Thread Number: 387
My old school dishwasher
Post# 47873   10/26/2004 at 18:52 (7,111 days old) by compwhiz ()
here it is
were getting rid of it though
Post# 47889 , Reply# 1   10/26/2004 at 21:45 (7,111 days old) by appnut (TX)
appnut's profile picture
Looks like an 18" Kenmore D&M design dishwasher.
Post# 48120 , Reply# 2   10/29/2004 at 17:50 (7,108 days old) by Compwhiz ()
Whats D&M?
Post# 48124 , Reply# 3   10/29/2004 at 18:11 (7,108 days old) by Partscounterman (Cortez, Colorado)
D & M
stands for Design and Manufactering- They built darn near everybodys dishwashers through the 50-70s.They built dishwashers for Sears Kenmore,Magic Chef, Tappan, Preway, Caloric, Speed Queen, Modern Maid,I think some Kelvys, Roper and anyone else that wanted to have a "me too" dishwasher in their appliance line up. These are the folks that brought up the much-loved Roto-Rack-the round upper rack that spun around past the sprayer
Post# 48168 , Reply# 4   10/30/2004 at 03:47 (7,107 days old) by kenmore1978 ()
school dishwasher
so why is it being replaced?
Post# 48182 , Reply# 5   10/30/2004 at 14:01 (7,107 days old) by Compwhiz ()
Because we dont have much time and money
The door springs have broke
the bottom lid has popped open
It leaks
its a mess
the pump is wearing out
Post# 48893 , Reply# 6   11/9/2004 at 10:21 (7,097 days old) by kenmore1978 ()
Time and money
Those are a weak spot in those machines, but cheap & easy to replace
You mean the access panel? Just a couple of screws
It leaks
from where? door? new gasket, easy. Hoses? Only 2, pump to drain and pump to spray tube/upper spray arm. easy replacement. Motor seal? Replaceable from inside machine at which time you would replace the impeller, too
its a mess
"pump" in this case is just an impeller kit, replaceable from inside the machine and not expensive.
These machines are do easy and cheap to work on, it's amazing.
Post# 48930 , Reply# 7   11/9/2004 at 17:24 (7,097 days old) by Compwhiz ()
ok
IT was assembeled with glue
it leaks at the bottom of the door
The impeller seems to be okay it squeeks when the pump shuts off
In order to fix it, we will have to pull the counter top off. The idiots who installed our tiles put the tiles right in front of it
Post# 49061 , Reply# 8   11/12/2004 at 07:14 (7,094 days old) by kenmore1978 ()
repairing D & M dishwasher
What was assembled with glue?
door gasket, and there's a retrofit part that goes inside the door that addressed that problem
Normal characteristic of the ceramic/carbon motor shaft seal, most all of them make that noise. Not a sign of failure.
I've seen that problem before,you're right, what idiots, a friend of mine has a dishwasher with the same problem, trapped in the hole. But, you'll have that problem even with a new dishwasher
Post# 49104 , Reply# 9   11/12/2004 at 22:35 (7,094 days old) by Compwhiz ()
The bottom lid that has popped open
ok
ok
were going to have to raise the counter top
also the inside of the dishwasher door is rusting
Post# 49150 , Reply# 10   11/14/2004 at 01:02 (7,092 days old) by kenmore1978 ()
school DW
Well, it's death knell is the door rusting. That part IS replaceable, but it's fairly expensive (maybe not as much as a full-size machine, but somewhere close to $100) The bottom of those is a weak spot on those machines, my '78 KM version was on it's 3rd liner, though this 3rd liner was plastic, they don't make the porcelain anyones anymore (though that may not be true for the 18" machines). Everything else is minor stuff.
