 (4,541 days old) by aquarius8000 ()   |   | |
our hottie goes from 0-5 rinses. |
Post# 557819 , Reply# 6   11/19/2011 at 11:53 (4,541 days old) by gorenje (Slovenia)   |   | |
Post# 557872 , Reply# 8   11/19/2011 at 16:42 (4,540 days old) by boschlover1997 ()   |   | |
on my hoover, 2 rinses on rapid 14 and 3 on rapid 30 and 44.. synthetics is 4 rinses and cottons is 4 too :) |
Post# 557874 , Reply# 9   11/19/2011 at 17:10 (4,540 days old) by logixx (Germany)   |   | |
My Dreamspace will also do two rinses as a default. Three with Intensive Rinse and four with Sensitive Skin selected. It all largely depends on the system used for rinsing. The Dreamspace spins and sprays the load at the beginning of each rinse so everything wets down fairly quickly. The AEG, on the other hand, did a poor job getting a full load saturated - since it didn't have the Jet System.
Post# 558783 , Reply# 12   11/23/2011 at 13:33 (4,537 days old) by jetsystem1200 ()   |   | |
My Zanussi FJD1266W does three short rinses (I think) and if you turn on Super Rinse, it makes the rinses longer. |
Post# 559217 , Reply# 13   11/25/2011 at 18:37 (4,534 days old) by nrones ()   |   | |
Hi again, I just wanted to ask you in what phase of spin does your machine actually move? In bursts, or when main spin kicks, or when? :) Dex |
Post# 559279 , Reply# 15   11/26/2011 at 02:44 (4,534 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Hi Aeg03... I'm actually surprised to see that you of all people finished up with an Indesit :-P
I appreciate the facts that these particular models shake a lot during spin but I still can't share the advisor's view about it being lightweight: I've had to move my ex Indesit washer dryer form time to time and I can assure you that it's as heavy as any other machine (if not heavier as it's a dryer too)... but it still shakes like there's no tomorrow especially when it lets an unbalanced load into spin. Anyway, once I'm here, I might as well stick to the topic of this thread... number of rinses on modern machines... yeah... 2 seems the norm! My Hoover does 3 rinses as standard on synthetics and for 80% of times it does 3 rinses on cottons too, unless it has a very small load in (like 1 kilo) then it does only 2. However, the same identical machine as mine was revised after a few years... in 2006 to be exact, and it was replaced by other models which were exactly the same cosmetically but they were programmed to carry out only 2 rinses (with higher water level) instead of 3. Having said that... they would still rinse 3 times as required if they sensed too much foam, instead my older model just enhances the water level of each rinse. Have you got an extra rinse facility on the Indesit? If you have, that would give you the 3rd rinse but also rise the water level on all. Happy rinsing ;-) |
Post# 559282 , Reply# 16   11/26/2011 at 03:50 (4,534 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
My new Hotpoint ultima (of the same family of course)weighs an absolute ton and hardly moves and I'm on a 3rd floor flat! Occasionally it has a wobble but not often.
2 rinses are standard on this machine. But I can do up to 5 but tbh they are very deep most of the time and the lower rinses use dual tumbling it rinses brilliantly and I am the fussiest person when it comes to rinsing. My last zanussi did 3 shallow rinses with no option of an extra rinse. It was a zwf12070g1 like liams minus the temp control. It did slightly deeper rinsing with big loads or towel loads but it static filled which wound me up something chronic as it would just soak it all up and not refill! Rarely it did! The fact the bearings began to go after 2 years was very disappointing. I had an aeg like yours and countless zanussis as it was my favourite brand but I'm unconvinced I would buy another at this stage. My LG did 3 rinses the highest it filled was the rim of the drum but it had a very powerful jet which made it rinse fantastically. That could could do up to 5 and a warm rinse could be selected. Warm clothes at the end was very bizarre but very effective! Darren |
Post# 559310 , Reply# 18   11/26/2011 at 07:29 (4,534 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Post# 559327 , Reply# 19   11/26/2011 at 09:17 (4,534 days old) by aeg03 (London, UK)   |   | |
Oh right. I thought the one I have is a current model. Its exclusive in John Lewis. |
Post# 559614 , Reply# 20   11/27/2011 at 05:18 (4,533 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Post# 559728 , Reply# 22   11/27/2011 at 14:27 (4,533 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
