Thread Number: 38892
Roper washer problem |
Post# 576964   2/19/2012 at 09:38 (4,448 days old) by norgechef (Saint George New Brunswick )   |   | |
My grams 15 year old roper washer started spinning and draining at the same time in may 2011 and were wondering if its gonna die soon? |
Post# 576991 , Reply# 2   2/19/2012 at 11:32 (4,448 days old) by norgechef (Saint George New Brunswick )   |   | |
Well i think the clutch is on its last leg because lately when it does the spin drain its sounds like somethings scraping and sometimes a buzzing noise......how much would it cost in total to get a clutch and a gearbox put in by a repairman? |
Post# 577004 , Reply# 3   2/19/2012 at 12:34 (4,448 days old) by DirectDriveDave ()   |   | |
While I am not sure of the exact amount, a repair man would be very expensive. If you are up for it and it is within your pricing means. I would do it yourself. |
Post# 577024 , Reply# 4   2/19/2012 at 13:31 (4,448 days old) by norgechef (Saint George New Brunswick )   |   | |
I think i will just get a new top load washer, are the newer hotpoint/ge washers any good? if they are junk i think i will just get another roper because i see them in a store around where i live......to be honest i think those are the only top loaders left around where i live........... |
Post# 577047 , Reply# 6   2/19/2012 at 15:24 (4,448 days old) by norgechef (Saint George New Brunswick )   |   | |
No it says no stores in your area, what about the basic hotpoint/ge's then because they are cheap, if not then what other top loaders? |
Post# 577049 , Reply# 7   2/19/2012 at 15:26 (4,448 days old) by DirectDriveDave ()   |   | |
Aww man, well then that i'm not sure of, I hope others here can give ya some advice. |
Post# 577054 , Reply# 8   2/19/2012 at 15:49 (4,448 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Repairs are not that expensive on a DD machine. |
Post# 577085 , Reply# 9   2/19/2012 at 18:55 (4,448 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Norgechef, you are not that far from the Maine border at Calais, ME/ St. Stephen, NB. crossing. There are 2 Speed Queen dealers somewhat close to there if you were really interested in getting one. One is in Bangor and the other in Ellsworth, both about 90 minutes east from the border. It would be a day trip up and back for you. But I dont know what the duties would cost to cross the border (because you really cant hide a washer) and now that we must have a passport to cross you have to weigh the options and see if it was worth it.
Post# 577087 , Reply# 10   2/19/2012 at 19:00 (4,448 days old) by norgechef (Saint George New Brunswick )   |   | |
Well your probably right about it costing allot to get one of those......whats so bad about Hotpoint/ge washers, there is one at a local home depot and it doesnt look junky to me............ |
Post# 577094 , Reply# 11   2/19/2012 at 19:33 (4,448 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
If I HAD to buy a new washer I would definitely spend the extra and get a Speed Queen from either of those dealers as they both are good people and take care of their customers. But I can understand what it would cost to transport it across the border. From what I have seen and heard from alot of people that have bought ANY of the newer ones, both top and front loaders, their life, cleaning action and dependability is alot shorter than the older ones. I just cant reason how a cup of water can clean a load of dirty laundry in temped down temperature water. If you had a good one "out in your woods" that might be salvagable for Gram, I'd get it out, clean it up and give it to her.
Post# 577201 , Reply# 15   2/20/2012 at 10:17 (4,447 days old) by macboy91si (Frankfort, KY)   |   | |
What is your deal with the new Roper machines? In several posts you have swept people away with a broom from these. Your argument is that the water level is too low on the rinse when it has been repeatedly said (See ROPER RINSE RASH) that that can be adjusted by a VERY easily accessible switch inside the control panel. It would be much easier than opening up a transmission or even replacing the transmission. The Roper/Inglis is the only models really left of the Direct Drive platform, it would seems that one would want to go with one of these or a SQ, but given the cost differential, I would consider the Roper for sure and set the switch. More so when given the ~$350 difference in price
To the original poster, I suppose you can get anything you want, a SQ is a great machine and Qualin has listed some vendors for you. We don't know your budget, tinkering ability or any other factors. The Roper that is being repaired/replaced lasted 11 years and was a cheap machine to begin with so in my eyes it has been a success. I would expect that a new Roper to last a similar amount of time, and for under $400 that is a great run. I think the SQ/Heubsch machines are also wonderful, but command a higher price accordingly. After seeing the various failures of GE laundry products post-1995 I can safely say that I would never buy one. I think with these machines' reliability is truly a crapshot. If I were in the under $400 range, a WP built Inglis or Roper would get my money hands down.
