Thread Number: 38716
Maytag model #A107A, Series D3, Serial #825502 CT |
Post# 574399 , Reply# 1   2/8/2012 at 12:43 (4,458 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 574486 , Reply# 2   2/8/2012 at 19:12 (4,457 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Lay the washer on its side and take off the belts [ they just lift off no tools needed ] and turn the large center pulley by hand and see if it turns easily in the counter-clock wise direction and while doing this the agitator should be moving. If it is very hard to turn you have a transmission that is binding and it would need to be replaced or rebuilt. This is normally the end of a good old washer, but if you want to consider repairing there is an excellent post about rebuilding a MT washers transmission, it takes an hour just to read it LOL. |
Post# 574733 , Reply# 3   2/9/2012 at 18:06 (4,456 days old) by Sibyl ()   |   | |
thanks to combo52 in Beltsville, MD. . . WE'LL GIVE IT A GO!@!@ FIRST THE BELTS AND THEN THE TRANNY!! THANKS AGAIN!! WE'LL NEED SOME LUCK SIBYL |
