Thread Number: 39172
Question about suds saver and how it worked
Post# 580747   3/6/2012 at 09:30 (4,423 days old) by PassatDoc (Orange County, California)
I grew up in a house built in the 1930s, so I presume the original owners of the home (we were owner #2) had wringer washers. There was a laundry sink at one end of the laundry room, and the washer exhaust hose was clamped to the sink. Of course, given the age of the house, there was no drain pipe built into the wall, as far as I recall, and I definitely remember seeing used water from the washer empty into the sink.
Question about suds saver feature, which we never had. I understand the concept, that the hot sudsy water from the wash cycle would be pumped/drained into the sink, and then sucked back into the washer for the second wash cycle. However, what then happened to the rinse water from the first wash cycle?? Wouldn't that dilute or cool down the saved hot sudsy water in the sink? I could see having a dual exhaust hose system, with one hose for wash water only and a second hose for rinse water only, but then you'd need either a divided laundry sink (one half for wash water, one half for rinse water) or else an arrangement whereby hot, used wash water would sit in the sink, waiting for the next load of wash, and then rinse water would be ejected into a drain pipe in the wall (which our laundry room lacked, I remember seeing the used water pump into the sink, which was a large single sink, not a double sink with a partition).
I am missing something here?
Post# 580752 , Reply# 1   3/6/2012 at 10:01 (4,423 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)
Suds savers
wayupnorth's profile picture
Yes, you would need 2 ways for the wash and rinse water to go. Those with just one tub could retrofit a sort of standpipe over the drain to hold the wash water in the tub and drain the rinse down the middle tube into the drain. I vaguely remember Sears selling this as an option on their laundry sinks in a real old catalog.
Post# 580764 , Reply# 2   3/6/2012 at 11:22 (4,423 days old) by limitededition ()
laundry sinks
Those laundry sinks can still be purchased, I have one from Sears around 1956 and Sears also sold them again before the Catalog went out. They can still be ordered on line and at the Home Depot the sinks are basically the same Metal cabinet with storage underneath, the tubs held about 21 gallons and with thestand pipe installed it allowed the excess water to go down the stand pipe and also hold the rinse hose so as to not dilute the wash water. This allowed the heavier soils to settle to the bottom of the tub and as the long hose was about an inch off of the bottom of the tub it did not allow the heavy soil to return to the washer for the next load.
Post# 580854 , Reply# 3   3/6/2012 at 17:56 (4,423 days old) by polkanut (Wausau, WI )
polkanut's profile picture
The circa 1922 house I grew up in has a concrete double tub laundry sink and my Mom had/has suds-saver machines.  She uses the half closest to the washer for saving the wash water, and the other hose is a bit longer to reach over to the other half of the sink for the rinse water discharge.
Post# 580941 , Reply# 4   3/6/2012 at 23:39 (4,423 days old) by arbilab (Ft Worth TX (Ridglea))
arbilab's profile picture
How does the machine suck the saved suds back into the tub? I know how Easy Spindrier did it, didn't involve sucking, just moving the hose. But once the suds are in the sink how do they get back to the washer?
Post# 580943 , Reply# 5   3/6/2012 at 23:45 (4,423 days old) by neptunebob (Pittsburgh, PA)
neptunebob's profile picture
I believe it used the same pump as was used to drain the water, that is in Kenmore/Whirlpool models.  On the models equipped there was a setting on the knob called "Suds" There is a solenoid valve to switch between the 2 hoses.  I believe the valve moved to the pump's intake, sucking up the water.  I don't know if the pump would work if you took the hose out of the water and it lost its "prime" but most of the time people left the hose in and it pumped back just fine.  Then the timer would proceed into the normal wash cycle.
Post# 580954 , Reply# 6   3/7/2012 at 01:09 (4,422 days old) by petek (Ontari ari ari O )
petek's profile picture
We had the same cement twin tub laundry sinks as well. I don't think the washers drain/intake hose reached quite to the bototm of the sink, it always left about 2 or 3 inches of water when refilling , maybe on purpose since the dirt would have settled and you didn't want it having that sucked back up into the washer for another load.
Post# 580958 , Reply# 7   3/7/2012 at 01:41 (4,422 days old) by arbilab (Ft Worth TX (Ridglea))
I know SS was an optional festure on many machines but I never saw one except the manual twintub method.
Post# 580985 , Reply# 8   3/7/2012 at 07:58 (4,422 days old) by ingliscanada ()
Suds Return
I believe there is a little diaphram that shoots some air out the suds hose to prime and create a siphon, assisted by the pump, to cycle the suds back into the tub. On my family's old Inglis (WP), when the suds cycle was selected, I remember seeing bubbles coming from the bottom of the hose just before the wash water started re-entering the washer.
