Thread Number: 38958
Morning |
Post# 577782   2/23/2012 at 08:18 (4,439 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 577805 , Reply# 1   2/23/2012 at 09:33 (4,439 days old) by turquoisedude (.)   |   | |
Post# 577807 , Reply# 2   2/23/2012 at 09:39 (4,439 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 577808 , Reply# 3   2/23/2012 at 09:42 (4,439 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 577810 , Reply# 4   2/23/2012 at 10:02 (4,439 days old) by bajaespuma (Connecticut)   |   | |
Post# 577823 , Reply# 5   2/23/2012 at 11:43 (4,439 days old) by mickeyd (Hamburg NY)   |   | |
Post# 577824 , Reply# 6   2/23/2012 at 11:52 (4,439 days old) by lebron (Minnesota)   |   | |
Post# 577843 , Reply# 7   2/23/2012 at 13:38 (4,439 days old) by Yogitunes (New Jersey)   |   | |
Post# 577846 , Reply# 8   2/23/2012 at 14:16 (4,439 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 577919 , Reply# 9   2/24/2012 at 10:03 (4,438 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 577926 , Reply# 10   2/24/2012 at 11:27 (4,438 days old) by mickeyd (Hamburg NY)   |   | |
so many of us firmly believed that you somehow pulled a rabbit out of your hat, either acquiring or making a golden pulsator. It seemed impossible that smoke stains could paint so perfectly. Then with all of Louis's commentary, it took me forever to accept that the smoke did it.
Only when you showed the big bottom ring where the creases were gray, did I believe. It's too bad you couldn't have shellacked her to keep her gold. |
Post# 577943 , Reply# 11   2/24/2012 at 13:59 (4,438 days old) by macboy91si (Frankfort, KY)   |   | |
You know, I've had old fill hoses for the old Hoover machines do this. They turn a golden sort of color from non-use and as the water soaks back in they again return to the grey color. I wonder if that golden color on the pulsator was nicotine or just the rubber's reaction to being dry for so long. On the 2 hoses I have, no deterioration has been observed, just a color change.
-Tim |
Post# 578071 , Reply# 12   2/25/2012 at 07:34 (4,437 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 578129 , Reply# 13   2/25/2012 at 12:42 (4,437 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 580332 , Reply# 14   3/4/2012 at 18:57 (4,429 days old) by electronicontrl (Grand Rapids, MI)   |   | |
