Thread Number: 39201
Tore into a Whirlpool WFW9750 today, interesting design changes
Post# 581074   3/7/2012 at 15:36 (4,431 days old) by MattL (Flushing, MI)
I picked up a Whirlpool WFW9750 for free a couple of months ago, it's been sitting outside, owner was told it had bad bearings and the cost to repair was too high.  After my previous experience replacing the bearings I jumped at it - especially for the price!  Temp here hit 65 so I tore the unit apart.
This is a Steam unit, but when I tore into it I did not find the steam generator I found on my previous machine.  However when I pulled the tub apart I found a dual element heater.  I've worked on a few Duets and never have come across a dual heating element.  I'm wondering if the steam function uses the heating element instead on these machines.  Also noticed they added a small fan in the vent area, I guess it's to keep things fresh, I have not powered the unit up so I don't know how often it runs. Large rear bearing totally shot, actually missing parts, small looks OK.  Not sure if I want to spend $$ on high quality stuff, but may make this one a keeper.
The cycles are pretty much the same as my WFW9600 except that the order is changed, Quick Wash is now just to the left of Normal vs. at the bottom on the 9600.  The 9750 does have a few more options, it has a rinse selector with 3 positions, and a night option that I guess slows the spin speed down to avoid too much noise.
After I get it up and running I'll have to decide what machines to list on CL, at this point I have 3 Duets only need one...
Post# 581101 , Reply# 1   3/7/2012 at 18:54 (4,431 days old) by logixx (Germany)
logixx's profile picture
That's just like on the Electrolux/Frigidaire washers: steam is generated by the water heater underneath the drum.
Post# 581154 , Reply# 2   3/8/2012 at 02:44 (4,430 days old) by jerrod6 (Southeastern Pennsylvania)
So is this really steam or is it just heating the water really hot and it is being called a steam washer.  My idea of a steam washer would be something that blasts steam across and through the clothes.
My washer has two 1300W heaters below the bottom of the tub in between the inner and outer tubs.  You can see them if you shine a flashlight down through the holes in the tub.  I don't know when it uses one or both heaters.
Post# 581155 , Reply# 3   3/8/2012 at 02:45 (4,430 days old) by qualin (Canada)
I understand that the fan is there as a response to users who like to keep the door closed after a wash, instead of leaving it open to let it air out.
Either that or when the load is finished and the clothes sit in the machine overnight, getting a moldy/mildewy smell.. the fan will put a stop to that.
It's not a bad design change IMO, but not necessary if people would just leave the darn door open after a load!
I think it's great you are repairing these machines.
Reminds me of a friend I have who has 14 cars. I asked him why the heck he has that many, he told me that they all had minor issues which he could easily fix for cheap, but was too expensive for the owner to get repaired.
I have the same problem with computers. They use up a lot less space than washing machines, but I've been in situations where people just GIVE me computers out of nowhere and ask me if I can do anything with them.. it always turns out that one component did go bad, but made the machine nearly unusable until it was replaced.