-Tim |
Post# 577202 , Reply# 16   2/20/2012 at 10:27 (4,447 days old) by neptunebob (Pittsburgh, PA)   |   | |
If the "neutral pak" is the only thing wrong I would go to www.whirlpoolparts.com... and get the transmission. One of us can direct you in how to repair your machine. I doubt if it is that difficult. It might run at least another 11 years and will rinse better.
Post# 577223 , Reply# 18   2/20/2012 at 12:16 (4,447 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Also to the first poster, there are about 25 million DD washers in use as we speck that are no longer doing the neutral drain. This does NOT hurt the clutch at all, this washer was engineered to spin with a full tub of water, save your money and just keep using it.
As far as new, the Roper and Adrimal DD machines are a good low cost choice if you change the water level. I would avoid any new GE or Frigidaire laundry appliances, the GE top loaders are about the most unreliable and short lived washers on the market today. |
Post# 577246 , Reply# 19   2/20/2012 at 13:46 (4,447 days old) by norgechef (Saint George New Brunswick )   |   | |
Why does everyone say those are so great? |
Post# 577259 , Reply# 20   2/20/2012 at 14:53 (4,447 days old) by macboy91si (Frankfort, KY)   |   | |
They are REAL commercial machines (like you would find at a coin laundry) in a home package. High quality materials, stainless tub and absolute rugged build. These machines are design to be abused day in and out with minimal repairs and when repairs are needed many common parts are easily accessible from the front.
For the enthusiast, the SQ name carries a long history of neat machines and the famous long, slow stroke action similar to the 50's through 80's Maytags as well as others.
I think the big thing is quality for most, they are very solid machines.
-Tim |
Post# 577260 , Reply# 21   2/20/2012 at 14:54 (4,447 days old) by DirectDriveDave ()   |   | |
Speed Queens are built in the US and have an excellent reputation of being reliable/very long-lasting. I have no knowledge on Huebsch. |
Post# 577264 , Reply# 22   2/20/2012 at 15:02 (4,447 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 577267 , Reply# 23   2/20/2012 at 15:15 (4,447 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 577273 , Reply# 24   2/20/2012 at 15:32 (4,447 days old) by norgechef (Saint George New Brunswick )   |   | |
Im quite interested in getting one now......i know commercial machines cost thousands of dollars so how much would one of these cost? |
Post# 577351 , Reply# 25   2/20/2012 at 22:10 (4,447 days old) by Kenmore71 (Minneapolis, MN)   |   | |
John, in the experiences I have had with a 2003 Whirlpool branded DD machine and later a 10 year old Roper Branded DD machine, when the neutral drain fails and it goes directly into spin with a full tub of water it actually throws some water up and over the sides of the tub. It's not a lot of water, maybe a gallon or so. It is however enough to be a problem unless the machine is either in a basement on a non-carpeted floor or actually sitting in one of those washing machine "catch" basins that I have seen in some new construction.
Both of these machines were being used for "commercial" type purposes and always washing large loads of towels and overalls so the water level was almost always set at the highest level. Do some of the tub designs on these DD machines prevent water from being thrown out of the tub at the beginning of the spin? In terms of the clutch, I have never seen a clutch go bad because of a failed neutral drain mechanism. That said, I would never pull a DD transmission off of a machine to replace the Neutral Drain Pak without replacing the clutch band and spring as well as the Direct-Drive Coupler. In my observations, by the time the Neutral Drain fails, the plastic on the clutch band is usually pretty worn as well. And, while you're that far, it seems silly not to spend the extra $20 to replace the drive coupler, especially if you know that it is original. Has that been your experience in the field? |
Post# 577464 , Reply# 28   2/21/2012 at 14:59 (4,446 days old) by norgechef (Saint George New Brunswick )   |   | |
Im pretty sure i will just get a Hotpoint/Ge machine because i live a few hours away from the nearest Huesbch dealer, not sure yet..... |
Post# 577475 , Reply# 29   2/21/2012 at 16:13 (4,446 days old) by norgechef (Saint George New Brunswick )   |   | |
Im going 2 fix it...........can somebody give me the link 2 a site where i can find these parts cheap: Clutch, transmission/gearbox and motor coupler, since its so old im gonna replace the coupler 2..... |
Post# 577543 , Reply# 31   2/21/2012 at 21:14 (4,446 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Mark K, your experiences with DD washers that leak water while spinning and draining at the same, I have NEVER seen. WP has built over 100 million DD washers to date, and if all a customer had to do was lift the lid at the start of drain which immediately throws the washer into spin, caused the washer to leak a gallon or any amount of water on the floor I think we would have all heard about this problem. This is ignoring the fact that there are about 25 million DD washers working now that DO NOT do the neutral drain any longer and are not leaking.