Different makes have their type of function on the suds-return cycle. On all perforated tubs, I believe, the machine will kick into the agitation cycle while the suds enter the tub from the bottom, meeting with the oscillating agitator. I know that at least WP and Maytag worked that way. On some solid tubs, it worked like the fill cycle, where the suds would come out of a flume similar to the fill flume via a small pump, while the machine was motionless (eg Frigidaire). The solid-tub Easys filled while agitating.
I don't know how every make did it; can someone give more examples? Like Speed Queen or Franklin?
Gary
Post# 581004 , Reply# 9   3/7/2012 at 09:49 (4,422 days old) by PassatDoc (Orange County, California)
The divided sink--or the standpipe alternative--would definitely make sense, and might explain why our laundry sink was not divided. The house was built in the mid-1930s, so the first owners likely used a wringer washer. If they did a "manual" suds saver, as many wringer users used to do, most likely they would have drained it into a laundry tub on the floor and then must have used the laundry sink for draining rinse water. I don't think the sink was large enough to have accommodated a large pail or tub (large enough to hold the wash water from a wringer), which would be another option: drain used hot sudsy water into the pail/rub, drain rinse water into the sink around the pail/tub.
I made a mistake in my first post: we were the THIRD owners of the house when we moved in in 1961. The people we bought it from were empty nesters with all their kids in college, I think either they downsized or maybe moved due to a job transfer, but as a five year old child I remember touring the house with my mother and there were no children present (not even big teenagers or college-aged students). I think it was the walk-through because I do remember the realtor introducing us across the fence to the next door neighbors who had kids about our age.
Anyway, I don't know for certain whether the laundry room sink was original, or whether the second owners installed it post-War. The laundry room had the original cabinets that matched what was in the kitchen---but my mother very quickly did a full remodel of the kitchen. Whereas nothing was altered or upgraded in the laundry room. The sink was wall-mounted or freestanding, it was not built in to any cabinetry. To the right of the sink stood the washer and dryer, and above them hung a pair of wall mounted cabinets that matched the cabinetry on the other side of the room (a solid wall of built in cabinets and drawers, lots of storage). I'm not positive if the sink was original though.
Post# 581029 , Reply# 10   3/7/2012 at 11:56 (4,422 days old) by mickeyd (Hamburg NY)
"If they did a "manual" suds saver, as many wrin
mickeyd's profile picture
Hi Jim,
This is new to me. What have you seen, observed, or heard? My experience has been that if rinse tubs or sinks were lacking, you would wash the three or so loads, drain the washer, and refill to rinse, one or more times. Everything being regional, your method is totally novel to me and very interesting.
This post was last edited 03/07/2012 at 12:13
Post# 581038 , Reply# 11   3/7/2012 at 12:49 (4,422 days old) by whirlpolf ()
that old 80 series Kenmore DD
that I own seems to feature a hidden suds saver. It is a regular Shredmore (NOT "shred" as I have found) with a Dual Action Agitator, black and golden backsplash and some wannabe wood decoration foil glued to it.
Between the first cycle (regulars/cotton) to the last one (delicates/wool), there is the OFF section.
But it looks like this: OFF, then some 2-3 timer steps with no indication at all, then OFF again.
This looked odd to me and I tried to get these mysterious blank minutes working. They did! The machine went on in wash mode (not the other direction of the motor which would be spin & drain), but it got working with no water at all. (All other cycles go via the level switch, thus waiting for the tub to be full).
I figured that this must be some recirculation thing, I tried to drain it into some tank (a garden watering tank that is, we don't have laundry sinks here, at least not of such a large volume).
Et voilą! Provided the drain hose end is underwater in the full tank, the machine would suck back its contents to the wash basket. I quickly learned to keep the lid closed as the water touching the swinging wash fins, it would easily be splashed all the way up to walls and ceiling. Later, when the fins were covered, watching was possible again. Once I pulled the suction hose end out and above water level in the tank, I had to reprime the pump again by doing some quick drain seconds, then turning to "secret refill" again.
This machine does not have any visible indication of a suds saver, nor does it feature some diverter valves or double hoses. Yet I was glad to have found out. I reckon a real suds saver would let you choose which cycle water to save and which to suck back automatically, but this is just a vague guess.
PS: That slurping sound along with the hefty splish-splash is just unique! Love it.
Post# 581046 , Reply# 12   3/7/2012 at 13:13 (4,422 days old) by mickeyd (Hamburg NY)
HI Joe, the exact same thing happened to me, only in a diffe
See for yourself. We're quoting each other. Excuse the slow, funny voice, surprised on an Early Saturday morning. Here it is with all the splashing,
CLICK HERE TO GO TO mickeyd's LINK
Post# 581049 , Reply# 13   3/7/2012 at 13:28 (4,422 days old) by DirectDriveDave ()
I still love that classic video!
