Thread Number: 38418
KitchenAid KDI-16 Detergent Dispenser
Post# 569910   1/19/2012 at 11:47 (4,470 days old) by SEAimperial ()
My KDI-16 is a real workhorse that's worked great for 42 years. Recently the detergent door has been a bear to keep shut over the main cycle well. It's got a button action in the middle of the door hinge that seems to help at times, though that's not consistent. The door works correctly during the cycle once I get it closed. I think it may be time to get a new spring (if that's what's used to keep the door shut) or replace the dispenser.
I'm having a time finding the part though. The detergent dispenser & gasket sub assembly with solenoid is part A-102830-1. I'm not sure if I need the whole thing or if just the body & lid sub assembly less solenoid, part M-83078, would do the trick. I'm attaching a link to the youserguide.com site where I found the parts catalog.
Any ideas on what I can try before replacing the dispenser? If I have to replace the dispenser, where can I find the parts?
Thanks for your input!
CLICK HERE TO GO TO SEAimperial's LINK
Post# 569940 , Reply# 1   1/19/2012 at 13:34 (4,470 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)
Betcha...
toploader55's profile picture
Stevet has one or Combo. ?
Post# 570140 , Reply# 2   1/20/2012 at 08:40 (4,469 days old) by stevet (West Melbourne, FL)
SOME DETECTIVE WORK NEEDED
Sorry, but the oldest and youngest detergent dispensers I have would fit from the 17 thru 23 series machines. Your dispenser was only used on the 15 and 16 series.
I would suggest that you remove the front panel of the door and inspect the action of the dispenser door shaft when you close it. It had a small latching mechanism on it that the solenoid would trip to release. It may have bent or wore out and is not locking well enough. IIRC, you may be able to flip the piece over and get another 42 years out of it!. Also, make sure that the dispenser is clean of residue either from deteregent or lime buildup so the door can go thru its full travel. Also, make sure there is no buildup on the outside as well.(meaning on the solenoid side of the dispenser)
John can verify this next thing,as far as what might fit in its place..I remember seeing Maytag dispensers of the same vintage that seemed to be the same as yours. They may be more readily available and may be able to be put in your original's place.
Post# 570149 , Reply# 3   1/20/2012 at 09:40 (4,469 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
KITCHENAID DW DET DISPENSERS 15-16 MODELS
combo52's profile picture
There were two different designs of solenoids on these dispensers, but the complete dispensers were interchangeable. You may be able as Steve suggests to fix the old one, other than that look for a good used complete dispenser.
Steve that's an interesting thought about using an early MT DW Det dispenser. I would be surprised if it fit as the KA disp fits in a pretty tight well in the door. The early MT dispensers had a 120 volt bi-metal and could work and the later models had a Bi Metal release that had to be wired in series with the DWs heater or Motor so these would be harder to use on a KA DW. The early MT dispensers were pretty unreliable so I wouldn't go to much trouble to put one of these in a good KA DW.
Post# 572312 , Reply# 4   1/29/2012 at 23:35 (4,460 days old) by SEAimperial ()
Vinegar Wash
I emptied the dw and ran it thru a full cycle with a couple cups of vinegar and no detergent. That helped somewhat. Must've had some liquid detergent residue preventing the dispenser door from staying closed. The button in the middle of the dispenser now pops up further. It still takes some finesse-ing to get it closed, but it's considerably easier. Thanks for the recommendations.
Post# 572356 , Reply# 5   1/30/2012 at 09:11 (4,459 days old) by neptunebob (Pittsburgh, PA)
neptunebob's profile picture
I have some KA16 parts including a dispenser so I could give it to you if you want.
Post# 760289 , Reply# 6   5/29/2014 at 18:40 (3,609 days old) by mistydawn ()
I have a KDR66 dishwasher looking for the dispenser part # A-102830-1
Post# 761280 , Reply# 7   6/3/2014 at 19:12 (3,604 days old) by chachp (North Little Rock, AR)
This one should work.
chachp's profile picture
This one is on eBay if you still need one and should work in your Imperial.
CLICK HERE TO GO TO chachp's LINK on eBay
