Thread Number: 38642
Two Videos I found of People modifying their FL washer to use MORE water (Samsung) |
Post# 573216   2/3/2012 at 02:30 (4,459 days old) by mark_wpduet (Lexington KY)   |   | |
I came across these two videos of a Samsung FL washer modification. The 2nd video is a lady who decided she would also try it with her same model washer.
CLICK HERE TO GO TO mark_wpduet's LINK |
Post# 573217 , Reply# 1   2/3/2012 at 02:32 (4,459 days old) by mark_wpduet (Lexington KY)   |   | |
I like this lady! She sounds about as nervous as I would be if I were attempting this. She was saying her husband is going to KILL her is she kills the washer
Post# 573231 , Reply# 2   2/3/2012 at 05:48 (4,459 days old) by tolivac (greenville nc)   |   | |
Guess folks are finally getting sick and tired of washers that try to clean loads in only tablespoons of water--we need MORE of that universal solvent to get the job done!Bet soon the washer builders will put in pressure switches that don't have adjustment screws. |
Post# 573250 , Reply# 3   2/3/2012 at 07:28 (4,459 days old) by Yogitunes (New Jersey)   |   | |
Post# 573356 , Reply# 4   2/3/2012 at 15:54 (4,459 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
well here are my toughts on this if pepole went more water in there washer they should just buy a good old fashion 1970 to 1990 top loading washer i have a generation 1 whirlpool duet that uses little water and i get clothes clean as same as if i had bought a top load washer of the same year as i do not see anything wrong in having not much water my duet washer the way its made sends water inb the tub with detergent and the only time it has to had more water is to cooldown the clothes and also the risk of raising the water level could cause a)the washer to completly break down in other word drains the water from the machine and stop leaving on the counter display an error code or b)cause the machine not to start from the start. So i think its completly ilogical to raise the water level in a front load washer. this is what i think you can get clothes clean the same as if they where washe in a topload washer.
Post# 573370 , Reply# 5   2/3/2012 at 16:51 (4,459 days old) by mrboilwash (Munich,Germany)   |   | |
Post# 573371 , Reply# 6   2/3/2012 at 16:53 (4,459 days old) by mark_wpduet (Lexington KY)   |   | |
Did you hear the guy in the first video say that he has REALLY dirty clothes from his job & after running a complete cycle (before he did any modifications) that the water was still dirty draining from the washer on the second AND sometimes third cycle?
He didn't strike me as someone who had no clue how to do laundry. I don't know. But I do think there is a definite cut off point with the water and some of them have gone way too far....Not necessarily in the wash, but definitely in the rinses. It blew my mind with the thread about the roper rinse rash. I mean, it uses the MOST water in the wash cycle and less in the rinses. That's like A$$ backwards! I do know that I washed REALLY dirty caked with dried mud from 4 wheeling in a wet field, in my Duet.. Definitely the dirtiest clothes I've ever put in there since I had it. I ran soak first, then washed in heavy duty xtra rinse & everything came out really clean.........but my duet uses more water because I modified it like 5 yrs ago (not by much- perhaps 2 to 3 more gallons per fill)........and it hasn't done any damage to the machine & it really helped....though it doesn't use nearly the water he has his using. The water level he has in that video is way too high....but based on comments section, he has lowered it back to just to bottom of the door, which is better. Also, in the 2nd video, I thought the water level was PERFECT! That's the exact water level I tried to get in my Duet.....but I could never get it exact, so I left well enough alone |
Post# 573453 , Reply# 7   2/4/2012 at 00:02 (4,459 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Post# 573461 , Reply# 8   2/4/2012 at 00:51 (4,458 days old) by MattL (Flushing, MI)   |   | |
I judge the water level by the amount of lift. If there is too much water the clothes just slosh around and really don't get washed. |
Post# 573515 , Reply# 9   2/4/2012 at 11:15 (4,458 days old) by peteski50 (New York)   |   | |
Post# 573526 , Reply# 10   2/4/2012 at 12:15 (4,458 days old) by Yogitunes (New Jersey)   |   | |
there can be excessives in both directs....too much OR too little......and each washer is gonna be a little different.....but no matter what, there should be sufficient enough to splash around....one to clean and rinse the clothes effectively, and the other to keep the machine clean......