Anyway, I only found this out too about our Whirlpool DD a couple of months ago.
I believe it was BrianL who had that thread about the DD he managed to find (which is very close to ours). Either he or someone else asked about that asterisk in the OFF section of the time. When it was told that it was for suds return, I was shocked realizing that our machine actually had this option all along. I guess you can still learn something new on a machine you have had for 21 years. heh.
Post# 581058 , Reply# 14   3/7/2012 at 14:17 (4,422 days old) by whirlpolf ()
Goodness, Michael /Mickey: Exactly!
Sounds like you are in my wash cellar! Exactly THIS sound!
Besides: My Kenmore looks pretty much like the one one the right side of your turquoise agitator one.
(I can recognize the McGuyver woodgrain stuff backspash).
This is "shuckah-shuckah" all along splashing the whole room, then "womble-womble /rumble-rumble" (when filled). Oh how I love a good old drenched T-shirt washday ;-) *spring time is coming!*
Thanks for posting, this video is what I meant (nail on the head vid).
Need these goggles, quick! Pass them! *gg* ;-D
Kudos!
Joe
Post# 581064 , Reply# 15   3/7/2012 at 14:43 (4,422 days old) by BrianL (Saddle Brook, New Jersey)
brianl's profile picture
Hey Dave, it was me who found the DD WP pair. I do like that I could perform a suds return, be it a manual one. I don't mind much though as that is half the fun.
Post# 581066 , Reply# 16   3/7/2012 at 14:48 (4,422 days old) by Kenmoreguy64 (Charlotte, NC)
Kenmores and the suds saver...and machines that will return
kenmoreguy64's profile picture
Sears did indeed offer a special hose configuration for people wishing to use a suds saver operation with a single well sink.
My home from 1967 through 1977 was built in 1967, with a single well utility sink next to the washer. All of the houses in our neighborhood from this era were equipped this way. Many if not most of the neighbors had suds model washers. In the two houses across the street were a 1963 Kenmore 70 in one, and a 1962 Kenmore Lady K/800 in the other. Both had Kenmore's drain hose adaptors for single sinks. The machine operates the same as a double sink installation, except the rinse water hose has an adaptation in which the end of the hose is a metal standpipe which fits via a rubber gromment in the end directly into the sink's drain, which acts as a stopper. This plugs the sink to hold the wash water which comes out of one discharge/recharge hose as always in a suds model.
The rinse water however is pumped through the rinse hose into this makeshift standpipe, and is drained through it, right through the holding wash water, directly into the sink's drain. The standpipe in the rinse hose has vents/emergency drains at the top which prevent accidental over-filling of the sink as the excess water drains into these holes and down the center of the standpipe.
To reclaim the wash water, at least for Kenmores and Whirlpools, some machines have a suds section at the beginning of the pre-soak or normal wash cycle, while others have the suds return isolated between two off sections. Certain non-suds models will operate in the suds cycle, others do not.
As to some WP-built machines having a reverse pumping & agitate mode, this is very common in DD washers and can be found on earlier models as is stated above, in the large OFF between Pre-Wash and Normal/Cotton Sturdy. Others have a little horseshoe printed on the console in the Heavy Duty cycle or similar in which a "dry agitate" is allowed, which turns off the circuit to the mixing valve and pressure switch, and simply activates agitation in one speed or another. I believe that in all or nearly all DD washers, the pump in agitate mode is operating backwards, which then allows it to become a "pump in" device vs. a pump out. This will duplicate the art of suds return, though the machine does not have the ability to separate wash/rinse water storage, etc.
This same ability is present in CERTAIN belt-drive machines as well. Many have dry agitate portions toward the end of the Normal wash cycle which can be used to return water to the machine, but not all. This however can ONLY be done with machines using the original style 2-port pump or the 4-port. With either pump, the only way that the machine will pump-in water is if there is a direct pump to cabinet drain hose. Machines with self-cleaning lint filters in line between the pump and the drain will NOT return wash water because the reverse function of the pump is already utilized to recirculate water during agitation through the filter. This becomes a closed system in agitate which deactivates access from the drain hose.
Also, for the literal millions of belt-drives built in the 1970s and 1980s which used the newer design 2 and 3-port pumps (these have the auxiliary triangular shaped 'compartment' on the side of the pump housing) -- these will never return water into the machine as they are not capable of reversing water flow -- water flows through them in one direction only and the flapper inside, which reverses flow in the old pumps, simply opens or blocks water flow like shutting or opening a big door. Suds versions of ALL these models always made use of the older style pumps.
