Thread Number: 38029
Anyone need a replacement Roto Rack ? |
Post# 565226   12/25/2011 at 20:38 (4,477 days old) by verizonbear (Glen Burnie )   |   | |
Post# 565575 , Reply# 2   12/28/2011 at 14:42 (4,474 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 565576 , Reply# 3   12/28/2011 at 14:44 (4,474 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 565577 , Reply# 4   12/28/2011 at 14:45 (4,474 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 565606 , Reply# 5   12/28/2011 at 18:22 (4,474 days old) by verizonbear (Glen Burnie )   |   | |
Post# 565735 , Reply# 7   12/29/2011 at 07:32 (4,473 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
John have you ever used your LKM DW? it would be interesting to see how much the top rack turns without a separate water feed tube spraying it and propelling it to turn. I don't think this design was used very long, Tom has the next generation TL LKM portable DW that still has an impeller for the lower rack but also has the spray tube for the roto-rack. |
Post# 565842 , Reply# 8   12/29/2011 at 19:32 (4,473 days old) by jakins (Kissimmee, Fl.)   |   | |
The Red line is what you see as the timer advances. they called it the "speedometer" dial it is not lighted although I have often thought that would have been a good idea. the Roto Rack hardley turns during a cycle unless you are washing small items. Even with the adjustable height with todays plates it is hard to get clearence. also with the design you have to make sure the top rack is balanced just right. If not it will tip and cathc on the plates below. However all in all it washes great esp. when you switch to super wash and super rince. here are a few pics and scans from the catalog.
John |
Post# 565843 , Reply# 9   12/29/2011 at 19:32 (4,473 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 565844 , Reply# 10   12/29/2011 at 19:33 (4,473 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 565845 , Reply# 11   12/29/2011 at 19:35 (4,473 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 565846 , Reply# 12   12/29/2011 at 19:39 (4,473 days old) by jakins (Kissimmee, Fl.)   |   | |
Post# 565937 , Reply# 13   12/30/2011 at 11:06 (4,472 days old) by dishwashercrazy (West Peoria, IL)   |   | |
I decided to bid on this Dishwasher Rack, and I won the auction. I thought it would be cool to have, because when I was in high school (1970) I had a slightly older Kenmore "Six Hundred" Model 587.65510, S/N: 24415 (I do not know how to decode the age). It had the exact same rack. I am planning on putting the rack inside one of my GE dishwashers that I can fit with a Plexiglas lid to watch the top rack turning. Theoretically it should work. Mike |
