Thread Number: 38834
Speed Queen AWN432 Question |
Post# 576095   2/15/2012 at 13:17 (4,452 days old) by Pulsator (Saint Joseph, MI)   |   | |
My boyfriend's mom recently ordered a Speed Queen AWN432 topload washer per my recommendation. I know that Speed Queen had to lower the water levels to meet the government standards and I also know that by tweaking that wonderful little set screw on the water level switch, those stupid reduced levels will go away forever. My question is, how does one access the control panel on these? I know it's probably simple but I don't want to break something on her new machine! Are there clips to be popped on the front of the control panel? Screws? Does the back of the control panel remove to access the switch?
Also, she requested the red dial inserts, how are these installed? Does the machine come with a set of new dials or do the inserts pop out? (I made sure those were put in the order, they were $5 extra.)
Thanks! -Jamie |
Post# 576231 , Reply# 1   2/15/2012 at 21:39 (4,452 days old) by rp2813 (Sannazay)   |   | |
Post# 576232 , Reply# 2   2/15/2012 at 21:44 (4,452 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 576236 , Reply# 3   2/15/2012 at 21:55 (4,452 days old) by LLMaytag (Southern California)   |   | |
Post# 576245 , Reply# 4   2/15/2012 at 23:18 (4,452 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 576344 , Reply# 5   2/16/2012 at 14:14 (4,451 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 576437 , Reply# 6   2/16/2012 at 20:01 (4,451 days old) by nmassman44 (Brooksville Florida)   |   | |
There are I believe 4 screws on the top rear. Remove those and the top plate comes off. There are a few screws holding the panel to the back panel. Remove those and pull the panel up and forward. The water level switch is the 2nd one and you will see the screw. Turn it to the back r clockwise. About 2 full turns should do it.
