Thread Number: 39276
ADA wringer washer |
Post# 582115 , Reply# 1   3/13/2012 at 11:30 (4,419 days old) by mickeyd (Hamburg NY)   |   | |
Post# 582122 , Reply# 3   3/13/2012 at 12:06 (4,419 days old) by mickeyd (Hamburg NY)   |   | |
Lance, it's so pretty, I hope you get it fixed. It seems loose when you put the clothes thru and it looks like it's not clamping in the back. Wringer can be finickety sometimes. I wish I could help. With the door open I thought it was warm. We're in the 60's here, way abouve normal; it's freaky, but we'll take it. Last March it was cold and snowy all month long.
Your agi cap is a lot like the classic Easy spin one. Interesting. Just thinking a pleasant thought, you've got the door open because of all the nice steaming heat you get from UK washers! |
Post# 582130 , Reply# 5   3/13/2012 at 12:29 (4,419 days old) by hoovermatic (UK)   |   | |
These must be as rare as hens teeth. My mum had an Adamatic twin tub in the early 1960's - it had a big lever on the front I remember - have never seen one since I was a kid. |
Post# 582131 , Reply# 6   3/13/2012 at 12:31 (4,419 days old) by hoovermatic (UK)   |   | |
Post# 582135 , Reply# 7   3/13/2012 at 12:41 (4,419 days old) by lancethecook (Driffield England)   |   | |
I didn't realise that Ada made a twin tub, I do have an AEG twin tub that has a big lever on the front, might it possibly be one of those? Unfortunately my AEG has a very bad leak on the spinner , another work in progress! |
Post# 582136 , Reply# 8   3/13/2012 at 12:50 (4,419 days old) by mickeyd (Hamburg NY)   |   | |
envy our UK, etc, brothers who have boil washers, and yes most of our homes have 110v and some 220 for elecrtric dryers and stoves. In my area, most people have gas dryers and stoves with no 220 lines, but the high volt are not hard to install.
I am not sure why our machines don't heat. Gas is much much cheaper than electricity here. Other people can answer this. Have often wondered why your washer heats and ours do not, ( Many new machines will heat, and a few older ones did, but the vast majority did not.) We're always cheering and hoping that a newly found unique TT will heat. Doesn't happen. And virtually none of our wringers heat. And yes, almost all of our machines fill with both hot and cold taps. When we want to almost boil, we can turn the hot water tank up from normal to hot, and then the water is scalding but not boiling.
For me, a soak in Tide with bleach powder takes out wine, chocolate and berry stains, but again many other members have more experience here. Tide HE powder and clorox also work wonders. Guessing that over here, it's more chemistry than energy. Nothing stained here (my house) sits for too long. I wash all the time. If I get filthy rich, I'm going to buy a heating TT and wringer from one of you lads and have it shipped. This post was last edited 03/13/2012 at 13:06 |
Post# 582138 , Reply# 9   3/13/2012 at 13:13 (4,419 days old) by mickeyd (Hamburg NY)   |   | |
Post# 582141 , Reply# 10   3/13/2012 at 13:22 (4,419 days old) by westingman123 ()   |   | |
That wringer is beautiful! Is that chrome or stainless? Took my breath away for a moment, there. |
Post# 582181 , Reply# 12   3/13/2012 at 15:37 (4,419 days old) by mickeyd (Hamburg NY)   |   | |
Post# 582207 , Reply# 13   3/13/2012 at 17:39 (4,419 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Ada top left, AEG bottom left.
From previous discussions it appears that the Ada facility was bought/taken over by Philips for production of the Top Twin twin tub. It may be that this was on the Ada design boards when they got taken over although it has to be said that in the Which tests the later Philips did a lot better than the Ada in 1960 |
Post# 582208 , Reply# 14   3/13/2012 at 17:42 (4,419 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
but I think the same facility might still be making White Knight Tumble driers. These used to be Philips models until Philips divested themselves of it in the late 1980s (I think)
CLICK HERE TO GO TO vacbear58's LINK |
Post# 582212 , Reply# 15   3/13/2012 at 18:07 (4,419 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Not so much a British thing as a European one.