Thus, to return water into a belt-drive that is not properly equipped as a suds-saver, you need a simple drain system AND the old-style pump, both.
Gordon
Post# 581072 , Reply# 17   3/7/2012 at 15:30 (4,422 days old) by PassatDoc (Orange County, California)
@mickeyd
The only "old fashioned" thing about our laundry set up in the 1930s house was that the washer exhaust hose emptied into the large, single laundry sink. There was no drain pipe in the wall directly behind the washer. Either mom's 1958 GE Filter Flo did not have suds saver, or at least she never used.
I never owned or operated a wringer. The only time I saw one in operation was a wringer unit at our tennis club as a child (to wash towels) and one in my grandparents' garage (in disuse, no longer the daily driver, but they never bothered to donate it or have it hauled away).
I have patients who grew up on a farm in Iowa without electricity, but they had a gasoline powered wringer washer. Evidently they heated up a large quantity of hot water, poured it in the washer, and washed the whites and linens. They then drained the wash water to a large laundry tub on the floor/ground. They would do a rinse with clean cold water, drain it, and run those clothes through the wringer before hanging them on a line. The used wash water in the tub would then be added back to the washer for the second load, sometimes with some additional heated water if it was getting tepid. Basically the wash temp dropped with each load, so whites and linens were washed first, then they moved on to colors. According to the patients, there was a lever they would pull to activate the gravity drain. This being a gasoline fired unit, there was no pump, only gravity drain. However, with the alternative being to wash by hand, they felt they were on easy street. ;)
Post# 581078 , Reply# 18   3/7/2012 at 16:05 (4,422 days old) by mickeyd (Hamburg NY)
Thanks, Jim
So I imagine they used a bucket to return the sudsy water to the Maytag. Interesting. I'm sure others have done it as well.
If you really like washers and washing, you might want to find a good, working, conventional washer, as they're properly called.. When my friend Dennis comes by again with his HD flix maker, I'm dying to show Underflow Rinsing in the 66 Visimatic, which goes to your point about rinsing in a wringer washer, still a rare practice. I've modified the machine to have a water inlet system, and with the drain open on slow speed, lint and other unwanted collectibles get sucked under the agitator and down the drain.
Jim, although I don't do it all the time, I genuinely enjoy doing laundry in a conventional washer, and hope to show it in detail in the coming months. It is easier than people imagine and tons o' fun.
Post# 581081 , Reply# 19   3/7/2012 at 16:32 (4,422 days old) by in2itdood ()
Newer suds saver sinks (mid 60's-70's)
here is a pic of a suds sink ... minus the center drain tube
Post# 581173 , Reply# 20   3/8/2012 at 07:11 (4,421 days old) by polkanut (Wausau, WI )
re: Bob & Pete,
Bob, you are correct in that the return hose does lose it's "prime", at least it does on our Maytag Dependable Care suds-saver machine.
Pete, you too are correct about susds return hose lengths.  The hoses as a rule are made to not touch the bottom of the sink were the wash water is being held so as to not draw up anything that has settled on the sink bottom.
The link below is to E.L. Mustee & Sons website where you can still buy suds tubs.  The models they show don't appear to have an integrated stand pipe though.  According to the website, Home Depot is one of their retail outlets.
CLICK HERE TO GO TO polkanut's LINK
Post# 581174 , Reply# 21   3/8/2012 at 07:32 (4,421 days old) by alr2903 (TN)
It worked well enough, if you sorted like you were using a wringer washer, for instance white sheets and towels  followed by white cottons, then followed by colored towels, you had to keep in mind if you had used bleach or not..  If you had a mechanic or farmer in the family your could wash the lesser soil load first and have the badly soiled in the "save" sink for a longer soak while the first load finished.  you had to watch what you were doing, re: the additives used in the first load. If you had limited amounts of well or cistern water it could be a real good routine.  City folks unless very frugal would be less likely to purchase the suds saver when i reality they could probably of gotten away with good laundering using the system to refresh light soiled office wear. My brother farms and mechanics i could not imagine saving wash water from his clothes. alr
Post# 581183 , Reply# 22   3/8/2012 at 09:04 (4,421 days old) by PassatDoc (Orange County, California)
@MickeyD: the folks in question had no indoor plumbing. I am assuming the water was hauled in from a well pump, heated on a stove, and then added to the washer, which was located on an outside porch because of the gas exhaust fumes. There were no pipes or laundry sinks or running water of any kind. They were simply grateful not to have to wash by hand with a board and pail.
Post# 581196 , Reply# 23   3/8/2012 at 11:35 (4,421 days old) by mickeyd (Hamburg NY)
Dave and Joe, sorry I forgot to thank you !