the solution to a clean machine is not running an empty machine, with additional cleaner......just wash in warm/hotwater, and enough of it....problem solved before it starts..... on my Frigidaire, once I increased the water level about 3 inches, one, it cleans better, and two, theres no balancing issues that it used to have......balance rotation to the left, and then to the right>>>>>>>>>and takes off high speed, for the full 12 minutes....clothes now packed to the sides of the drum, they never were when I first got it....... |
Post# 573530 , Reply# 11   2/4/2012 at 12:47 (4,458 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
When he drops the water valve flow restrictor into the machine is a perfect illustration of the reason to unplug any machine before attempting any service or modification. That was wildly irresponsible considering he's preaching to a largely unqualified audience.
Good points about the flow restrictor and the seal and bearing. Does this Samsung have a temperature control? Removing one restrictor could cause a huge imbalance in warm water temperature and there is no reason for a faster fill. The washing ability of the machine is indeed hampered by too much water. The clothes getting clean depends a great deal on the lift-and-drop action of the drum. I experimented with adding water manually through the dispenser drawer in the Duet I had, and as mentioned above, cleaning performance dropped off dramatically with too much water. Rinsing, soaking, etc. is another matter but too much water can quickly reach a point of diminishing returns in a front-load washer. Pete is right, I would have raised the water level to just below the door boot. With the machine unplugged. |
Post# 573742 , Reply# 14   2/5/2012 at 15:58 (4,457 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
In my humble or not so humble opinion, the washer in the first video that "Tony" modified has WAAAAAY TOO MUCH water in it! IMHO that water level will severely shorten the life of the shaft seal, bearing and the machine. Not only that, but the mechanical agitation and cleaning ability has been reduced because the the clothes are now just "rolling around" in the water. No more "lift and drop", no more actual "tumbling". It's like putting your clothes in a large bucket, filling it with water and just sloshing it from side to side.... that is NOT going to get your clothes clean.
The water level in the 2nd video is, in my opinion, a MUCH better balance between more water and the tumbling action needed for good cleaning, though it was under loaded.
My 2009 Kenmore Elite FL (last of the Whirlpool built washers) has an electronic (circuit board) water level switch and cannot be modified like this Samsung could.
If "Tony" wants THAT much water when washing, he should return the machine and buy a top loader.
Kevin |
Post# 573743 , Reply# 15   2/5/2012 at 15:59 (4,457 days old) by Yogitunes (New Jersey)   |   | |
Mine is still within warranty.....actually I have a 10 year warranty, 6 more to go......after getting mine, and complaining to the company about the low water use, they sent a guy out several times, to which there is no adjustment he can make......and the company is satisfied with washing a 4 towel test load with that low amount of water, NOW, if YOU can make Frigidaire give me a refund, let's do it, because they are only offering 50.00 coupon towards another machine that they sell......
so if I am stuck with this machine....hell yes, I am modifying it!...to work the way it should.....effectively!!!....... what they don't know won't hurt them! agreed that guy added too much water, but a few more gallons is exactly what some of these machines need.... I am placing a VOTE with my money.....I complained to Frigidaire, and word of mouth advertising, and refuse to buy another one of their machines!...... Who's making the customer happy....this guy?.....or the company?...... the company should be paying him!!! |
Post# 573847 , Reply# 17   2/6/2012 at 05:23 (4,456 days old) by mark_wpduet (Lexington KY)   |   | |
Yes......Just a "FEW" more gallons?
