Thread Number: 38761
Belt Life ? |
Post# 575076 , Reply# 1   2/11/2012 at 08:17 (4,429 days old) by jmurray01 ()   |   | |
Oh, and it is only used about once a week, if that. |
Post# 575084 , Reply# 2   2/11/2012 at 08:58 (4,429 days old) by electron1100 (England)   |   | |
I have had one these for the last 5 years, i keep it in my loft (it just fitted through the hatch) where it is very cold or very hot, i have never changed the belt (they are available), it has been a reliable workhorse, i modified mine to have reverse tumble which was a bit of a job but worth it in the end. I vent it out of the loft window when i want to use it As far as rear venting via the filter goes thats the design, they use whats known as a "halo of heat" system wherebye air is drawn in through the back at high pressure, this air can only escape by passing over two spiral heating coils that sit around the front of the drum and then it goes out via the fluff filter through the outlet on the back, it works well because you even heat passing through the load being dried I hope you enjoy this machine Gary |