I got so caught up on Jim's tale of the gas Maytag and suds-saving that I overlooked acknowledging your graciousness. So thank you both.
Post# 581197 , Reply# 24   3/8/2012 at 11:40 (4,421 days old) by DirectDriveDave ()
You're very welcome!
Curious though, how come you haven't done much with youtube since then? (so it seemed on the channel)
Post# 581204 , Reply# 25   3/8/2012 at 12:14 (4,421 days old) by mickeyd (Hamburg NY)
My friend Dennis films the movies and the last few times he came over with his camera, I wasn't up to filming. The last one we made was over a year ago. I'll get back to it.
And now back to the Laughingsuds.
The Frigidaire could lose its prime easily, too, but the KM/WP's did not. They pretty much wrote the book on suds-saving; in fact, WP would not market their Automatic until they perfected the Suds-return. And as has been seen on this forum lately, the early machines had Suds-returns as a standard feature, built into the wash cycle, without any special separate switches. The Suds were returned and the wash cycle proceeded without interruption, automatically. You didn't have to move the dial as is the case on some later models.
The suds hose was indeed designed to reach the bottom of the tub, but the siphon would break to prevent the last half inch or so from entering the washer. Some hoses were cut at an angle at the bottom, other created an angle by the placement of the hose, but I saw many that were nearly flush with the bottom, and a few that sucked up all the water. Most loads did not have muck or stuff in the washing liquors, as they were once comically called. You'd save the grime for last, and not save that water by removing the plug from the sink.
The early WP/KM machines did not allow the save or drain/dispose option. All wash water was pumped out the suds hose, and all rinse water, including the post-wash spray rinses, came out the L-shaped drain hose; hence, all the valve clanging that so many of us came to love. If you didn't want to save the suds, you simply left the stopper out of the sink. There was no way to make all the water come out of one hose, as was possible in later years. I think GE's earliest suds-returns did have the save/drain/drain/ feature.
For me, few washer functions are as dramatic or as satisfying as watching the original suds-returns at work.
EDIT: PS, Dave, the other flix are on another channel. Dennis had trouble finding the first channel so he made EasySpin 1.
Post# 581224 , Reply# 26   3/8/2012 at 14:15 (4,421 days old) by DirectDriveDave ()
Oh that explains it!
I'll check them out when I have the time.
Post# 581332 , Reply# 27   3/9/2012 at 06:19 (4,420 days old) by polkanut (Wausau, WI )
MickeyD
You've hit the nail on the head with your explanations.  All of Mom's GE's had the option of saving or draining suds, and from what I remember you had to move the dial once the suds were returned to continue with the regular wash cycle.
Yesterday at an estate/tag sale there was an 80's Maytag set for sale and the suds-saver washer was located next to a concrete double tub laundry sink.  It had the suds hose on one side of the sink, and rinse discharge hose on the other side.  It was exactly the same set-up as what my Mom had/has.  Didn't see what the asking price was for the set though.
Post# 581397 , Reply# 28   3/9/2012 at 12:08 (4,420 days old) by mickeyd (Hamburg NY)
Hey Tim
My Aunt Alice had a pink GE in her kitchen with the alum hook drain hose in the sink. Curled up behind the machine was the attached suds hose. Thank God I never touched the lever. "Drain" was unmarked and in the middle, between SAVE and RETURN if my young memory is accurate.
It was a TOL, mid-to-late 50's with many metal levers in a row with salmon tabs. She was really strict then, and had I flooded the kitchen, I might not be here right now. ;-D
Post# 581529 , Reply# 29   3/10/2012 at 11:41 (4,419 days old) by polkanut (Wausau, WI )
The suds hoses on Moms 2 GE's had a wire wrapping around them, and they were cut at an angle at the end to help break the suction before the tub was completely emptied.  Hers and our Maytags have slanted hose ends also.
When we were first married some friends of ours were over one evening to see the house.  When we mentioned that we had received a suds-saver machine from my parents as a wedding gift, her comment was "how cheap can a person be."  I think it's great to have one as a daily driver, and it helps save on the water bill.
Post# 581532 , Reply# 30   3/10/2012 at 12:02 (4,419 days old) by mickeyd (Hamburg NY)
For the record, Tim.
I've heard that solid tub GE's returned the water to the outer tub, then arriving in the inner tub via the filter-flo. Is that correct? And that the agitator was in motion. Do any of the perf tub GE's have suds-savers? Thanks.
Your friends do not realize that it's only been in the last half century or so that people dumped perfectly clean, hot, soapy, cloroxed water down the drain after one use. Before that, it was unthinkable.
