Thread Number: 37611
Kitchenaid KDSM 21A-does not drain, full of soap crud |
Post# 560836 , Reply# 1   12/2/2011 at 14:32 (4,527 days old) by zinniakdsm21a ()   |   | |
Hi, I am adding to my message to see if I can get any response from any of you knowledgeable people. Please help. I need instructions on how to remove the old motor. Again, mny thanks. |
Post# 560856 , Reply# 2   12/2/2011 at 17:19 (4,526 days old) by pdub (Portland, Oregon)   |   | |
Can you take and post pictures of your machine to this thread, that would be helpful. Get one of the control panel and one of the interior showing wash arm at bottom.
After the machine fills, does it sound like it's washing? If so, when it stops and pauses just before it is supposed to drain, does it go into the drain process (or sound like it)??? Your drain hose from the pump to the disposer or sink port could be plugged up or there could be a timer problem like not advancing into drain. Let us know more... |
Post# 561719 , Reply# 4   12/7/2011 at 13:59 (4,522 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
