Thread Number: 37610
1950 kenmore help |
Post# 559388 , Reply# 1   11/26/2011 at 13:37 (4,528 days old) by yogitunes (New Jersey)   |   | |
can we get a pic of the one you need......
is it the one that goes directly from the tub to the pump......no pump guard?.....best solution I seen from John was to install the rubber fitting in the base, with the pump guard and then the four inch hose to the pump...... or is it with a pump guard, and you need that 4 inch piece to connect to the pump....this one is simple.....Lowes sells reinforced hose, clear, 1 1/4 inch...buy a foot and cut to fit..... almost anything can be improvised! |
