Thread Number: 38619
Belts and other info on two different twins |
Post# 572986 , Reply# 1   2/1/2012 at 21:52 (4,460 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hi Diane, First, CONGRATS on getting the two twin tubs! Do you have or can you post any photos of them? Next, if you will post the 2 letters at the end of the serial number on the Maytag A50, I can tell you when it was built. Does the Hoover need a belt too? (I know the A50 does) The spinner belt (also drives the pump) on the A50 MAY be OK, try it first. I believe this belt, like the main drive belt on the older Maytag washers, is designed to slip a bit, so it may not be as bad as you think, IMHO. Tim (Macboy91si) is the resident Hoover "enthusiast" (in the US) and can tell you anything you want to know about your Hoover. Here is a little (boring?) video I shot of my Hoover and A50. Enjoy! Kevin |
Post# 573098 , Reply# 2   2/2/2012 at 13:51 (4,459 days old) by macboy91si (Frankfort, KY)   |   | |
So the Hoover has no belts at all? Is that correct? There are 3 belts on that machine, I can't understand how they would all be missing, they weren't known for breaking on these. Anywho to the question at hand, the Hoover 500 models use different parts than the later and more common square ones of the 70's. Picture would be helpful. If the machine is white with a turquoise control panel, it's a 0510, if it's Coppertone, it's a 0512 for future reference. Same machine mechanically. The pump and pulsator belt COULD be fabricated like Martin (Yogi) has done, but the spin belt is a very narrow v-belt and would have to be obtained, the spinner motor is torquey and aggresive and this belt sits in a deep groove. I don't know how well a cord-stock alternative would work here. These belts are non-existent for the most part, but Yogi has some tricks for making them, but I don't know if he has an older Hoover to try this on as the measurements of the belt would be different. Here are some Ebay links for the pump and pulsator belt if all else fails:
Pulsator Belt
Pump Belt
Old-Style Pump
I have some extra spin belts for these, but for the later models, which I THINK are a different length. Also before you do anything, check the pump pulley underneath and make sure it is still turning easily. This could have been one reason for the belts being missing. The pump can be had for this machine, but not cheaply, there is a link above for one. These also use a different pump than the newer ones. I'll keep an eye out for a spin belt and may try and make some cord stock belts later when I have access to my older Hoovers.
-Tim
Post# 573099 , Reply# 3   2/2/2012 at 14:07 (4,459 days old) by macboy91si (Frankfort, KY)   |   | |
The "sloppy belt" underneath the machine is just that a tension belt. This belt should be coarse and loose when the machine is not running. Have you plugged the machine in and tried the spinner and pump with a little hot water in it? The 2 things on the A-50 are the diverter plunger, which is connected to the wash/drain dial on the front and the polyurethane drive belt for the washer. Yogi has had success with the belt on the washer part, the originals are very scarce.
So if you put a little water in the wash tub of the machine and it starts filling the bottom of the spinner, then the diverter valve needs to be replaced. You can open the spinner lid and stick a butter knife (BE CAREFUL) in the slot at the front of the opening to start the spinner and watch it. If it has no spin mat the spinner will howl, that's air and nothing to be worried about.
Part# for washer belt is 251021 and the diverter plunger is 204316. AppliancePartsPro has it in-stock below:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-arm-assembly-item-number-ap4023730.aspx
Hope that's a start
-Tim |
Post# 573105 , Reply# 4   2/2/2012 at 15:11 (4,459 days old) by Yogitunes (New Jersey)   |   | |
here I am using 1/4" O-Thane hollow cording.......and a connector......this is usually used for sewing machines...but is holding up very well for these applications.....
any Sew n' Vac place should carry it........ MrMaytag/Ted has gotten solid cording, which you super glue together, which is really nice too......works out great for a pump belt on the Hoover as well..... the Hoover's spin can belt I got from PepBoys Auto.....not sure about all Hoover's, but my motor was adjustable for tension...... |
