Thread Number: 38876
Rust on ge ff inner tub |
Post# 576715   2/18/2012 at 01:38 (4,450 days old) by doug (West Virgina)   |   | |
I bought some CLR lime, calcium, and rust remover cleaner today because my filter flo has some rust in the bottom of the inner tub. I wanted to get some of ur guy's opinions on how to clean the tub with the CLR. i read on the back and it said to pour 1 and a half cups of the CLR into the washer and run it through a cycle then run a rinse through to clean the CLR out of the washer this makes since but i dont know if i should let it soak or scrub it with a sponge or something with a little bit of a texture to it. And i wasnt sure if it would hurt or damage the tub, like maybe take the shine finish off. Maybe someone can help me out, maybe one of u have used this before in a washer.
Post# 576718 , Reply# 1   2/18/2012 at 02:25 (4,449 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 576723 , Reply# 2   2/18/2012 at 03:21 (4,449 days old) by doug (West Virgina)   |   | |
