Thread Number: 38656
DEC 606 Maytag Dryer |
Post# 573487 , Reply# 1   2/4/2012 at 05:20 (4,463 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 573503 , Reply# 2   2/4/2012 at 09:36 (4,463 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Can you describe the noise a bit more completely as well as where exactly you think it's coming from?
I have a fair amount of experience with the Halo-of-heat dryers. Hopefully the noise is coming from one of the rear pulleys or maybe even from the cabinet being out of alignment which will cause the drum to rub. It's also, unfortunately, possible that the main drum bearing has dried out and it starting to rub, there can also be issues with the blower having too much play on the shaft that can eventually lead to problems. |