Slowly, we can assemble a comprehensive history of Suds-savers. We have the WP/KM, the MT and with you, the GE, in place. But many of the solid tubs of the 50's like the Norge are still out there.
Post# 581550 , Reply# 31   3/10/2012 at 14:15 (4,419 days old) by suds14 (Pittsburgh)
Speen Queen suds return.
My aunt had a Speed Queen with suds saver. When she turn the switch to return, I can remember the suds water coming in just like the fresh water did. This was amazing to me becasue my mom's, my grandma's and the neighbor who I always helped on wash day all had Whirlpools with suds saver and the the washer agitated and brought the water through the bottom.
Mickey, I still cannot just wash a load and let the water down the drain. I need to get one of my suds models uo an running. Right now I am washing and I save the water move the hose to second tub and put the water back in the washer with a bucket for each addition load I do.
David
Post# 581559 , Reply# 32   3/10/2012 at 14:45 (4,419 days old) by mickeyd (Hamburg NY)
David
It would be cool to know how it came in thru the fill flume. We learned the other day, that SQ used a smaller separate pump the way Frigidaire did, and we could tell from seeing Patrick's machine that it operated through the 4 minute fill, just like Frigidaire. But this is cool news. While Frigi had a separate flume, your SQ was routed right in with the fill flume and probably aerated too. How exciting! So that's the last piece in the SQ version of the Suds-return. The more we know, the better it gets.
David, depending on what machine you are currently using, you may be able to siphon the water back into your machines, until you get one of your suds machine back on line.
Post# 581692 , Reply# 33   3/11/2012 at 10:14 (4,418 days old) by polkanut (Wausau, WI )
MickeyD,
Yes, it is true that the wash water in the 1967 GE was returned to the tub via the Filter-Flo with the agitator in motion.  Mom's circa 1984 GE suds-saver had a perforated tub, and the suds came in from the bottom.  When the tub was about 1/2 full the Filter-Flo pump would kick in while the suds were still coming in from the bottom.
Post# 581704 , Reply# 34   3/11/2012 at 11:46 (4,418 days old) by mickeyd (Hamburg NY)
Polkanut
That must have been really cool: suds coming in from the top and the bottom. Love to see that. Leave it to GE for drama, as if the mini-basket fill were not enough with all that fury as the filter-flo fills the dancing tub. Chubby Checkers and Let's Do the Twist.
Another piece, Tim, thanks. Amazing.
Edit PS: You're the first person I've heard tell of the perf tub GE suds. Wonder how many are out there.
This post was last edited 03/11/2012 at 12:04
Post# 581714 , Reply# 35   3/11/2012 at 12:57 (4,418 days old) by mickeyd (Hamburg NY)
Excuse me, Tim, er..... um.....not the twist, but the
POLKA{#emotions_dlg.Washer-1}
Post# 581878 , Reply# 36   3/12/2012 at 07:29 (4,417 days old) by polkanut (Wausau, WI )
I don't know how many GE suds-savers may still be out there, but I do know that in 1998 when we were shopping for our current Maytag Dependable Care set, the appliance store had to special order the washer because this was when Maytag was phasing suds-savers out of production.  My wife has already said that she wants to keep the washer going as long as possible because she grew up in a wringer washer household.  For her, saving wash water is the norm.  YAY!!!
Post# 581881 , Reply# 37   3/12/2012 at 08:03 (4,417 days old) by ingliscanada ()
GE & WP Suds Return
From the descriptions above, GE's suds-return cycle is much like that from Whirlpool. WP also agitates as the suds comes up through the bottom, then as the level rises, the water starts coming out of the waterfall filter. Then it also has that dual-action fill. I'll bet the GEs must've been very splashy during the suds-return with that fast agitation!
David, thanks for the info on the SQ suds-return cycle. I wonder if GE and Easy were the only solid-tub washers which had an agitated suds-return cycle. Maytag AMP, and many other solid tubbers, must've had a neutral top-fill suds-return cycle, since they had no recirculation-type filter systems. It seems that the Westinghouse top-loaders were never available with suds-saver. I remember the Canadian Vikings from the 60s, with the Franklin mechanics and solid tub, were available with suds-saver. Has anyone seen an old Franklin suds-return cycle in action? If it's the agitated type, it must've looked funny with the indexing tub dry agitation with the suds coming in!
Gary
Post# 581928 , Reply# 38   3/12/2012 at 12:23 (4,417 days old) by mickeyd (Hamburg NY)
Ditto.
Gary, the Maytags returned the suds from the bottom of the tub while agitating exactly like the non-waterfall WP/KM's. Geoff has an MT suds and there is a video of it. No surprize that Maytag imitated Whirlpool's perfection of their well-researched, tested and simplified system. Petek has cited the video of this.
