Thread Number: 38835
Maytag A106 Hums but wont spin or agitate |
Post# 576175 , Reply# 2   2/15/2012 at 16:56 (4,446 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 576191 , Reply# 4   2/15/2012 at 18:20 (4,446 days old) by Yogitunes (New Jersey)   |   | |
Post# 576202 , Reply# 6   2/15/2012 at 19:06 (4,446 days old) by Yogitunes (New Jersey)   |   | |
insulation can be as cheap and easy as a water heater blanket......insulation for keeping the heated water hot, and the noise to a minimum.....around 20.00
the corkscrew agitator unfortunately only fits the tall tub if you gonna use the dispenser..... maybe you wanna go with the 50hz pulley/belt setup.....add more kick to the wash, and higher spin speed....... tub light can be added, but you will have to change out the top outter tub, or cut the slot and glue in a piece of plexiglass...... for best fit and options......your better off finding a broken 806, and change things over......I think theres a shop around here that has one, and he wants to part it out......I'll get back to you on that one..... |
Post# 576207 , Reply# 7   2/15/2012 at 19:30 (4,446 days old) by queeny77 (BERWYN, ILLINOIS)   |   | |
Post# 576228 , Reply# 9   2/15/2012 at 21:27 (4,446 days old) by lebron (Minnesota)   |   | |
Post# 576283 , Reply# 13   2/16/2012 at 07:00 (4,445 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Jay there are several possibility's as to why the motor is not starting reliability,
1 be sure you got a anther 1speed motor not a 2sp motor they wire up differently and do not always interchange well on MT washers, the data label will list the motor sp and it should only say 1725 not 1725/1140.
2 you can add a motor start capactor to any MT washer motor these can help.
3 But most likely you just need another motor, one SP MT washer motors are still plentiful and cheap, I often don't even bother to save them from all the MT stack L-1000s that we scrap each month and these all have the 1sp motors in them. |
Post# 576299 , Reply# 15   2/16/2012 at 08:49 (4,445 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Jay -
I am not as proficient with Maytags as I am Kenmores, but I've bought a number of motors on eBay for my machines and just to have for stock when the price is right. There are good deals there, and some not good deals as well. I searched 'Maytag washer motor' and got a slew of options with tremendous variety. There were Neptune motors mixed in with motors for the Norge built machines, motors for machines of the same generation as yours, and even some Whirlpool built direct drive design motors. My best suggestion is to find out what the current replacement motor part number is for your model, according to Maytag. Take that number, exactly, and search only that on ebay. See what you get. If MT motors are stocked differently in 1-speed and 2-speed versions, and you have a one-speed machine, the replacement part number if searched correctly should yield only single speed options. Then I believe I would consider the motor you have as potentially bad. If all it takes is a nudge to start it, something is wrong with your installation or the motor itself. Since you only purchased this on 2/3/12, I would contact the seller if you think the motor is faulty and work on getting your money back. It should not be difficult if the motor is non-functional. Then start over with a motor that you know is proper for your machine and see what you get. Gordon |
Post# 576302 , Reply# 16   2/16/2012 at 10:12 (4,445 days old) by cfz2882 (Belle Fourche,SD)   |   | |
i would check out where the extra red wire is meant to go-washer the replacement motor came from may have used a seperately located start capacitor or something... sounds like the original motor was GE and the replacement emerson. |
Post# 577275 , Reply# 22   2/20/2012 at 15:52 (4,441 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 577366 , Reply# 24   2/21/2012 at 00:10 (4,441 days old) by pdub (Portland, Oregon)   |   | |
Take a look at this thread which details the complete rebuild on a Maytag.
CLICK HERE TO GO TO pdub's LINK |
Post# 577368 , Reply# 25   2/21/2012 at 00:21 (4,441 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 577387 , Reply# 26   2/21/2012 at 03:55 (4,440 days old) by alr2903 (TN)   |   | |
Your link to the ebay ad, under item specifics reads, for dryer, maybe thats explains the red wire? Then again if it reversed with the small load, for spin it's not a dryer motor. alr This post was last edited 02/21/2012 at 04:12 |
Post# 577490 , Reply# 28   2/21/2012 at 17:07 (4,440 days old) by goatfarmer (South Bend, home of Champions)   |   | |
