Thread Number: 38476
Late Seventies Maytag Set in South St. Louis |
Post# 570619   1/22/2012 at 23:51 (4,469 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
Asking $100.00 for this nice looking set. If I'm reading correctly the dryer is a DG408 built in December of 79. If I'm full of beans someone here will straighten me out.
CLICK HERE TO GO TO d-jones's LINK on Stlouis Craigslist |
Post# 570746 , Reply# 1   1/23/2012 at 14:35 (4,469 days old) by macboy91si (Frankfort, KY)   |   | |
This is the set I have, DE408 and an A407, both 1976 models. These are a good midrange set, and my favorite.
The dryer offers 2 temps (140 AND 150 woo hoo) and timed, fluff and regular and perm. press auto-dry cycles. The electric version isn't very fast but quiet and cavernous. It can hold 2 loads from the washer handily if you're willing to wait for it to dry. The washer is the entry-level big-tub machine, Fabric-Matic 1-speed. The washer looks to be an A407, it only has 3 temps but has 4 water levels. On this machine the HOT setting also does a warm rinse. The A408 had 4 temp buttons seprating out the warm rinse as a dedicated button. Washer has 2 soak cycles, a 30-minute timed soak that spins at the end and an "infinite" soak that agitates for a bit and then stops until you manually advance the machine. This machine has a hidden "dry agitate" section on the dial and it can be used as a suds-saver. -Tim |
Post# 570790 , Reply# 2   1/23/2012 at 17:56 (4,469 days old) by pulltostart (Mobile, AL)   |   | |
I have a very similar set - A208 washer and DG408 dryer, both from 1977. This is the washer that needs damper pads. At some point, someone got crazy with the 'spray n wash' and did a number on the console with overspray. I wish the consoles looked as good as Tim's!
This set needs a new home.
Lawrence |
Post# 572198 , Reply# 3   1/29/2012 at 16:21 (4,463 days old) by electronicontrl (Grand Rapids, MI)   |   | |