The first WP/KM's did not recirculate but indeed returned suds, a standard feature then.
Post# 581979 , Reply# 39   3/12/2012 at 16:36 (4,417 days old) by suds14 (Pittsburgh)
Mickey
I have a Frigidaire and sometimes it will siphon the water but not always. When my mom replaced her Maytag she bought a GE and I showed her how to save the water and how to siphon thet water back in. She is so happy it always siphons the water in because she cannot lift the buckets and she has always had a suds saver. washer until now.
David
Post# 582120 , Reply# 40   3/13/2012 at 11:52 (4,416 days old) by mickeyd (Hamburg NY)
Dave, it happened to me too. "Sometimes it will siphon t
If your Frigi is a uni- multi- or roller-matic, make sure you've got enough water in the outer tub to get the siphon going. Just let the tub fill for a few seconds, couple quarts should do, throw the water, then start the agitation till the gushing water is strong--only seconds--and stop the agi/pimp. The siphon should be perfect. And the hose has to be secure. If it's a standard hose, you have to secure it to the bottom of the sink. Ours was easy because the sinks had a sliding lid, so you'd just pull the hose into the sink till the neck fit against the bottom, then slide the lid across and lock it in. Excuse me if you already know this. If it's a perf tub Frigi, I have no experience there.
Post# 582156 , Reply# 41   3/13/2012 at 14:24 (4,416 days old) by akronman (Akron/Cleveland Ohio)
1-18
akronman's profile picture
The 1-18's with perforated tub will also suck suds back in. I just wired around my water level switch to get a dry agitate. The 1-18 does require the "pump priming" of 10 seconds of fill, then immediate spinout, then I flip my switch to dry agitate and immediately get the suction going. Do it all on low speed, it works for me. The 75 Filter-Flo also requires the pump priming 20 seconds of work, while my "monkey-rigged water level switch suds machines-dry agitate" 79 Maytag and 60-WP both almost always suck immediately in dry agitate, especially the 'Tag, never a problem..
I do not own any genuine suds machines, but I have rewired and gotten all to work so far. Someday I'll find a real one, I hope.
My 78 Norge, I mis-wired and am currently getting agitation that starts as fresh flume water enters, I need to splice into a different water level switch wire for try #2, dry agitate. But I did at least shut off water valves, and yes it sucks back the suds with no priming. Soon I'll try wiring attempt #2.
While I wish all my machines were truly automatic suds machines, I have found easy ways to get them all to be "manual suds savers." For hobbyists like many of us, I find the once a week of evening of 4 machines with one wash water to be a fun and busy chore, swapping hoses from tubs to drains and such. But many would prefer a real automatic suds machines like many from the 50's, I don't blame them.
My only problem----whites! I start with very hot water, and Biz and OxiClean and powder detergent, and let them soak, but I am afraid of Clorox because the next load isn't white. If I do occasionally add Clorox, which I like for whites, that's the one load where I do not save suds. Am I a chicken about "used" Clorox damaging the next load? With summer coming, I do lots of white socks, Tees, etc, more than winter.
Post# 582211 , Reply# 42   3/13/2012 at 18:02 (4,416 days old) by suds14 (Pittsburgh)
My Frigidaire is from 2001. What gets me if I am outside hanging clothes and I do not get back down the cellar before the rinse fill the water is siphoning back in, but when I want it to, is siphons only a little back and stops. Akronman I soak my whites fisrt in warm bleach water then make fresh hot water to wash then save that water for as many loads as I need.
I am so glad this topic is running, I didn't realize how many of us like the suds savers. Most people think I am crazy and am using dirty water. My rags which are washed after black clothes are still whiter than my sister in-laws whites and she uses clean water all the time.
Post# 582232 , Reply# 43   3/13/2012 at 20:27 (4,416 days old) by badgerdx ()
Fascinating stuff. It explains the two concrete washtubs next to the washer and the extra hose when I was a child (Childhood washers: 63 Kenmore 70 series and a Wizard Citation Imperial)... Of course, as an adult who's an equestrian with gardening and stonemasonry as a vocation, the LAST thing I WANT to do is save those nasty suds...
Post# 582319 , Reply# 44   3/14/2012 at 08:43 (4,415 days old) by PassatDoc (Orange County, California)
more details re: gasoline powered wringer washer in Iowa
The couple from Iowa were in the office last week. He grew up on a farm. She grew up in town and always had electricity (she doesn't remember not having electricity). They are in their early 90s.
