Thread Number: 38064
Screeching noise on my KDS-18? Stevet are you out there? |
Post# 565607 , Reply# 3   12/28/2011 at 18:37 (4,496 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes Steve is probably correct, we used to run into this problem fairly frequently. We used to remove the motor and you would have to completely disassemble the pump assembly from the motor, but you can epoxy the fan blade in place on the motor shaft. I never had one fail again after we did this and you can keep using the machine with the loose fan blade. But eventually the blade will get so loose that motor cooling will suffer and the motor may cut out on the overload protector before the full cycle is complete. |
Post# 565648 , Reply# 4   12/28/2011 at 21:31 (4,496 days old) by alabamboy ()   |   | |
So there is a chance I can fix the cooling fan? |
