Hi Everyone:
I know on my KitchenAid dishwasher(model KUDK)I can access the test mode by pressing Heat Dry, Normal, Heat Dry, Normal. Then Start cycles through the various test functions. Does anyone have a chart about the sequence of the various test functions or the service manual?
Bob
The troubleshooting/service procedures are on a sheet that is located either behind the door panel or somewhere in the lower area of the machine. Sometimes it is in a plastic pouch on the lower crossmember or behind the control panel. Some detective work should prove valuable to you.
See if this works for you.