From a UK point of view the first washing machines were supplied without heaters too. We had (and to an extent still do) hot water storage tanks in our homes as well although it would be fair to say that, back in the 1950s, by and large they would not have had the "recovery" time that US water heaters would have had. Others can be more specific on dates but I think it was about 1956 or so that Hoover started fitting heaters and certainly the Hoovermatic (1957) was supplied with a heater, and a powerful one at that. The small Servis wringer/washer (1956?) was designed to have a heater from the outset too and the first Servis Supertwin had a thermometer arrangement rather than a thermostat. Personnally I believe there are two factors - the first being that we did not have the tradition of using bleach in our laundry. The second is that there was a very long tradition of boiling whites - that goes back a long way so that late victorian houses onwards had wash houses built with coal fired "coppers" built into them for the specific purpose of boiling clothes. With the spread of the suburbs in every town and city with smaller kicthens and no wash houses came a wide range of both gas and electrically powered free-standing "wash-boilers". And it was not unusual for the whites to be put into the copper (or later wash-boiler) to soak while the water heated up. So hence the tradition was established. And even when the Hoovermatic was launched the wash action was described as "pulsator boiling action" - even though the water did not actually need to be boiling - but tapping into this same tradition. Al CLICK HERE TO GO TO vacbear58's LINK |
Post# 582296 , Reply# 17   3/14/2012 at 03:55 (4,418 days old) by keymatic (London / UK)   |   | |
Hi Lance,
Nice Ada there !! I have a similar machine, I think yours maybe the Balmoral model, but will check when I get home tonight. With regards to the wringer, is it the tension or the drive to the wringer ? I was'nt over struck on wringer due to the fact it was a set tension, and was un-adjustable. I think they were rather cheaply made machines what with the non-traditional gearbox. Hope you get your AEG Lavalux sorted, the spinners on them can be a bit of a pain-in the ar*e, i find out that the early model with (white knobs) has a saftey drain which kicks in really quickly when rinsing, and the later one (black knobs) doesn't have the drain, is it the pump or something else ? I have a couple of these machines, built like tanks..lol Al, I think Servis introduced a heater to there model "R" in 1950, however the styling was some what of a back-step due to the re-introduction of the four legs due to the national steel shortage. Paul, as you say, i think the Adamatic would be very rare !! It was a very early twin tub, being introduced in the late 50's. I have a nice pamphlet of it, i will try and scan at some point. Cheers Keith |
Post# 582331 , Reply# 19   3/14/2012 at 09:59 (4,418 days old) by keymatic (London / UK)   |   | |
Hi Lance,
I will try and get a scan done over the weekend, yes, the 3kw heater would certainly bring the water up to the boil quickly !! You mention the Burco 21, I have never seen one either, they look fab..I think someone in the Uk has got one as i saw someone salvaging one from the scrap yard, last year or the year before. Up at the top of the machines is the Acme Twinspeed..not sure what this was like, but with the name "Twinspeed" wonder if you could choose between gentle & normal wash power ??? I don't think Which rated it very well. Good luck on the AEG, i know the spin outer can is sheet steel which is prone to corrosion.. Cheers Keith |
Post# 582421 , Reply# 21   3/14/2012 at 18:08 (4,418 days old) by keymatic3203 (Cardiff UK)   |   | |
wash tub |
Post# 582423 , Reply# 22   3/14/2012 at 18:10 (4,418 days old) by keymatic3203 (Cardiff UK)   |   | |
Spinner |
Post# 582541 , Reply# 24   3/15/2012 at 03:47 (4,417 days old) by keymatic (London / UK)   |   | |
Hi Mathew,
Nice machine there !! With reference to the rinising..the pump doesn't cut in if you don't have it switched on, i think what i was ment to say was, if you over filled the spinner slightly when rinsing, there is a sort of valve thing that just empties the spin can all over the floor, unless i have a dodgie machine !! My older machine with the black knobs doesn't do it for some strange reason. I think your right about the Acme Twin-Speed..i know Which didn't give it a very good write up, stating the control lever was to low to the floor. Although it did have a nice emptying arm for the spinner, bit like the Hoover spinarinse. Going back to the AEG, the internal hose set up inside is a nightmare, the wash & spin hoses into the pump are so small, and are arranged in a Y shape set up, on one of my machines i had to put an electric pump in. Cheers Keith |
Post# 582579 , Reply# 25   3/15/2012 at 08:45 (4,417 days old) by keymatic (London / UK)   |   | |
Post# 583303 , Reply# 26   3/18/2012 at 14:22 (4,414 days old) by keymatic (London / UK)   |   | |
Post# 583305 , Reply# 27   3/18/2012 at 14:24 (4,414 days old) by keymatic (London / UK)   |   | |
Post# 1177233 , Reply# 28   4/5/2023 at 13:50 (379 days old) by anthony (uk)   |   | |
the Ada wringer washer .As a young boy i remember my aunt having an Ada wringer washer but it was much older [or at least it looked older ]it was cream and was the size of a hotpoint empress .I remember it being used and then later being replaced with a twintub .the Ada was pushed into the corner of the washhouse where it sat for many years till my aunt died
