Thread Number: 37708
Miele W1986 draining very slowly |
Post# 561002 , Reply# 3   12/3/2011 at 15:08 (4,499 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Yes, smaller loads get a shorter wash time. |
Post# 561063 , Reply# 5   12/3/2011 at 23:25 (4,498 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 561317 , Reply# 7   12/5/2011 at 15:02 (4,497 days old) by ronhic (Canberra, Australia)   |   | |
Miele's are designed to be used...and used often.
There are hundreds and hundreds of small, private laundry services all over Europe that use non-commercial Miele machines to do their 'bag wash' (wash/dry/fold) services for a reason - these machines are designed to take heavy use and are as close to commerical machines as you can get, with the possible exception of Speed Queen front loaders.
...and nothing needs to be 'pushed hard' on a Miele to get it to work. |
Post# 561324 , Reply# 8   12/5/2011 at 15:57 (4,497 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Miele's 1900 series amoung others are routinely used by dry cleaners and laundries here in the states.
Not only is the build quality fantastic but the various settings and range of textile care options Miele presents on domestic washers aren't normally found on commercial units until one spends several thousands. |
Post# 561339 , Reply# 10   12/5/2011 at 17:51 (4,496 days old) by Lee280zx ()   |   | |
Launderess-- It's "Bouquet," darling. It's French. |
Post# 561386 , Reply# 12   12/5/2011 at 21:27 (4,496 days old) by ronhic (Canberra, Australia)   |   | |
That, I would like to see.....
You wouldn't do that to the front door at home, and I would suggest that it shouldn't EVER be done to a washing machine.
If it said something along the lines of 'Swing the door closed and press firmly', that would be more accurate rather than giving a wind-up to slam it in one hit....
Pushing the door to and then clicking it shut with your hand over the catch is the ONLY way any front loader without a lever-style handle should ever be closed. |
Post# 561439 , Reply# 14   12/5/2011 at 23:10 (4,496 days old) by ronhic (Canberra, Australia)   |   | |
Post# 561448 , Reply# 15   12/5/2011 at 23:33 (4,496 days old) by mielerod69 (Australia)   |   | |