As far as weather to replace the clutch and drive cupping while doing other major repairs, I do these on a case by case basis. If the clutch is slightly worn I generally do not replace it. If the washer does not have the new style metal reinforced drive cupping I would almost always replace it. |
Post# 577546 , Reply# 32   2/21/2012 at 21:57 (4,446 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Maybe this only happens on high speed with a truly FULL tub of water but I have personally witnessed the water running out of the machine and after i changed out the ND pak the problem disappeared. Maybe this was a problem unique to the the WP branded commercial machine that I was the custodian of over the last 8 years. Maybe the tub cover on this particular machine wasn't sealing properly. I suppose there could be any number of reasons for the leaking water but I can say that I NEVER leaked when the ND was working properly unless you opened the lid at the beginning of a spin cycle.
Happy Mardi Gras! |
Post# 577547 , Reply# 33   2/21/2012 at 22:00 (4,446 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 577550 , Reply# 34   2/21/2012 at 22:09 (4,446 days old) by supersurgilator (Indiana)   |   | |
I second that, and what about all of the early DD models that do a spin drain, we have one. It has never ever leaked any water on the floor. |
Post# 577634 , Reply# 35   2/22/2012 at 13:38 (4,445 days old) by macboy91si (Frankfort, KY)   |   | |
I forgot to place the foam seal back in the tub after cleaning and managed to get some water spill, but never aside from that.
Norgechef, if there is a local repair or parts supplier, I bought a good used one for about $60, and usually these places have them by the dozen. They even threw in one with a 6-pad clutch for little to nothing, I don't think they generally come with the clutch (easy to swap though). I can see where it may sound daunting, but these machines are so simple to work on, even with a minimal understanding of mechanics you should be good. You don't even have to remove the tub to get it out. Someone here can help you, but I'd say $75-$100 and you'll have another machine ready to go.
Also as mentioned, you could continue using until it won't spin anymore. I've run into issues where the neutral get stuck and the machine has to be stopped/started several times for the cam to drop.
-Tim |
Post# 577636 , Reply# 36   2/22/2012 at 13:54 (4,445 days old) by runematic (southcentral pa)   |   | |
I agree with John. I have NEVER seen a DD washer that leaked while spin-draining a full tub o' water. We sell a lot of these washers used and it just doesn't happen. When we get these washers ready for sale, we will fill the tub w/ h2o and cleaner. We let them soak an hour or so & then drain them before removing the inner basket to scrub away all the gak. A lot of times we will happen to advance the timer into spin and do a spin drain. The water stays in the tub and not on the floor. Now, we've oversuds these things while cleaning them and that'll get water on the floor.
Post# 577649 , Reply# 37   2/22/2012 at 16:09 (4,445 days old) by Kenmore71 (Minneapolis, MN)   |   | |
All I can say is that my Whirpool did leak when it was full of water and clothes and then went immediately into spin. The water was on the floor running to the drain every damned time. It wasn't a lot, probably only a few quarts. I saw it with my own eyes and the paint on the concrete is damaged in a way that shows the route it took to the drain time and time again.
I will concede that it's possible that this particular machine had a bad upper tub gasket or that plastic top of the tub was not seated properly on the tub itself (or maybe even had a crack that I didn't notice) in such a way that allowed it to leak when it would spin with a full tub. Taking the top of the cabinet off of a DD machine alone is such a damned effort that it was easier to rebuild the transmission. I never went through the effort to see if the basket cover wasn't seated properly. |
Post# 577691 , Reply# 38   2/22/2012 at 19:51 (4,445 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Mark I am not doubting you for one minute that you had a WP DD washer that leaked when it did not neutral drain. But as we all should consider that one experience is not statistically accurate and there was something else wrong with the washer you were using. WP would never let a machine out of the factory if it would leak if you lifted the lid and closed it again.
When I remove a transmission from a DD washer I always remove the cabinet and top assembly first, yes it can be done without doing so but it is much harder not to have complete access. Not removing the cabinet and top first would be like doing open heart surgery on someone while they are still wearing a suit LOL. |
Post# 577726 , Reply# 39   2/22/2012 at 21:56 (4,445 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 578238 , Reply# 40   2/25/2012 at 19:40 (4,442 days old) by norgechef (Saint George New Brunswick )   |   | |
I saw one today at a local futureshop and i thought about getting until i lifted the lid and it has that new low water usage thing on the rinse, how do you tweak with the watet level switch? and could i brake it in the process? |
Post# 578539 , Reply# 43   2/26/2012 at 20:00 (4,441 days old) by norgechef (Saint George New Brunswick )   |   | |
When i go to remove the softener dispenser off the agitator its stuck on and wont budge, underneath the dispenser it feels welded on or something......please help |
