Thread Number: 39262
Aqualits Problem - Leak ? PCB problem? |
Post# 582001 , Reply# 1   3/12/2012 at 18:55 (4,420 days old) by mrx ()   |   | |
Tested it again, and it got through the first bit of the wash cycle normally. Then the power started randomly switching on/off - drum light on/off etc Any ideas? This seems to happen when the pump starts. |
Post# 582183 , Reply# 2   3/13/2012 at 15:52 (4,419 days old) by ariston4life ((Dublin) Ireland)   |   | |
Post# 582377 , Reply# 3   3/14/2012 at 13:30 (4,418 days old) by electron1100 (England)   |   | |
My first test would be to electrically disconnect the pump and see if the problem still occurs when the machine qoes to pump out, obviously it cannot drain water so you will have to lay the hose on the floor or re-connect the pump
If the fault doesnt show up then maybe you do have a faulty pump thats were i would go with this one, and after this i would gladly take it to the tip coz i hate my aqualtis |