I agree! Tony had his filled with way too much water. The second lady had the water level (to me) is what I would call perfect. And even the water at "the level she had hers" is still significantly LESS than a conventional TL by a good amount! I think what bothers me most about HE FL washers is the rinsing. In a perfect world of HE Front Load Washers, it would be LOW water wash (more concentrated detergent and just saturated clothes)....Then.... rinses with rinse levels at about the level her washer's water level set on. Still using MUCH less water than a conventional TL, but still very effective in washing & rinsing and definitely NOT overkill on the water.... Like I said, I tried to get the water level in my Duet at about what she had hers on, but I couldn't. It was either one extreme of the other. What amazed me in my duet was when it was filling with water 1/2 way up the window, it didn't leak a drop! Luckily, I did get a couple of more gallons for each fill. I did see a difference, especially in towels. I noticed that even with the little bleach I used, that whitest whites with extra rinse still had somewhat of a bleach smell. When I made this adjustment 4 or 5 yrs ago, just the additional couple of gallons of water with much more sloshing sound and that was the first thing I noticed. Very little if any bleach smell on whites. Obviously me making that adjustment hasn't harmed my machine since it's approaching seven years now and clean as a whistle inside. I keep hoping that when mine finally dies that the manufacturers would add deeper rinse options to the HE FL machines....but so far, they haven't. I think WP DUET did for a short time, but they took that away. Another thing I never understood! A few years ago when Whirlpool introduced the Duet Sport ( a smaller, cheaper version of the Duet) it used a very deep rinse on the heavy duty cycle, almost half way up the door! Made no sense to me that one of their versions of Duet did that, yet the more expensive one didn't. Sorry.....I'm beyond rambling at this point....Too much coffee |
Post# 573849 , Reply# 18   2/6/2012 at 06:00 (4,456 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Hey Guys
Well I read this thread and watched the videos. The first guy has no idea. That is far too much water. The second lady well she got it good. If you watch the video I've attached of my Hotpoint front loader on a synthetic cycle (perminent press to you guys across the pond) this cycle uses a similar water level without any modification. However the cottons (Normal cycle) does not but it will refill until everything is completely saturated. I don't like high wash water levels. A good detergent in a small amount of water is much more potent than in a massive amount of water combined in motion with a decent tumble speed achieves excellent results in warm water alone without pretreatment. I have 2 small kids who have thrown everything at this machine and it always comes good. I do like your US front loaders and would love to one day get the chance to see and use them. I like the LG's I spent a damn lot of money of one which is now the other side of the country sat in my ex's kitchen! grr! I also like the duets as with everything I see differences of opinion which leads me to my point what works for one person doesn't always work for another but I'd definitely say a water level higher than the door glass in the main wash phase is unnecessary. The rinse phase however....now that's another story!!!! Darren CLICK HERE TO GO TO newwave1's LINK |
Post# 573850 , Reply# 19   2/6/2012 at 06:18 (4,456 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
Post# 573916 , Reply# 20   2/6/2012 at 14:40 (4,456 days old) by Yogitunes (New Jersey)   |   | |
we do modifications all the time, as needed...some good, some bad......trial and error......
I have a 1993 Ford Taurus SHO, already a powerful machine, had it modified, by the dealer, a factory power chip....increased my horsepower, torque, and mainly gas mileae drastically....... believe me, these machines are built and designed to withstand a little extra kick, and NO, were not talking of a spin speed from 1200rpm to 4000rpm.....but if a little more speed, a gallon or two more of water, can make a huge difference in cleaning and performance...plus satisfy your needs...whats the harm?..... even my Maytags have the 50hz set up for increased speed....... even a new SpeedQueen top loader....how many of us have raised the water level back up to where it belongs....all we did is reverse what the manufacturer did......and your gonna tell me that I am exceeding what this machine was originally designed to handle...... |
Post# 573991 , Reply# 22   2/7/2012 at 05:13 (4,455 days old) by mark_wpduet (Lexington KY)   |   | |
I found the older thread showing the Duet Sport during rinse. This was not even the top of the line Duet. Check out the factory set rinse level on the heavy duty cycle. You may have to scroll the see the picture. No clue why Whirlpool did this for only one model of their FL machines.
Post# 573997 , Reply# 23   2/7/2012 at 06:52 (4,455 days old) by Logixx (Germany)   |   | |
who has the german version of a Whirlpool Duet.
Hello there! It has a high-efficiency and high-performance cycle that cleans a heavily soiled and tightly packed load according to the European Energy Label. This cycle runs at 140F with two rinses for almost four hours. Now, if I deselect the preset options like Eco and Heaviest Soil, it already shaves one hour off that time. I can also run a full load (lightly soiled) at 140F in little over two hours when I select another cycle. Or I can run a 2/3 full load in one hour on Daily Wash, which would be the exact equivalent to the Duet's Normal cycle. It really depends on which cycle and options I want. By the way, I played with some new washer at Sears when I was in LA and some of these new Allergene cycles and all also take over two hours. Water levels on my washer are usually low. For a normal rinse, the water covers the perforated part of the tilted drum. Enough for me and if I need extra rinsing, I can add up to two extra rinses. The Direct Inject really makes short work of saturating the whole load. Alex |
