Thread Number: 38039
Kenmore Drying so so |
Post# 565280   12/26/2011 at 13:32 (4,501 days old) by joefuss1984 (Little Rock, AR)   |   | |
I know this doesnt belong on the vintage post per say....However I know that a lot of the guys who read and post on this page have infinite knowledge. I have also posted on the delux page as well. Anyway here goes...
My parents Kenmore Elite Dryer is about 10 years old. (Model - 110.72954100/Serial - MM0304885). The dryer is gas powered. The dryer has the moisture sensor with the Automatic Dry Cycle. For the last few years you have to set it to the most dry option and sometimes then it may not be dry all the way. I don't know if the moisture sensor bars are not working quite right but it seems every WP Dryer I have had eventually starts acting like this. When it was new setting the dryer on the recommended dry used to be sufficient. This dryer has never been cleaned on the inside. If someone could help me address the first issue mentioned above and how to properly open up and clean out the interior that would be great! Thanks! |
Post# 565297 , Reply# 2   12/26/2011 at 16:08 (4,501 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 565301 , Reply# 3   12/26/2011 at 17:35 (4,501 days old) by joefuss1984 (Little Rock, AR)   |   | |
So I kinda winged it with what I was doing haha. I took the bottom cover off. The bottom of the cabinet was lined with about 3/4" of lint. I took the vacuum to all of that and anything else I could get to with lint buildup. It vents at the front, so I looked down the slot the filter goes into. It was full of lint!! So I then removed the cover for the blower wheel which is also the slot the lint filter goes down into. Lawdy have mercy!! The hole in the blower wheel cover where the blower wheel attaches to the lint filter shaft was half full! So I cleaned all of that out. Took alcohol to the moisture sensors. Ran the filter through the dishwasher (this works great for cleaning the grime off). The last thing I did was replace the exhaust vent from a foil type to the good metal one. The exhaust shaft in the dryer was relatively clean.
I noticed that the belts were starting to fray a little and the rollers could probably stand to be replaced but that will have to wait a bit. The only other maintenance this dryer has had was the circuit board had to be replaced once about a year ago. This dryer has seen a lot of heavy use as it was put in the house while my sister and I still lived at home and mom and dad are not the most careful with the laundry appliances lol. It is now drying a load of undies so we will see how good it does! |
Post# 565302 , Reply# 4   12/26/2011 at 17:39 (4,501 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 565305 , Reply# 5   12/26/2011 at 18:51 (4,501 days old) by KenmoreBD (Mass, usa )   |   | |
With my folks and we had a Kenmore dryer with same issue, did the alcohol work? |
Post# 565333 , Reply# 6   12/26/2011 at 22:05 (4,501 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Almost any dryer of any brand attracts lots of lint to settle inside the cabinet and all over various internal parts, and a decent amount throughout the exhaust vent. Clean out and delint every 2-5 years, from the innards of the cabinet to all ducts inside the machine and all vent pipes going outdoors, you should be ok. It's a standard part of dryer maintenance that gets neglected until there's a problem. |
Post# 565655 , Reply# 7   12/28/2011 at 22:37 (4,499 days old) by joefuss1984 (Little Rock, AR)   |   | |
So the first load of undies took an hour to dry on medium-high heat setting the time on the most dry option. They were still slightly damp and resetting the timer on most dry, tho it did not take as long as the first time, by the time it shut off it was dry.
Towels always dry good on high heat and button down shirts always dry well on the extra low heat setting for the most part. But I still wonder why the clothes are not dry at the end of the cycle when it is set on the most dry option. They used to be completely dry using the normal dry setting. I wiped the sensors with alcohol but my cloth was still white so either they werent dirty or nothing came off. |
Post# 565660 , Reply# 8   12/28/2011 at 23:15 (4,499 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 565675 , Reply# 10   12/29/2011 at 00:29 (4,499 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
In the users guide for our Whirlpool dryer it states that every three years or so the cover needs to come off and the insides vacuumed out for best drying. You may have had a combination of dirty sensors along with a linty dryer. |
Post# 565756 , Reply# 11   12/29/2011 at 09:42 (4,498 days old) by joefuss1984 (Little Rock, AR)   |   | |
