Thread Number: 37888
POD Maytag "0" series 806 |
Post# 563551 , Reply# 1   12/16/2011 at 12:01 (4,485 days old) by macboy91si (Frankfort, KY)   |   | |
Yes, I was aware of the capacity limitations of the machine going in. I love the machines though, they are something different and with me, I can certainly manage. Me an my roommate use the 1976 A407 and matching 1976 DE408 dryer as daily drivers, neither of us generate that much laundry. I mainly like them because the machines have very clean lines on the cabinet and control panel and they were in good condition and not used very heavily. I'd say they run maybe 3-5 full loads a week. I would personally consider the "big-tub" Maytag on par with standard capacity machines of other brands and of the machines that I own, the GE is the largest "real-world" capacity machine that I own. I have no ran into any fabric damage myself with the Maytag, but I can see where overloading would cause clothing issues. The Super Highlander 502 I have is much more aggressive with it's fixed-vane bakelite agitator, coupled with it's smaller tubs, you have to be careful how you load it. Again I will never understand why they didn't let the machine wash with the lid up. I've had to pull that one sock too many out before on my machine more than once but I have the lid-switch disabled. My 1976 A407 still reads Small, Medium, "Normal", and Large on the water levels.
-Tim This post was last edited 12/16/2011 at 12:19 |
Post# 563601 , Reply# 2   12/16/2011 at 18:22 (4,485 days old) by Kenmore71 (Minneapolis, MN)   |   | |
While still techincally series "0" machines, this ad would not be from the original release of the new "large capacity Washerpower" machines that were introduced in January of 1966. The fact that they have permanent press cycles, 4 water levels, models 407 & 207 BUT lack the "sun glow" panel strip indicates to me that this brochure was produced sometime between 1970 & 1975.
The ORIGINAL 806, 606 & 406 machines had only 3 water levels: small, normal & large. Small was a 12-1/2 gallon fill, normal was 16 gallons (the same as the "normal" capacity machines) and large was 19 gallons. The four button water level selector as shown in the POD was added in December of 1968. Also, none of the early machines has a special "Permanent Press" cycle with a cool-down phase. That was introduced in February of 1969. I cannot find documentation to determine when the 206 & 406 became the 207 & 407 and when the 107 was introduced. I am relatively certain that this HAD happened by 1972, though. I'm also not entirely certain what things were changed so significantly was to warrant re-numbering those models and NOT the 606 and 806 (in fact, the 806 retained its model number all the way up until the introduction of the *10 series machines in 1980!) Here's a pic of the 1966 brochure with the 3 water level switch on an 806 |
