Thread Number: 37878
mobile maid rescue |
Post# 563383   12/15/2011 at 09:35 (4,509 days old) by juice61 ()   |   | |
Found in a field.had been pulled from an old house .they were about to load it to take it to scrap yard. I just happened to be there on a service call.will post pics . |
Post# 563399 , Reply# 1   12/15/2011 at 11:35 (4,509 days old) by turquoisedude (.)   |   | |
Post# 563404 , Reply# 2   12/15/2011 at 12:42 (4,509 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 563446 , Reply# 3   12/15/2011 at 19:10 (4,508 days old) by mikepaquette ()   |   | |
Pic's PLEASE. |
Post# 563449 , Reply# 4   12/15/2011 at 19:40 (4,508 days old) by bajaespuma (Connecticut)   |   | |
Post# 563743 , Reply# 5   12/17/2011 at 14:54 (4,506 days old) by juice61 ()   |   | |
Interior is very good |
Post# 563745 , Reply# 6   12/17/2011 at 15:25 (4,506 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 563757 , Reply# 7   12/17/2011 at 17:29 (4,506 days old) by juice61 ()   |   | |
Clean |
Post# 564260 , Reply# 8   12/20/2011 at 10:13 (4,504 days old) by juice61 ()   |   | |
Top |
Post# 564272 , Reply# 9   12/20/2011 at 11:07 (4,504 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 564304 , Reply# 11   12/20/2011 at 14:42 (4,503 days old) by rp2813 (Sannazay)   |   | |
I have that same model refrigerator. Looks like you're in the middle of a thermostat issue. I had to replace mine a few months ago. Feel free to contact me about my experience. I also have the service manual.
Here, for about the 10th time, is a shot of my fridge. That's 120 watts worth of interior lighting, from three separate sources. Ah, the olden days when energy was cheap and the power companies encouraged everyone to use as much as they could. |
Post# 564315 , Reply# 12   12/20/2011 at 15:24 (4,503 days old) by westingman123 ()   |   | |
Oh, Ralph, it may be about the 10th time, but we never tire of that beauty! Post away, sir. |
Post# 564317 , Reply# 13   12/20/2011 at 15:26 (4,503 days old) by juice61 ()   |   | |
You are right.it will not shut off.cools great I can get aftermarke stat but have been looking for an original.l will trade mobile maid to that upper shelf |
Post# 564320 , Reply# 14   12/20/2011 at 15:37 (4,503 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 564321 , Reply# 15   12/20/2011 at 15:41 (4,503 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Ralph, I NEVER tire of seeing one of my orphans in her new home! I am still jazzed that you took to her like that. One of many treasures from "The Pile" behind our shop that found a good home...
I am healing the femur better every day and am about ready to start playing... errr... WORKING on some things that have been haunting me these past three or four months including a '63(?) Mobile Maid... I like the one I see here!!! RCD |
Post# 564339 , Reply# 16   12/20/2011 at 16:37 (4,503 days old) by rp2813 (Sannazay)   |   | |
Hey Andy, I can't pull a beer or soda out of that fridge without thinking of you! Thanks again for rescuing it! If David (Marler) had his way, the fridge would have followed him to Tucson but it's not going anywhere, I can assure you of that!
Joseph, you don't see food because it's my designated beverage (and sometimes overflow) fridge.
John, good luck finding OEM control for your fridge. The aftermarket one I have is working fine, but OEM would have been preferred, as the mounting would be more solid. If you decide to go with an aftermarket one (Larry at Modern Parts might still have one in stock) I can give you some pointers on how to modify it (with provided parts) and make it work just like the original. The controls seem to be the weak link on GE fridges of this era. Mine did the same thing; wouldn't shut off. I had the aftermarket control here waiting, so took appropriate action and the fridge has been fine ever since.
Nate and I opened up the old control but couldn't really see any obvious issues with it. Otherwise, I would have preferred to repair that control and continue to use it. If a visual check of your control reveals the trouble, I can perhaps provide parts from mine to fix yours.
Post# 564342 , Reply# 17   12/20/2011 at 16:51 (4,503 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 564402 , Reply# 19   12/20/2011 at 22:01 (4,503 days old) by Autowasherfreak ()   |   | |
What a great save, and that frige is fabulous too. |
Post# 564407 , Reply# 20   12/20/2011 at 22:42 (4,503 days old) by rp2813 (Sannazay)   |   | |
Exactly. Based on my experience (hindsight is definitely 20/20), a universal fit can be made to look and feel (as in a thumbwheel that doesn't wobble) like the original if, 1) The adjustable holes for the mounting screws are properly aligned with those in the interior liner's trim -- which is not as cut & dried as one might think, and, 2) A conservative approach is used should the thumbwheel post on the replacement control need to be shortened. If it appears you'd have to make deeper notches in the end of the thumbwheel shaft as a result of your cut, you're removing too much from the post. I ended up with not enough thread in the post for the screw that secures the thumbwheel.
I got tired of looking at the empty egg shelf on my fridge. Only once have I had to use that space for something due to lack of room. I now have an installation of a dozen multi-colored plastic Easter eggs in there indefinitely.
That Hotpoint sounds nice. Post pix if you get it. |
Post# 564834 , Reply# 21   12/23/2011 at 13:49 (4,501 days old) by juice61 ()   |   | |
Looks good |
Post# 564838 , Reply# 22   12/23/2011 at 13:55 (4,501 days old) by rp2813 (Sannazay)   |   | |
Post# 564842 , Reply# 23   12/23/2011 at 14:06 (4,501 days old) by juice61 ()   |   | |
More pink |
Post# 564938 , Reply# 24   12/24/2011 at 00:02 (4,500 days old) by rp2813 (Sannazay)   |   | |
Post# 564971 , Reply# 25   12/24/2011 at 01:49 (4,500 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 565277 , Reply# 26   12/26/2011 at 13:10 (4,498 days old) by rp2813 (Sannazay)   |   | |
