Thread Number: 39021
BlueTurquoise Lady Kenmore 6508993 |
Post# 578581 , Reply# 1   2/27/2012 at 01:46 (4,413 days old) by rp2813 (Sannazay)   |   | |
Post# 578585 , Reply# 2   2/27/2012 at 02:57 (4,413 days old) by ames ()   |   | |
Somebody painted the front white to match their old washer (with a roller), that thing is true blue all the way through. If I had motivation I'd try and take the white paint off. |
Post# 578588 , Reply# 3   2/27/2012 at 03:29 (4,413 days old) by rp2813 (Sannazay)   |   | |
Post# 578628 , Reply# 5   2/27/2012 at 09:11 (4,413 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 578648 , Reply# 6   2/27/2012 at 10:13 (4,413 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Eddie - This is a 1965 Lady Kenmore. The maching washer was indeed an alphabet washer with the Roto-Flex agitator. I have the pair in Coppertone.
Here's a pic of the washer. Ames - This dryer doesn't have manual selections for drying times, or for heats. You select the dryness you want, and just leave the dial there permanently, or change it when you want more or less dry items. The machine will do the rest itself. The soft heat feature will adjust the heat downward as things dry so things don't get baked when they are mostly dry. I do have a manual for this model which I may be able to photocopy... Gordon |
Post# 578657 , Reply# 7   2/27/2012 at 10:48 (4,413 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 578777 , Reply# 9   2/27/2012 at 18:46 (4,413 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This dryer was a transitional year for WP built dryers, if your dryer is electric and the lint filter is only about 1 foot long it does use about 25% more power than a new electric dryer. If you have the later version with a lint filter that is closer to two feet long it is just as efficient as any electric dryer built today. And if the dryer is heated by natural gas it doesn't matter as gas dryers are so cheap and efficient that it doesn't make much difference. |
