Thread Number: 38083
Video of a 1955 Blackstone washer |
Post# 565746   12/29/2011 at 09:10 (4,495 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 565747 , Reply# 1   12/29/2011 at 09:27 (4,495 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 565749 , Reply# 2   12/29/2011 at 09:32 (4,495 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Great machine there Kevin, it looks sooo substantial cant understand why there arnt many more around, yet the mechanics look a lot simpler than other TL`s, but perform in a quirky way!!!
What would happen if the powers goes off whilst filling, I guess its a timed fill - would it just keep overflowing?? Love the french doors at the front for easy access & viewing, is that Nate viewing the machine underneath??...Lol |
Post# 565758 , Reply# 3   12/29/2011 at 09:53 (4,495 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 565769 , Reply# 4   12/29/2011 at 11:35 (4,495 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 565771 , Reply# 5   12/29/2011 at 11:48 (4,495 days old) by Blackstone (Springfield, Massachusetts)   |   | |
Post# 565800 , Reply# 6   12/29/2011 at 15:43 (4,495 days old) by peteski50 (New York)   |   | |
Post# 565821 , Reply# 7   12/29/2011 at 17:17 (4,494 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
WOW great video Kevin, I have not seen one of these run through a full cycle in about 45 years. My younger brother Jeff and I found a Model 250 when he was about 10 years of age and he and I tore it all apart and replaced a broken connecting rod in the transmission that we took from another Blackstone. The machine ran great, it was very well built and smooth in operation. Thanks to Fred in Springfield Mass. I have a 250 again and he sold me a brand new gas dryer that matches the washer you video taped. He also sold me his remaining parts supply for these neat washers, so if anyone needs anything to fix one let me know. |
Post# 565826 , Reply# 8   12/29/2011 at 18:14 (4,494 days old) by mickeyd (Hamburg NY)   |   | |
Post# 565834 , Reply# 9   12/29/2011 at 19:04 (4,494 days old) by Supersuds (Knoxville, Tenn.)   |   | |
Post# 565888 , Reply# 10   12/30/2011 at 00:08 (4,494 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Thanks everyone! Chester Mike & Eddie, Yes that is Nate you see in the reflection as he peers at the under belly of the machine. Chester Mike, as I noted in the video, if the power goes off while the washer is filling, yes it will just keep on filling and eventually overflow and flood the place. Fred (Blackstone) Can you explain why that is, why the water does not stop flowing when the power goes out? What type of inlet valve does it use and how does it function? Thank you! Kevin |
Post# 565923 , Reply# 11   12/30/2011 at 08:16 (4,494 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The inlet valve is a mechanically operated valve that is opened by a cable from the timer control on top of the transmission. It is much the same as turning on a faucet in your home, it has to be closed again or the water will flow forever. On the washer the flow stops when the timer moves ahead automatically or if it is turned ahead by manually turning the timer control knob. If the power is interrupted the timer will stop moving and the water will keep flowing. I can imagine that this is one of many reasons why Blackstone went to an electrically controlled automatic washer designs after the model 350. |
Post# 565968 , Reply# 12   12/30/2011 at 15:02 (4,494 days old) by Blackstone (Springfield, Massachusetts)   |   | |
Thanks John for answering the question about water valve. I was starting to type a response, after having cleaned my keyboard, and discovered that some of the keys no longer worked. It's hard to type without being able to type an "n". Perhaps best advice is not to clean keyboard with Clorox disinfectant wipes!
John, you could be the designated Blackstone expert. Another reason for Blackstone changing inlet valves could be cost savings. The 350 valve is a block of solid brass, with machining for inlet and outlet. Much cheaper to make a plastic valve with minor amounts of copper wire coils. The old brass valves make great paperweights. |
Post# 565973 , Reply# 13   12/30/2011 at 15:35 (4,494 days old) by cornutt (Huntsville, AL USA)   |   | |
When the camera panned down the first time, I thought, "Why on earth is the motor running during fill?" I never knew that the motor drives the timer. Sounds like just about everything is mechanical on this machine. |
Post# 566006 , Reply# 14   12/30/2011 at 19:06 (4,493 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 566019 , Reply# 15   12/30/2011 at 20:58 (4,493 days old) by washerlover (The Big Island, Hawai’i)   |   | |
Post# 566469 , Reply# 18   1/2/2012 at 11:52 (4,491 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
All Washers and dryers with the Blackstone name on them were made by Blackstone, I am not sure about the spin speeds of the early 1960s machines but I never got the idea that they were very fast. The one thing that has not been mentioned about the 150-250-350 and 1960s solid tub Blackstones was thier gyroscopic tub balancing where the spin basket was supported at the top of the tub by a heavy rubber collar. This allowed very smooth spinning even with an off balanced load. |
Post# 566474 , Reply# 19   1/2/2012 at 12:26 (4,491 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 566558 , Reply# 20   1/2/2012 at 20:01 (4,490 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 566591 , Reply# 21   1/2/2012 at 23:28 (4,490 days old) by roto204 (Tucson, AZ)   |   | |