He said that water for the washer was heated on their wood-burning stove in a large copper vessel normally used for butchering pigs. The water was then re-used for a series of washes on wash day. The wood-burning stove had an auxiliary water tank, about five gallons, that kept a small quantity of water at hot temperature for washing hands, faces, etc., but it was insufficient to fill the wringer washer. Because of the gasoline fumes, the washer had to be outside on the porch. Rinse water was obtained from a well hand pump and hauled over to the washer.
His wife recalls an electric wringer washer. Her house had indoor plumbing. I forgot to ask her if they had central water heaters then or whether they had to heat water on a stove. My guess is that in the early days of central hot water, people ran into supply problems (i.e. hot water ran out) and that part of the impetus for suds saver was not simply to save water/energy but to avoid running out of hot water before the wash day was over.
Post# 582576 , Reply# 45   3/15/2012 at 08:07 (4,414 days old) by polkanut (Wausau, WI )
My Grandma Wilde was born in 1903, and grew up on a farm west of Wausau which was homestead property.  They finally got electricity in the mid 1930's thanks to FDR, and the REA (Rural Electrification Act).  She remembered her family getting a gas-powered Maytag with a flex exhaust hose that they could stick out the basement window.  This was sometime in the mid 1920's.  From what she told me, they had a wood stove in the cellar, a sink with a pump for water, and clotheslines for use in the winter.
Post# 582638 , Reply# 46   3/15/2012 at 11:56 (4,414 days old) by mickeyd (Hamburg NY)
Morning chuckle
Not reading carefully, it first sounded like Jim's friends used the pig water to wash the clothes. Laughing at myself.
Post# 582697 , Reply# 47   3/15/2012 at 17:24 (4,414 days old) by Yogitunes (New Jersey)
yogitunes's profile picture
Heres a few scans of a Speed Queen repair manual...interesting of all the different designs this washer had, not only thru the years, but in the same years as well, they had solid tubs, with time fill and metered fill as well.....they had one basic base design between motor, trans, pumps, tub and agitator.....but offered overflo rinsing, and filter tray, as well as agitator mounted filter pan, bleach injection of several designs, as well as softner designs....I guess it was a matter of BOL to TOL.....
it shows the suds return variations from a spout in the 10 o clock position...to returning thru the filter flume, if so equipted....
Post# 582698 , Reply# 48   3/15/2012 at 17:25 (4,414 days old) by Yogitunes (New Jersey)
#2
Post# 582699 , Reply# 49   3/15/2012 at 17:26 (4,414 days old) by Yogitunes (New Jersey)
#3
Post# 582700 , Reply# 50   3/15/2012 at 17:27 (4,414 days old) by Yogitunes (New Jersey)
#4
Post# 582701 , Reply# 51   3/15/2012 at 17:28 (4,414 days old) by Yogitunes (New Jersey)
#5
Post# 582865 , Reply# 52   3/16/2012 at 14:20 (4,413 days old) by ingliscanada ()
MikeyD
About the Maytag suds-return cycle, I know the helical-drive washer returned suds through the bottom with dry agitation, but was the same also true with the older MT AMP (ie solid tub with perforated inner liner)?
Gary
Post# 584409 , Reply# 53   3/22/2012 at 11:51 (4,407 days old) by mickeyd (Hamburg NY)
Gary, I'm pretty sure
that the systems are the same. In fact, I think Geoff D's Suds Tag is an AMP. There is a video somewhere.
Post# 584410 , Reply# 54   3/22/2012 at 11:52 (4,407 days old) by mickeyd (Hamburg NY)
OH MARTIN!!!
The Speed Queen's version of a suds return is a miracle of engineering. Holy Cow! I'm going to have to re-read and study because I didn't get it all the first time. But thanks so much for finding and scanning this. For me, it's candy.
Post# 584431 , Reply# 55   3/22/2012 at 13:49 (4,407 days old) by neptunebob (Pittsburgh, PA)
Bring it back?
If you all want me to maybe I can start a petition for Whirlpool to bring the suds saver back.  It would certainly be better than the low water level on the Roper.
Post# 584435 , Reply# 56   3/22/2012 at 14:14 (4,407 days old) by YOGITUNES (New Jersey)
Bob...the new Whirlpools don't use enough water to be worth saving.......you would not need a laundry tub, just a five gallon bucket to save the suds...
Mike...I re-read and looked over that diagram myself for hours trying to understand the complexety of this system......suds save, filtering, bleach dispenser?....if I had one, I would be afraid to take it apart for fear of not getting back together right....between that valve, and seperate return pump, the regular pump, and then, to drain, to save, or to filter.....that machine would confuse its ownself....lol...
not to mention, time fill, metered fill, or pressure valved fill.......
all this talk about the automatic ones........and people think I confuse them on my setup, either use a wringer as a tub, and its pump to return the water....or line up machines, draining one into the next.....you just have to be there to monitor it.......
